iichels VW Passat 2.0 TSI DSG 4-Motion 2017
Re: iichels VW Passat 2.0 TSI DSG 4-Motion 2017
Amongst other performance upgrades I did recently, I installed the upgraded DSG oil cooler 02E409061C
This will allow for higher cooling capacity and quicker heating up of the DSG oil when cold.
https://imgur.com/a/8wlyrVC
If you want the racingline (like) R600 intake but don't want to spend the big dime and/or don't like the looks...
Drill some holes into the original air guide behind the front grille.
Install blocking plate 5Q0129849.
Remove snow guard 5Q0129668D.
I haven't confirmed this by any means, but a lot of people report very positive results with these modifications.
https://imgur.com/a/FrYZs1O
Gave the good old DSG and Haldex a service as well, since they weren't done since the car was born.
Febi 850cc of Haldex oil ref G060175
Febi 5 liters of DSG oil ref G052182
Febi DSG oil filter 02E305051C
OEM DSG oil plug N90215404 + N0438092
OEM Haldex oil plug N90281802
Tools you need:
24mm socket for DSG filter
14mm Allen for DSG plug
8mm Allen for DSG snorkel
8mm Allen for Haldex drain plug
5mm Allen for Haldex filler plug
Oil drain pan from my favourite brand https://www.amazon.nl/dp/B0062U6628?psc ... ct_details
DSG filler hose https://www.amazon.nl/dp/B0BJ68JGS5?psc ... ct_details
Haldex filler hose https://www.amazon.nl/dp/B014ENZC2O?psc ... ct_details
Let the fun begin...
Remember the filter on the pump (Haldex gen 5). Haldex gen 4: loose filter insert, buy it!!
Insert the filler plug when the oil is > 20 and < 40 degrees C
DSG gearbox...
Factory oil and oil filter :evil: :evil:
Let the engine run, go through all gears for at least three seconds while holding down the brake pedal...
Remember to drain after filling, when the DSG oil is at 45 degrees C
Top fill via the oil filter hole is also possible, it's slow and you have to measure how much went in and how much you put back in.
Not the factory way, but good method!
Allright, so I probably haven't told you about my Audi TTS brakes yet, did I?
I mean, I sort of did, but not all of it...
viewtopic.php?p=595443#p595443
viewtopic.php?p=596761#p596761
Parts front:
Calipers: 8S0615107 + 8S0615108
Pads: 8S0698151A / B / G
Brake lines: 8S0611701B (12mm banjo to the caliper)
Parts rear:
It's identical to the Passat 310x22 setup. Only the handbrake actuators have a different part number.
The front is a bolt-on solution with the original spindles, disc, etc.
They are installed, along with a fresh filling of brake oil and new steel brake lines. The factory oil was still in place.
The pedal feel is lovely!
More pictures: https://imgur.com/a/OHyfm1Y
fluidicjoy
Drives: Polo 1.0 TSI 6AT (09G)
Post by fluidicjoy »
patil wrote: Fri Apr 21, 2023 7:22 pm
iichel wrote: Fri Apr 21, 2023 4:22 pm
You can still disable kessy for one cycle by pressing lock on the fob, and touching the door handle sensor for 'lock'.
This feature has an important implication as well. It adds another layer of safety by disabling kessy temporarily, and preventing car theft. I liked this feature very much and use it when I feel I have parked my car at unsafe places. :)
Owner's manual explains it's operation in detail:
I may have 100's of reasons not to love VW, but I have 1000's of reasons to love
:mrgreen:
This is a great share. Thanks for sharing this. I've always wondered if KESSY could be temporarily disabled and would love to try this out.
patil wrote: Tue Apr 25, 2023 6:09 pm Black and white combination :)
Your Bi projector led headlights have dynamic AFS?
For that 360 camera, need PLA 3.0 right. And also need new PDC button with camera logo or stock PDC button also does the job?
We had installed 360 Camera on my friend's Tiguan and had not upgraded the 8K OPS, so I believe we do not need PLA 3.0. Plenty of buttons work to trigger input for the 360 Camera, including the Stock PDC button.
fluidicjoy
iichel wrote: Sun Apr 23, 2023 2:53 pm So, allow me to do share a nice retrofit, the 360 Area View / Overhead View camera.
- 1x Camera module 5Q0 907 556x
- 4x camera 5Q0980546A
- 2x bracket for mirror camera's 3G0857689
- 1x foam for below right seat 3G0907285, to mount the module
- 1x 3G0927132J (or without PLA another module) buttons in dash
- Wiring looms for module and video feed cables to all four camera's
- 2x 8R0972702 and 2x 8R0972701 connectors for door wiring loom in A pillar
- Remove the door panel and lead the cable to the A pillar connector. I opted not to change the 27-pin connectors to 8R0972702/701 but use MCON in the four available holes
- To connect the module to the car, I took the original +30 cable in the right hand side sill and spliced into it. There, the wire to the RVC compact is already present.
