Amarok Oem Bixenon retrofit
peter222
Drives: amarok 2012
Re: Amarok Oem Bixenon retrofit
Post by peter222 »
Good day . coding done. mainly the lights and fog lights do not work. I connected the fog lights according to the forum Static Cornering Lights. Retrofit. (Amarok 8K0, 8K1, single cab)
Remove and isolate T17/8 light switch connector original wire (white/yellow). Remove SC60 fuse. 20Amp
Install new 0.5mm2 wire from T17/8 light switch connector to T73a/7 BCM black connector.
Install new 1.5mm2 wire from SC50 output to T73b/11 BCM white connector. New 15Amp fuse.
Left
Remove and isolate T2/1 foglight connector original wire.
Install new 1.5mm2 wire from T73b/9 BCM white connector to T2/1 foglight connector.
Right
Install new 1.5mm2 wire from T73b/10 BCM white connector to T2/1 foglight connector.
. the indicator light for a burnt-out bulb is on.the cruise control does not work. how to continue ? well thank you
VIN: WV1ZZZ2HZCA056596 License Plate: TT
Mileage: 145500km-90409mi Repair Order:
Chassis Type: 2H-VN81 (6N0)
Scan: 01 03 04 08 09 15 17 19 22 25 32 56 61 69
VIN: WV1ZZZ2HZCA056596 Mileage: 145500km-90409miles
22-AWD -- Status: OK 0000
32-Differential Locks -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CDCA) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 FA HW: 03L 907 309 K
Component: R4 2,0L EDC H43 9745
Revision: 26H43--- Serial number: 00000000000000 CVN: C615361C
Coding: 01194012232600080000
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_ECM20BTD01103L906019FA 002005
ROD: EV_ECM20BTD01103L906019FA_002.rod
VCID: 6FED66BBB69D05F1A8-803A
VINID: 9E606AAAA098A9344014614918770CDBE1
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels: 2H0-907-37x-ESP.clb
Part No SW: 2H0 907 379 J HW: 2H0 907 379 D
Component: ESP MK25A XT H44 0109
Revision: 00H44001
Coding: C07324B69199039B24A789AC6F5690
Shop #: WSC 07456 790 49164
VCID: 377D9EDB864D8D31B0-8062
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 2H0 907 040 D HW: 2H0 907 040 D
Component: ClimatronicT5 H11 0304
Revision: 00001003
Coding: 0000000002
Shop #: WSC 07456 790 50316
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis.rod
VCID: 224B5F8F35CFF89977-8076
2 Faults Found:
13701936 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 7
Reset counter: 47
Mileage: 145509 km
Date: 2023.09.19
Time: 06:26:39
9481988 - Air Quality Sensor
B10AF 04 [008] - Internal System Fault
Fault Priority: 3
Fault Frequency: 3
Reset counter: 47
Mileage: 145509 km
Date: 2023.09.19
Time: 06:26:39
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 B HW: 7H0 937 090
Component: BCM PQ25 Max4 H74 0712
Revision: B9074001 Serial number: 0571 150133718
Coding: 3C0002380C01000000300C912C4B84D41080654E60003040300000020000
Shop #: WSC 00001 001 00001
VCID: 2D51BCB3741137E1DA-8078
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3321
Coding: 100000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3321
Coding: 100000
Subsystem 3 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3321
Coding: 100000
Subsystem 4 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3321
Coding: 100000
6 Faults Found:
00901 - Back-Up Lamps
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 7
Mileage: 145509 km
Time Indication: 0
Date: 2018.02.09
Time: 17:40:02
02745 - Bulb for Daytime Running Light; Left
010 - Open or Short to Plus - Intermittent
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 7
Reset counter: 47
Mileage: 145509 km
Time Indication: 0
Date: 2018.02.09
Time: 17:32:05
02746 - Bulb for Daytime Running Light; Right
Fault Priority: 3
Fault Frequency: 7
Reset counter: 47
Mileage: 145509 km
Time Indication: 0
Date: 2018.02.09
Time: 17:32:05
01495 - Bulb for High-Beams; Left (M30)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 7
Mileage: 145509 km
Time Indication: 0
Date: 2018.02.09
Time: 17:36:35
01499 - Bulb for High-Beams; Right (M32)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 7
Mileage: 145509 km
Time Indication: 0
Date: 2018.02.09
Time: 17:36:35
01504 - Bulb for License-Plate Light (X)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 7
Mileage: 145509 km
Time Indication: 0
Date: 2018.02.09
Time: 17:31:60
Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
Component: VW10Airbag00B H06 0013
Revision: -------- Serial number: 003HN006UJP.
