I've tried a quick SEARCH on the forum, but can't seem to find an answer.
While I know that modern car batteries are a lot better these days.
During the winter months (& it can get pretty cold up here in Scotland), I tend to usually stick my battery on trickle charge once a month if I've not been using it that much (or for loads of short journeys).
Now the battery in my new car (Polo GTI) appears to be hidden in the boot, under the spare wheel. Not easy to get at.
Question... are there any pick up points under the bonnet that allow you to connect a smart charger?
Thanks in advance.
Polo GTI mk6 face lift battery charging
Re: Polo GTI mk6 face lift battery charging
yes there is a big red jump start terminal next to the ECU on the right side (drivers left). you can use that as a plus.
for the minus you can use chassis, engine, engine mount, etc
MikeDO
- Drives: GTI 2022 (white)
Thanks for the reply.
Just had a look and found what you mentioned. There also appears to be a BIG bolt to the right of it marked -ve.
So looks like that's sorted then.
Thanks again.
Thanks again.
Can you tell me where did you exactly plug the negative ? I can’t find anything, that’s standing out..![Image]()
- IMG_1416.jpeg (4.5 MiB) Viewed 24298 times
any bare metal on engine or gearbox will do
Can you draw some points on the photo, so I can be sure ? Thanks!
- Maarten
There should be a big knob like stub in the right side just beneath the parafan of the windscreen.
That's your minus.
That's your minus.
MikeDO
That's the one
