dkudel
Drives: Vw caravelle 2015
Post by dkudel »
It's a pity that you can't help me, maybe you know where I can buy an original harness that will fit?
Shadow109
Drives: Vw t5.1 2013
Post by Shadow109 »
Believe me the only way is to do it yourself
dkudel
Post by dkudel »
Unfortunately, I don't know how to do it :shock:
Ciclo Can you explain to me step by step what wires and pins I have to change :roll: My lights are H7 vw t5.1 caravelle 2015
dkudel
Post by dkudel »
Hi bropasiek, maybe you are can help with the wiring harness for auto light ps. dzieki
Shadow109
Post by Shadow109 »
dkudel wrote: Sun Nov 06, 2022 1:59 am Unfortunately, I don't know how to do it :shock:
You have to read this article many times, write down any thing you think it will help you
post an autoscan with some pictures like everyone did here
Pit
Drives: T5.1
Post by Pit »
HI , I have read this thread several times now and more to come , first question before being stuck with this conversion, is there a list parts required to have on the beginning headlights excluding. Mine van is Shuttle from 2010 I guess it will require some work to be successful but i would like to have washers bixenons and leveling system fitted. but getting confused from the start.... :shock: continue to read from beginning ....
Can anyone give me number for red coupling connector?? please....
Pavlo
Drives: T5.1
Post by Pavlo »
Hello everyone. I have a 2013 t5.1 and i have retrofitted bixenon led headlights vw genuine. I have done coding and it works. Only priblem i have is when i changed bit on byte 12 and 22 i accidentally unticked all figures and didn’t save them at the beginning. At the moment low beam doesn’t switch on auto mode only on manual switch and blower is on full time.
Pit wrote: Wed Jan 25, 2023 1:44 pm HI ,
ISO 10 pin connector.
Pavlo wrote: Wed Mar 22, 2023 11:16 am Hello everyone. I have a 2013 t5.1 and i have retrofitted bixenon led headlights vw genuine. I have done coding and it works. Only priblem i have is when i changed bit on byte 12 and 22 i accidentally unticked all figures and didn’t save them at the beginning. At the moment low beam doesn’t switch on auto mode only on manual switch and blower is on full time.
Please post the current BCM coding so I can tell you what to do.
Pavlo
Drives: T5.1
Post by Pavlo »
Ciclo please find a picture attached. The is a Long code and Long code No2
Ideally, post the long code as a text string (hexadecimal) and not through images, it's as easy as copying it from Autoscan and pasting here, so that I can more easily study it with my powerful tools.
Using images I would have to enter the hexadecimal values of each Byte one by one in the boxes of my tools to be able to study it, which is a tedious task and with the possibility of making a mistake when doing it.
I ask you please to post a Full Autoscan.
In the Logs folder of the Ross-tech program you have all the autoscans that you have done to your T5.1, maybe you will find everything you need there.
However, for now:
- Enable Byte22 Bit5.
- Byte12 is fine as it is, although it depends on personal taste when it comes to Bit2, it's your decision. (usually enabled)
Pavlo
Drives: T5.1
Post by Pavlo »
Thank you. Auto lights are now working. Does anyone know if bixenon headlights can be manually adjusted? I mean on the dashboard.
It is not possible from the dashboard, in case you mean vertical adjustment. We assume that you have not installed the headlight height control unit and the corresponding sensors.
You can do vertical and lateral adjustment with the wall method with the two adjustment screws (usually white in color) that are built into the headlights.
You only need a phillips screwdriver, although a flat one will also work.
This is the wall method (DIY):
viewtopic.php?p=582906#p582906
It is very easy, the lights will work perfectly and you will not dazzle anyone, it is 100% effective for any type of headlight. Enough to be happy with your lights. :lol:
You can also do it with a reglosscope, which will be somewhat more precise and specific for your headlight model, although the results hardly differ from those obtained with the wall method. In this case, each vehicle model has a procedure specified in erWin.
Pavlo
Drives: T5.1
Post by Pavlo »
Thank you. It is all adjusted, works and looks great. Would any of know why my aircon blower works full time i mean after i take the key off it still works and drain the battery unless i switch it to 0 position b4 i leave the van. The problem started after headlights were changed.
Gemo
Drives: Vw polo 1.4 GTI DSG
Post by Gemo »
Pit wrote: Wed Jan 25, 2023 1:44 pm HI , I have read this thread several times now and more to come , first question before being stuck with this conversion, is there a list parts required to have on the beginning headlights excluding. Mine van is Shuttle from 2010 I guess it will require some work to be successful but i would like to have washers bixenons and leveling system fitted. but getting confused from the start.... :shock: continue to read from beginning ....
Hi Pit
Did you ever bottom out your parts list request ? Did circo come back to you ?
Gemo
Post by Gemo »
Hi Every one
I have tried to install a new BCM into my 2012 VW Transporter 5.1 GP part number 7H0937090D. It thinks I have DSG auto gearbox, however I have got a 6 speed manual. When using VCDS if I go into auto scan code select all and look at Address 02 can I change the DSG auto trans to 6 speed manual ?
