Polo 6r GTI - Bi-Xenon installation Issues
Re: Polo 6r GTI - Bi-Xenon installation Issues
the difference between rapid and Polo/Ibiza/T5.1/5.2 is mostly in the details, the bigger process will involve adding power lines to the BCM, light switch input lines to the BCM and light output lines from the BCM.
you must know your 'as is' situation based on wiring diagrams and verify with your car
you must know your 'to be' situation based on your studies of the wiring diagrams
the difference between these is what you must do to successfully install the BCM max and the bixenons.
from there, part of the wire go to bcm and rest to new T10 connector of new autoswitch and T40?
- 4444.JPG (107.18 KiB) Viewed 4244 times
Yes, exactly, You can re-use some wires as they are the same regardless of what BCM is installed.
Other wires need to be re-routed to the BCM and from BCM to external lights/fuse box.
I don't think you need to run wires to T41 for the stalks, unless you want the BCM to control high beams too (7E0 only)
In my case T16 as I understand, no t41.
Anyway
if there something special i need to do after harness complate in case coding? i have BCM t6 090.
Almost work except Hi beam no flashing without lo beam.
Drl led flashing as crazy and didn’t working on another two position.
All back light and light inside car work perfect.
Anyway
3 Bugs found:
00886 - Turn signal switch (E2)
008 - Invalid signal
Saved freeze frame:
Fault status: 01101000
01495 - Left High Beam Lamp (M30)
010 - Open circuit or short to positive
Saved freeze frame:
Fault status: 01101010
01499 - Right high beam lamp (M32)
Saved freeze frame:
Hmm... please post here a fresh Autoscan.
(viewtopic.php?p=597930#p597930) I didn't intervene because I thought you already had help.
after some manipulation today i forgot make vcds scan but i have from carista. there no difference in fault light code anyway
just for test The pin from T73B/29 that come to T17/3 i remove it from socket , and drl stil working
If you want help, you should do and post a full Autoscan due to many more reasons than detected faults.
I will be able to help you with the BCM coding and maybe to solve some problem due to an incorrect electrical installation, but I do not have the wiring diagrams for Skoda models, so the help will be somewhat limited.
For example:
-According to the faults that you show us, apart from correcting the BCM coding, the BCM adaptation channels would also have to be reviewed.
-According to the pictures of the T17 light switch connector, wires 13 and 14 should not be there.
For example:
Thank you
i post 2 pic t17 after evolution
I am not sure if i need cut T17/14 or reconnect other side to T73A/45 or it already connected?
https://vwts.ru/skoda/rapid/skoda_rapid ... 12_eng.pdf
7E0937090
BCMPQ25
0736-
H80
2 error i can remove but how is help? turt signal right still make a partial sound
in 17 bit uncheck 2(M30-M32 lost after scan)remains Е2
7E0937090
BCMPQ25
0736-
H80
Chassis Type: NH-SK25 (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 56 0B
VIN: Mileage: 195430km-121434miles
[b]09-Cent. Elect. -- Status: Malfunction 0010[/b]
Address 01: Engine (J623-CAXA) Labels:. 03C-906-016-CAX2.clb
Part No SW: 03C 906 016 CR HW: 03C 906 016 CR
Component: 1.4l R4 TSI H02 4874
Revision: LJH02--- Serial number: CVN: 761A8B19
Coding: 00250012000400000000
Shop #: WSC 73430 031 00125
ASAM Dataset: EV_ECM14TFS01103C906016CR 001004
ROD: EV_ECM14TFS01103C906016CR.rod
VCID: 71E960C3A0A913057D-8024
VINID: 91D4919067981D41000C51C9086C1421BB
Readiness: 1110 0101
Part No SW: 0AM 300 060 E HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6203
Revision: 00043014 Serial number: CU501601216604
Coding: 0000020
Shop #: WSC 08643 002 1048576
VCID: 2C57B1B78F0B3EED0E-8078
Address 03: ABS Brakes (J104) Labels: 6R0-614-517-TRW460.clb
Part No SW: 6R0 614 517 BK HW: 6R0 614 517 BK
Component: EBC 460 ESP H08 0004
Serial number: A00AWQ1
Coding: 4129481409B400B9824E12DB90A200404B0800
ASAM Dataset: EV_Brake1ESPAEntryTRW 002011
ROD: EV_Brake1ESPAEntryTRW.rod
VCID: 7DF14CF3ECF16765E9-8028
Part No SW: 6RA 959 654 HW: 6RA 959 654
Component: LENKW.SENSOR H02 0020
Serial number: 28051304210234
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005002
ROD: EV_LWSKLOVW25X.rod
VCID: 0F2D063BD65D65F50B-805A
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb
Part No SW: 5JA 820 045 HW: 5JA 820 045
Component: Man AC H06 0101
Revision: 2013SH06
VCID: 73E56ACBD2B521158F-8026
Part No SW: 7E0 937 090 HW: 7E0 937 090
Revision: B9080001 Serial number: 0771 003200040
Coding: 6C980F2000210400000808303F480CC00F406607600308C0060000024800
Shop #: WSC 18752 008 00032
VCID: 68DF0DA79B73D2CD2A-803C