Thanks for sharing your experiences with the 360 Camera Retrofit. Are there are advantages opting for the MCON crimps, compared to the LVDS cable in the door connector? Do your wires experience a bend closer to the door connectors? This was a reason, I thought I need to find a 90 degree wire for the door connectors, suitable enough for the door connector. I have collected nearly all the parts for installing this on my father's Tiguan and I purchased 3Q0972701 and 3Q0972701 for the A-pillar door connectors. I tried searching for the patch wires that connects the Door to the Mirrors and Module to the Doors, but couldn't find it listed separately. Could you please help me find what type of connector will fit? I am attaching pictures of the door connector I bought. I already anticipate that this could be a painful task to translate all of these existing wires to the new connector. :?
WhatsApp Image 2023-01-14 at 12.31.56 PM-2.jpeg (96.88 KiB) Viewed 14433 times
WhatsApp Image 2023-01-14 at 12.31.56 PM-3.jpeg (114.69 KiB) Viewed 14433 times
WhatsApp Image 2023-01-14 at 12.31.56 PM-4.jpeg (127.77 KiB) Viewed 14433 times
WhatsApp Image 2023-01-14 at 12.31.56 PM.jpeg (95.8 KiB) Viewed 14433 times
Yeah, I mostly couldn't be bothered with re-pinning all these pins on the door connector and it was a real pain to source the exact correct wires and cables. So I took the easy way.
OEM steel oil sump pan for EA 888 TSI engines
06J103600AF + 20x M6x15 + liquid gasket
Ever since I found out that my OEM sump is made out of plastic, it bothered me. No reason for it, it just did.
The OEM sump is probably a composite material and very strong. But it needed to go.
The process is very simple.
Drain oil, wait... Remove old T27 bolts, remove old sump, clean edges, install new sump, tighten bolts, check for leaks and be happy. And add oil to engine :mrgreen:
Upgraded by 3Q0 ACC radar to the newer 3QF radar. Only one letter different but all the difference.
My old radar lost its calibration after, perhaps of my own doing, the front of the car was taken off. And put back slightly out of alignment.
My 3Q0 radar needs a full dealer calibration, I could only manage to complete it myself for a very short while.
The 3QF radar just needs a brick wall, a tape measure and a drive on the motorway for calibration. So whenever I mess it up, and I WILL mess it up, I can fix it myself.
Plus, I now have pACC! Predictive ACC that reads the traffic signs and map data.
Swap codes:
10009008 MRR, package 8: ACChigh ( ACC S&G) + FrontAssist including CityANB
10009101 ACC function extension package "predictiveACC"
10009205 AWV version" AWV1,2,3, vFGS, vRFS "
10009300 no expansion
https://imgur.com/a/BgPdcu6
prtvrk
Drives: 6C
Post by prtvrk »
Is 3QF heated? I've always had trouble with B8s in Estonian winter's that sludge builds up on the emblem and acc goes offline.
I don't know to be honest. I did see 'heated lens' in the coding. But that's no guarantee it's actually heated.
