Abs fault, I really need some help please
Alex polo
Drives: 2015 polo 1.0
Post by Alex polo »
Hi everyone, I have fault codes
U101700, c114602, c101d29, u112400, u112300.
I have replaced a rear wheel sensor and rear brake shoes can anyone help point me in the right direction with my daughters car it is a vw polo 2015, 1.0 blue motion.
Many thanks
Alex
Re: Abs fault, I really need some help please
In what modules do you read these code? A longer description of the code would be good since these codes are very generic.
Alex polo
Post by Alex polo »
Is this what you are after ?
yes. so it might be worthwhile to check the cable that goes to the abs sensor and check for any damage.
Alex polo
Post by Alex polo »
What is the best way to do that other than visually?
Alex polo
Post by Alex polo »
And on live data all the speeds match up as well
Yes either visually or with a multimeter. If that works out, in rarer cases the magnetic ring on the sensor is dirty or something is wrong with/at the ABS unit.
Alex polo
Post by Alex polo »
My thoughts were it is the abs pump module, but I will test the other things first, many thanks
On such a young car, it hardly ever is the module itself.
Can you check the wire connector and cable leads leading towards the sensor? Just back trace it a bit, see if there is some corrosion inside of the connector? Maybe damaged wire?