Coding: 000000000000000000000000000000003042
Shop #: WSC 07446 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3365AACB9A3561118C-8066
Serial number: 3495RRB40610TGJKB0T6
Serial number: 3505RRB40610TGJKCGH3
Serial number: 3555YRB40650P4N040VK
Crash sensor for front airbag: front passenger side:
Serial number: 3565YRB405R0UT987H4G
Part No SW: 2H0 920 863 B HW: 2H0 920 863 B
Component: KOMBI H02 0505
Coding: 150800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 285F4DA753F312C929-807C
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H74 0712
Revision: B9074001
VCID: 70EF65C7A3A31A09B1-8024
Address 22: AWD Labels: None
Part No SW: 2H0 927 755 B HW: 2H0 927 755 B
Component: SG offroad VTG 0153
Revision: 00H06000 Serial number: T1IYC36211RNKZ
Coding: 0000013
Shop #: WSC 131071 1023 2097151
VCID: 2F6DA6BBBE1D45F1E8-807A
Component: IMMO H02 0505
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADB77AF8D7FE0D9FF-803E
Address 32: Differential Locks (J647) Labels:* 2H0-927-771.clb
Part No SW: 2H0 927 771 A HW: 2H0 927 771
Component: Quersperre H04 0017
Revision: 11001001 Serial number: 4DG 21.07.11 00
Coding: 000001
ASAM Dataset: EV_QuersUDSAAMVN817 A01606
ROD: EV_QuersUDSAAMVN817.rod
VCID: 2C57B1B7470B3EE9CD-8078
Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
Component: RCD310 EU H03 5004
Revision: -----04S Serial number: VWZ4Z2M1135004
Coding: 00000400020016
VCID: 72EB6FCFADAF281947-8026
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7H0 907 534 HW: 7H0 937 090
Component: Batt.regelung H74 0712
Coding: 00030A5A
Shop #: WSC 73430 790 00114
VCID: 6BD572AB8A85F9D184-803E
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00008030114049
Coding: 0100000100000000
VCID: 306FA5C763235A09F1-8064
End-------------------------(Elapsed Time: 02:51)--------------------------
Again... you have to disable address 61.
Recode the GW. Why is it now at 000000?
If you had planned to install front fog lights, why didn't you mention it?
New BCM coding:
(BCM Max + Bixenon-Amarok + Front Fog lights + SCLs, without Auto lights)
3C0002380C01000000300CD16C4B84D41080654F60843040300000020000
The license plate lights need a new electrical installation.
In the diagrams compare your 7L3 model with the 7L6 model of your model year. With BCM Max should be like in 7L6.
I don't know why your high/low beam lights don't work.
Review the diagrams in the same way I indicated previously, 7L3 vs 7L6. With BCM Max should be like in 7L6.
peter222
Drives: amarok 2012
Post by peter222 »
remotes work. low beam lights (mainly lights) do not work, daytime lights are on together with side lights. if I turn on the marker lights, only the interior lighting is on. I mentioned the fog lights above :-)
Please can you tell me the post where you mentioned that you were going to install the front fog lights? The only post where you mention it is 'after' the first BCM coding I did for you. I do this altuistically, but regardless of this, I don't like doing the same thing twice.🤷‍♂️
peter222
Drives: amarok 2012
Post by peter222 »
sorry 😬. I'm sorry. thank you for your help . I will come home from work and immediately try coding. I will send a scan
In that case, I'm going to help you a little with your electrical installation.
Please check if there is an 'original wire' at position T17/11 of the light switch connector.
If it does not exist for your Amarok (MY 'C', 7L3), you must install it.
From T17/11 to T73b/52.
It is the '56' signal, which informs the BCM that you have the lights ON at the light switch.
Note:
The image shown in this post belongs to the images you posted previously, in which it is not possible to see (even by modifying the image) if this wire is installed.
peter222
Drives: amarok 2012
Post by peter222 »
Good day . the cable from the light switch to the bcm is connected. dipped beam lights work. main beam lights work, direction lights work.