Updated A5 camera to FW L 0610 + parameters, to experiment with tighter lane tolerance
Tuesday,23,May,2023,14:42:37:11868
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
Workshop Code: 123 30389 056831
VIN:   License Plate:
Mileage: 147634km-91735mi   Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 22 2B 36 3C 42 44
          47 4B 52 5F 65 69 6C 6D A5 BB BC CA CF D6 D7
VIN:   Mileage: 147634km-91735miles
05-Acc/Start Auth. -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
47-Sound System -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-CJXA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 3G0 906 259 B    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0002
   Revision: --H13---    CVN: 73B77959
   Coding: 091D003A2476050B3004
   Shop #: WSC 30389 123 56831
   ASAM Dataset: EV_ECM20TFS0203G0906259B 001003
   ROD: EV_ECM20TFS0203G0906259AC_VW48.rod
   VCID: 2B03FAEDB387D5928A9-807E
   VINID: 9E69EAAAA0D3A9A54008518520274044B7
Readiness: 1110 0001
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 018 C    HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5201
   Revision: 06454104    Serial number: TFK01706160335 CVN: 0000580D
   Coding: 0014
   Shop #: WSC 05311 115 00065
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 1C612931E629222AF33-8048
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0743
   Revision: 00000000    Serial number: 61907000000236
   Coding: 0FEC6B8F54222371477D070540CB69F0D62AC4E2E00296753842508842A9420000000012121212B835351919323200
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010
   ROD: EV_Brake1UDSContiMK100IPB_036_VW48.rod
   VCID: 79AF10A5095BB702485-802C
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0906
   Revision: 00037000    Serial number: 0448732144 Dataset Number: V03935260TX 0001
   Coding: 1F20200723
   ASAM Dataset: EV_KessyHellaMQBAB 004041
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3E25C3B950F5503A3D7-806A
   Rear lid opener control module:
   Subsystem 1 - Part No SW: 3G0 962 243     HW: 3G0 962 243
   Component: GEB.F.Heckoef  H17 0812
   Serial number: ;8001216
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 3G8 907 044 R    HW: 3G8 907 044 R
   Component: Climatronic   H10 0221
   Coding: 12020024104111011115500D0014592A
   ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 002004
   ROD: EV_AirCondiBHTCMQB3rTranc_002_VW37.rod
   VCID: 3C21C9B146E9422A133-8068
   Air quality sensor:
   Humidity sensor: exterior:
   Rear air conditioning block 1:
   Subsystem 3 - Part No SW: 11A 907 049 A    HW: 11A 907 049 A
   Component: E265 KPH SH  H02 0183
   Serial number: G04S01.11.2100972191
   Coding: FFFFFF
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 034 0242
   Revision: --------    Serial number: 865829061700DO Dataset Number: V03935260TT 0001
   ASAM Dataset: EV_BodyContrModul1UDSBosc 018001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 06556B5948A5C8FA357-8052
   Wiper motor control module:
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    170615  042 0607
   Serial number:         170629234856
   Coding: 0F4DFD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  042 0105
   Serial number: S4Y17M06D29H19M25S21
   Coding: 06A8DD
   Light switch:
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Component: E1 - LDS MQB  H01 0032
   Serial number: 14 04 2017  10001690
   Anti-theft alarm system sensor:
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY1714382PB
   Alarm horn:
   Subsystem 5 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0314
   Serial number: 00000000000070188699
   Humidity sensor: interior:
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0045
   Serial number: 000308417617172 Dataset Number: V03935256HH 0001
   Coding: 0A71167951
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 50F98D01FA61D64ADFB-8004
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 S    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0780
   Dataset Number: V12345678AA V315
   Coding: 351F5FEBDFFFCF28979F813681500D00000000000099000002
   ASAM Dataset: EV_ACCBOSCHVW416 003015
   ROD: EV_ACCBOSCHVW416_003_VW41.rod
   VCID: 47CBA65D0F2F11F28E1-8012
Address 14: Susp. Elect. (J250)       Labels: 5Q0-907-376.clb
   Part No SW: 5Q0 907 376 C    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0130
   Serial number: 25061741350001 Dataset Number: V03935316RN 0001
   ASAM Dataset: EV_DRCONTITEMIC 001019
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 392FD0A549DB7702085-806C
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 BK    HW: 3Q0 959 655 BK
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W6PCG5P2/ Dataset Number: V03935266FT 0001
   Coding: 98FCC0C0008000005C5400CF000800000065
   Shop #: WSC 05314 000 00001
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
   ROD: EV_AirbaVW21TS6VW48X_VW37.rod
   VCID: 0849656142B1DE8A47B-805C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945 A    HW: 4M0 980 945 A
   Component: BeltPretRevFL  106 1040
   Serial number: 3G0857705 0031T01500
   Coding: 80000D
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946 A    HW: 4M0 980 946 A
