Retrofit park pilot 8k problem
Post Instructions on DIY modifications here - use all information with caution!
Homer51
Drives: Polo 6C
Post by Homer51 »
Hello,
I retrofited my park pilot 4k to 8k, oem, except for the front radars that i bought on ali.
I coded all, but i 've got a problem, when engine is on, front radars beep continually, when i stop the engine with contact on it's ok.
I don't understand why, front radars are painted, Polo 6c got abs and esc and i installed the pdc button.
Any idea ? coding seems to be ok. Other, my wiring come from passenger hole, so the the left and right sensor are inverted on OPS, is it possible to swap it by coding ?
Thanks !
radar not ok -.jpg (247.79 KiB) Viewed 15728 times
radar ok -.jpg (249.05 KiB) Viewed 15728 times
Re: Retrofit park pilot 8k problem
No you can't swap left and right but perhaps you can switch the cables either in the module or in the coupling point to the rear bumper.
Is your kit OEM or ali OEM?
Homer51
Drives: Polo 6C
Post by Homer51 »
Oem kit from carsystem, it.s a good idea for coupling point from rear bumper, must found diagram.
Other an idea about my problem ?
Code 1.jpg (316.08 KiB) Viewed 15659 times
Code 2.jpg (324.03 KiB) Viewed 15659 times
Code 3.jpg (97.81 KiB) Viewed 15660 times
Homer51
Drives: Polo 6C
Post by Homer51 »
Hello,
Thanks ! I will have a look
Homer51
Drives: Polo 6C
Post by Homer51 »
I fix my problem with new originals sensors.
On carplay, when pdc is on, the screen become black, do you have same thing ? Or i need a new coding ?
On radio or gps no black screen.