Subsystem 1 - Part No SW: 5E0 919 719 C HW: 5E0 919 719 C Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H03 0120
Serial number: 000000000A0184150513
[b]3 Faults Found:
00886 - Turn Signal Switch (E2)
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 195436 km
Time Indication: 0
Date: 2017.10.08
Time: 11:06:59
01495 - Bulb for High-Beams; Left (M30)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 48
Mileage: 195436 km
Time Indication: 0
Date: 2017.10.08
Time: 11:06:59
01499 - Bulb for High-Beams; Right (M32)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 48
Mileage: 195436 km
Time Indication: 0
Date: 2017.10.08
Time: 11:06:59
[/b]
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 34D 959 655 B HW: 34D 959 655 B
Component: AirbagVW20 004 0365
Serial number: 003K7R016UMU
Coding: 88CCC00000000000540000C8000000000045
Shop #: WSC 73430 790 00125
ASAM Dataset: EV_AirbaVW20SMEVW253 001108
ROD: EV_AirbaVW20SMEVW253.rod
VCID: 3467A9D79F3B662D56-8060
Subsystem 1 - Part No SW: ----------- HW: 480 411 805 13
Component: SideSensor_Df 003 0148
Serial number: 349650A25E62A7233EDW
Coding: 2D2D2D
Subsystem 2 - Part No SW: ----------- HW: 480 411 805 13
Component: SideSensor_Pf 003 0148
Serial number: 350650A25E6C6F22AF6
Coding: 2D2D2D
Subsystem 3 - Part No SW: ----------- HW: 480 411 805 13
Component: SideSensor_Dr 003 0148
Serial number: 351650A25E62ADF2AF1$
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 480 411 805 13
Component: SideSensor_Pr 003 0148
Serial number: 352650A25E62A2F4EC4Z
Coding: 2D2D2D
Part No SW: 5JA 920 810 B HW: 5JA 920 810 B
Component: KOMBI H04 0709
Coding: 110A01
ROD: EV_Kombi_UDS_VDD_RM09_004_SK25.rod
VCID: 366393DF8947743D68-8062
Part No SW: 7E0 909 901 HW: 7E0 937 090
Revision: B9080001
Coding: 332200
Component: IMMO H04 0709
VCID: 6ADB77AF8D7FE0DD3C-803E
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11230
Shop #: WSC 73430
VCID: 306FA5C7F7235A0D32-8064
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:11)--------------------------[/quote]- Attachments
- T17 22.JPG (119.87 KiB) Viewed 3952 times
- T17 11.JPG (92.02 KiB) Viewed 3953 times
- Once I've reviewed the diagrams from your link, wires T17/13 and 14 should stay where they are from factory, ... the Rapid's xenon headlights are somewhat simpler than those of the 6R.
- Try this BCM coding: (first test)
6C980F2000210400000808303F480CC00F406607600308C0060000024000
- Go to BCM Adaptation and check that channels 53 and 54 have value 0. Change to 0 if you find value 1.
- reports the results.
Thank you
Ok i add T17/13 back.
You new code change work of Steering column switch, hi beam with this code work non stop and unpossible to blink with it.
Everything else work is the same as before.
Adaptation Channel 53-0-0,54 0-0.
some vag owner of polo, jetta and rapid mention that only if I FIX eeprom with VCP or Odis it can help in my situation.
Do u know something about that?
PWM Value with POS/TFL lights and activated Pos-lights .
New BCM coding: (second test)
6C980F2000210400000808303F480CC00F404007600308C0060000024000
Please explain what is everything else, thank you. (I read your previous posts, but I don't know what additional failures there are apart from the autoscan)
Else
Drl not stable and flickering, drl not working as parking light and no with lo bean. Can’t blink with Hibeam if lobeam not active
I run outside to check new code
Up
Else
Up
Apart from the signal from the light switch to the BCM T73b/29 for DRL, have you installed two 'NEW' wires from the BCM to the xenon headlights?
BCM T73b/29 for DRL i connect it direct to T17/3.i try connect it to wire from SB17 but no difference.part from the signal from the light switch to the BCM T73b/29 for DRL
Yes 2 from Hibeam pin to L-A1,R-B1have you installed two 'NEW' wires from the BCM to the xenon headlights?
Drl same story,+no lo no hi beam at all. When I switch to lobeam it blink a bit and stop working
Well, in that case (low and high wired from BCM to headlights), you should modify and install more wires in E4 for Low and High beam.
E4
Check your diagrams for clarification.
Regarding the DRL, the diagrams do not seem to be clear. There is no representation of an LED module that controls the DRLs and side/parking lights on the same LED strip. I haven't tweaked anything in the BCM coding for the DRLs yet, the BCM coding tests are to find out what's going on with your installation (low/high).
I am completely unaware how the xenon headlights of a Skoda Rapid (pq25) work, even if during the production years of this vehicle there were different models of xenon headlights. I can only base myself on what I see in the diagrams, and from there test the codings.
Any video or images would help me understand these headlights.
E4