   Component: BeltPretRevFR  106 1032
   Serial number: 3G1857706G0185R01460
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 001 606 17
   Component: SideSensor_Df  008 0887
   Serial number: 357000000000507D3628
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 454 001 806 17
   Component: SideSensor_Pf  008 0887
   Serial number: 358000000008D140C62J
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 454 801 106 17
   Component: SideSensor_Dr  301 0148
   Serial number: 3510091305210000000U
   Coding: 2D2D2D
   Subsystem 6 - Part No SW: -----------    HW: 454 801 106 17
   Component: SideSensor_Pr  301 0148
   Serial number: 352002F2F52100000009
   Coding: 2D2D2D
   Subsystem 7 - Part No SW: -----------    HW: 454 801 406 17
   Component: FrontSensor_D  304 0149
   Serial number: 3550040279610000000%
   Coding: 2D2D2D
Address 16: Steering wheel (J524)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 KT    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0265
   Revision: FF035035    Serial number: 20170828500092 Dataset Number: V03935250KY 0001
   Coding: 8410
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 0E45537920D580BA8D7-805A
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 3G0 920 791 D    HW: 3G0 920 791 C
   Component: KOMBI         406 4191
   Coding: 07AD0898FE8C000C01887F0F3001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009058
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 2A0DFFE9BC7DCC9A71F-807E
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 H    HW: 5Q0 963 272 H
   Component: STH-MQB       008 0075
   Coding: 9309
   ASAM Dataset: EV_AuxilParkiHeateWOS 002018
   ROD: EV_AuxilParkiHeateWOS.rod
   VCID: 3B23CAAD43E745121A9-806E
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0401
   Serial number: 00000000000000276932
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5366
   Serial number: 06071710802132 Dataset Number: V03935278KN 0001
   Coding: 0B0300347F015900FB00025E9C0F00010001070000000000000000000000
   GVL: 01DE3C0008000600C0DC80000006CC0010040000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013025
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E8533F94015E0BAED7-803A
   Generator:
   Component: 0-00-03-00-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 1EA 959 442 E    HW: 1EA 959 442 E
   Component: MFL  H03 0219
   Serial number: 17036218123222100161
   Coding: AF0900
   Subsystem 3 - Part No SW: 3Q0 915 181 B    HW: 3Q0 915 181 B
   Component: J367-BDMHella  H10 9070
   Serial number: 5131394104
   Inverter for electrical outlet:
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: U13DCAC  H26 0780
   Serial number: 0066181
   Analog clock:
   Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 3003201700010095
Address 22: AWD (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 H    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7083
   Serial number: HA1-00017.05.17 Dataset Number: v1260x015G0 0000
   Coding: 0601
   ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
   ROD: EV_AllWheelContrHA1VW37X_004.rod
   VCID: 4ACD9F691C3DEC9A91F-801E
Address 2B: Steer. Col. Lock (J764)       Labels:* 5Q0-905-861.clb
   Part No SW: 3Q0 905 861     HW: 3Q0 905 861
   Component: ELV-MQBB      H05 0032
   Serial number: 17000160250002
   Coding: 0800000000000000
   ASAM Dataset: EV_ELVMarquMQBB 001007
   ROD: EV_ELVMarquMQBB_VW41.rod
   VCID: 71BF2885512BFF42F05-8024
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 3Q0 959 760 B    HW: 3Q0 959 760 B
   Component: Sitzmemory    H05 0022
   Serial number: Y0006QFD15173
   Coding: 001000020000050081C280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   ROD: EV_SeatMemorDriveSide.rod
   VCID: 3A2DCFA94CDD7C1A01F-806E
Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
   Part No SW: 3Q0 907 566 E    HW: 3Q0 907 566
   Component: MRR1Rear      H20 0510
   Revision: --------    Dataset Number: V03935248QY 0001
   Coding: 14C002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001007
   ROD: EV_RearRadarS1BoschVW48X_VW37.rod
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 E    HW: 5Q0 959 593 B
   Component: TSG FS        020 0041
   Serial number: 190417EDJ1110A Dataset Number: V03935256EF 0001
   Coding: 00351A20D200028000111000
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 43D3B24D3B173DD2529-8016
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 K    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  506 5072
   Dataset Number: V03935256EB 0001
   Coding: 9307
   Shop #: WSC 00015 115 00319
   ASAM Dataset: EV_SteerAssisMQB 013144
   ROD: EV_SteerAssisMQB_013.rod
Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
   Part No SW: 3Q0 035 465     HW: 3Q0 035 465
   Component: MIB2_amp_P_VW H60 0440
   Revision: 00000001    Serial number: VWZ8Z1HJD00RUVL Dataset Number: V03935264BQ 0001
   Coding: 1284020001AA0A2AAA0000000000
   ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001018
   ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
   VCID: 6B833AED73071592CA9-803E
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Part No SW: 3Q0 907 338     HW: 3Q0 907 338
