Boot Unlocking
Johntheo1
- Drives: 2018 MK10 AW1
Boot Unlocking
Can the boot unlocking function with the key fob be disabled or if not, the automatic locking of the boot when closed, disabled?.
- Maarten
Re: Boot Unlocking
Maybe in the open & close section of the radio menu?
1 door opening
1 door opening
Johntheo1
Re: Boot Unlocking
No good I'm afraid. Might be able to do something with VCDS, will have a browse through it.
grazuncle2
Re: Boot Unlocking
I seem to remember an app for this with OBDEleven
so probably with that (on or off) with adaptation.
curious why you want to disable it.. just curious or I'm getting this wrong.. LOL won't be the first time
Johntheo1
Re: Boot Unlocking
Because its so easy to drop the keys into the boot if loading up with luggage/shopping or your? golf clubs, you then close the boot lid with your keys locked safely inside the boot, its happened numerous times to friends of mine on other makes of cars.
grazuncle2
Re: Boot Unlocking
Makes sense now
Mine boot doesn't lock anything unless you press the lock button on the fob
Johntheo1
Re: Boot Unlocking
Just to be clear, my key fob has 3 buttons "Lock" "boot Lid" (picture) and "unlock". If you unlock everything with the "unlock" then everything stays unlocked after opening/closing, including the boot lid.
If everything is locked and you press the "boot Lid" unlock button then the boot lid unlocks but if you then open it and close it again then it self locks, I'm fairly sure most other VWs do the same but mybe wrong.
Cant acces any controller with my HEX-V2 VCDS release 23.3.1 in "Select Auto Mode", all the controllers just time out, everything else is fine.
grazuncle2
Re: Boot Unlocking
I see.
I suppose if don't use the boot unlock.. ever..
I can see why this could be a problem for boot only if using that method.
Re: Boot Unlocking
With the 3 button key, you are getting "security with convenience", I'd suggest that if you want to carry out this change, that you either search out a 2 button key or physically modify your 3 button key to remove the "with convenience" feature and so retain "security".
grazuncle2
Re: Boot Unlocking
Found this page.. It is 9N but may be a clue
http://wiki.ross-tech.com/wiki/index.ph ... lectronics
Scroll down to +00002 and Trunk Lid Remote Unlocking is down as installed
Wonder if you can change it to Not Installed ?
- Maarten
Re: Boot Unlocking
AW works in longcoding with bits and bytes.
9N works different, you add options in the coding
grazuncle2
Re: Boot Unlocking
Still learning.. LOL
grazuncle2
Re: Boot Unlocking
Hope..
Saw this line is a vwaudi site for an R32.. Might be a younger model then 9n.. LOL
Interesting read https://www.vwaudiforum.co.uk/forum/sho ... -a-new-CCM
Quote
i messed about a bit with the coding, switching rear lid functions off and back on but made no difference
So it may be possible to turn off functions?
Quote
Johntheo1
Re: Boot Unlocking
Thanks for all replies.
I feel I could do somthing if I could gain access to this but all the selections just time out after 30 secs with message "controller not responding", excuse quality of photo.
- VCDS Select Control Mode Photo.jpg (2.55 MiB) Viewed 4005 times
grazuncle2
Re: Boot Unlocking
Strange..
You'd think that if the remote does open the boot that the module is communicating properly