   Component: FCM MQB Low   002 0286
   Serial number: 01071710801233
   Coding: 000000060100035207004F01020000000000000000000000000000000000
   Shop #: WSC 05311 000 00001
   ASAM Dataset: EV_MultiModulContiVW48X 001010
   ROD: EV_MultiModulContiVW48X_001.rod
   VCID: 72BD2789542DC45A09F-8026
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo links  H02 0003
   Coding: E02400
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo rechts  H02 0003
   Coding: E02400
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 E    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0041
   Serial number: 170617EFH29274 Dataset Number: V03935256ZD 0001
   Coding: 00351020DE00028200111000
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 42DDB749240D34DA59F-8016
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
   Part No SW: 5NA 035 022 B    HW: 5NA 035 022
   Component: MU-H-LND-EU   H54 1367
   Serial number: A846F0JS020395 Dataset Number: V03935262VW 0001
   Coding: 02840201000000005111110200880A301F0106E4012004009F
   ASAM Dataset: EV_MUHig4CGen2HBAS 001001
   ROD: EV_MUHig4CGen2HBAS_VW37.rod
   VCID: 323DE78994AD845AC9F-8066
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZJT1915518
   Data carrier:
   Subsystem 2 - Part No SW: V03 959 809 PC    HW: -----------
   Component: ECE 2023  --- 0310
   Compact disc data bank:
   Subsystem 3 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1016
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 40000000081630 Dataset Number: V03935262CE 0001
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3431E1916EB98A6ADB3-8060
Address 69: Trailer (J345)       Labels:| 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Component: Anhaenger     H27 0264
   Revision: 8A001003    Serial number: 0446947174 Dataset Number: V03935259HF 0001
   Coding: 0100000202000000
   ASAM Dataset: EV_TrailFunctGener2Hella 001008
   ROD: EV_TrailFunctGener2Hella_VW26.rod
Address 6C: Back-up Cam. (J928)       Labels:* None
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG069231 Dataset Number: ----------
   Coding: 01840201E70F200000214817
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
Address 6D: Trunk Elect. (J605)       Labels:| 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0261
   Revision: --------    Serial number: 31344982200000 Dataset Number: V03935261MK 0001
   Coding: 02A8
   ASAM Dataset: EV_DeckLidCONTIAU736 001014
   ROD: EV_DeckLidCONTIAU736_VW37.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0610
   Serial number: 14061711P11354 Dataset Number: V08154711FU 0001
   Coding: 000408020000040100222347C1508900B4000E30004000
   ASAM Dataset: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D9BD412A0126CA4FB-8014
Address BB: Door Rear Drv (J388)       Labels:* None
   Part No SW: 5Q0 959 595 E    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0041
   Serial number: 070617EF614855 Dataset Number: V03935256XR 0001
   Coding: 000410200100028000001000
   ASAM Dataset: EV_DCURearDriveMAXKLO 006003
   ROD: EV_DCURearDriveMAXCONT.rod
   VCID: 45D7AC55352303E27CD-8010
Address BC: Door Rear Pass (J389)       Labels:* None
   Component: TSG HBFS      020 0041
   Serial number: 070617EF613546 Dataset Number: V03935256NT 0001
   ASAM Dataset: EV_DCURearPasseMAXKLO 006003
   ROD: EV_DCURearPasseMAXCONT.rod
Address CA: Sunroof (J245)       Labels:| 4M0-907-594.clb
   Part No SW: 4M0 907 594 D    HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Dataset Number: V03935218DJ 0001
   Coding: 208040748202
   ASAM Dataset: EV_SunRoofCONTIAU736 004008
   ROD: EV_SunRoofCONTIAU736_004.rod
   VCID: 372BD69D7FCF6172FE1-8062
Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
   Part No SW: 3Q0 907 590 E    HW: 3Q0 907 590
   Revision: --------
   Coding: 14C002
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001007
   ROD: EV_RearRadarS2BoschVW48X_VW37.rod
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
   ROD: EV_LEDModLeftMELCOAU736_VW37.rod
   VCID: 16753B191805787AC57-8042
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H09 0003
   ASAM Dataset: EV_LEDModRightMELCOAU736 001004
End----(Elapsed Time: 02:51, VBatt start/end: 11.3V/11.3V. VIgn 11.3V)-----
Source for data: https://mibsolution.one/#/1
Flashed with ODIS-E
K&N filter 33-3005 performance air filter
One 3G0845011AB please :mrgreen: :lol:
Passat B8 windshield "full option" :lol:
- Heated
- Climate glass
- Acoustical
- Rain/light sensor
- A5 camera
There's the heated windscreen going in. Kudo's if you can guess who's on the pic
More semi-related pics: https://imgur.com/a/cB6JKQ3
Alltrack skidplate
After installing the steel oil pan here, I also installed the Kevlar alltrack skid plate to protect the bottom of the car.
Kevlar lower plate:
For my car I need 3Q0825901B, with slot for cooling DSG
Installation was okay, there are two bracket attached to the front cross member
Through the holes here...
Finally, make sure your assistant is more focussed on making charming pictures than helping you out, and you're all good
Parts 6, 8, 9, 10
Any car will have 7x number 7 from factory for the OEM splash panel.
More pics: https://imgur.com/a/KBPpcNV