the fog light only works for me. daytime lighting is also on with the parking light if the light switch is at 0. if I turn on the parking lights, only the lighting in the car turns on and the parking lights do not work. it says burned out bulbs. what to do next? thank you
Scan: 01 03 04 08 09 15 17 19 22 25 32 56 69
Coding: 01194012233600080000
Revision: 00H44001
Revision: 00001003
Coding: 0000000002
2 Faults Found:
B10AF 04 [009] - Internal System Fault
Fault Priority: 3
Fault Frequency: 4
Reset counter: 7
Mileage: 145509 km
Date: 2023.09.20
Time: 18:58:10
9482025 - Air Quality Sensor
B10AF 29 [008] - Signal Implausible
Fault Priority: 3
Fault Frequency: 1
Reset counter: 47
Mileage: 145509 km
Date: 2023.09.20
Time: 16:12:06
Coding: 3C0002380C01000000300CD16C4B84D41080654F60843040300000020000
Coding: 100000
Coding: 100000
Coding: 100000
Coding: 100000
7 Faults Found:
03429 - Activation of Right Adaptive Light
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 7
Mileage: 145509 km
Time Indication: 0
Date: 2018.02.10
Time: 16:14:15
Fault Priority: 3
Fault Frequency: 1
Reset counter: 7
Mileage: 145509 km
Time Indication: 0
Date: 2018.02.10
Time: 16:17:26
Fault Priority: 3
Fault Frequency: 2
Reset counter: 47
Mileage: 145509 km
Time Indication: 0
Date: 2018.02.10
Time: 16:14:15
Fault Priority: 3
Fault Frequency: 2
Reset counter: 47
Mileage: 145509 km
Time Indication: 0
Date: 2018.02.10
Time: 16:14:15
Fault Priority: 3
Fault Frequency: 1
Reset counter: 7
Mileage: 145509 km
Time Indication: 0
Date: 2018.02.10
Time: 16:14:15
Fault Priority: 3
Fault Frequency: 1
Reset counter: 7
Mileage: 145509 km
Time Indication: 0
Date: 2018.02.10
Time: 16:14:15
Fault Priority: 3
Fault Frequency: 1
Reset counter: 7
Mileage: 145509 km
Time Indication: 0
Date: 2018.02.10
Time: 16:14:15
Coding: 150800
Revision: B9074001
Coding: 742200
Coding: 0000013
Serial number:
Coding: 000001
End-------------------------(Elapsed Time: 02:44)--------------------------
Once we have solved the main problem, Low/Dipped beams ...
The rest of the problems are due to the same circumstance, that is, they are due to the fact that you have not studied the diagrams enough to carry out this retrofitting. I remind you that I told you not to do these installations if you did not know how to interpret the diagrams.
Again, I'll have to do the work for you ...
Parking/side lights:
'Assuming' the two new wires for the 'front parking lights' are installed correctly, and due to your comments, you will need to reprogram your used BCM Max with the correct settings/parameters/values for Bixenon (front POS parking lights):
viewtopic.php?p=598453#p598453
Value = 28.
License plate light:
New wire 0.5 from T73b/7 to the lamp conector.
Remove and perfectly 'insulate' the original wire from the lamp connector.
Reversing lights (Back-up lamps):
New wire 0.5 from T73b/12 to the reversing light conector. ... (edited, I wrote T73b/48 and it is not correct, it must be T73b/12)
Remove and perfectly 'insulate' the original wire from the connector.
New and last BCM coding: (definitive)
3C0002380C01000000300C316C4B84D40F80654E60843040300000020000
peter222
Drives: amarok 2012
Post by peter222 »
sorry, I didn't notice this post. I will change it tomorrow via vcp. what could be the problem that it is writing to me
03429 - Activation of the right adaptive light
011 -
Open circuit freezing:
Fault status: 01101011
Fault priority: 3
Frequency of failure: 1
Reset counter: 7
Mileage: 145509 km
Time indication: 0
Date: 2018.02.10
Time: 16:14:15
00901 - Backup lamps
Shortened to 010 -
Unbroken Frame:
Fault status: 01101010
Fault priority: 3
Frequency of failures: 1
Reset counter: 7
Mileage: 145509 km
Time indication: 0
Date: 2018.02.10
Time: 16:17:26
02745 - Bulb for daytime running lights; On the left
010 - Open or short to plus - Intermittent
freeze frame:
Fault status: 00101010
Fault priority: 3
Frequency of failure: 2
Reset counter: 47
Mileage: 145509 km
Time indication: 0
Date: 2018.042.10
Time: 156
:27 - Bulb for daytime running; On the right
010 – open or short to plus – intermittent
freeze frame:
Fault priority: 3
Reset counter: 47
Mileage: 145509 km
Time indication: 0
Date: 2018.02.10
Time: 16:14:15
01495 - Bulb for main beam; Left (M30)
010 - Open or short to Plus
Fault priority: 3
Counter reset: 7
Mileage: 145509 km
Time indication: 0
Date: 2018.02.10
Time: 16:14:15
01499 - Bulb for main beam; Right (M32)
freeze frame:
Fault priority: 3
Reset counter: 7
Mileage: 145509 km
Time indication: 0
Date: 2018.02.10
First, copy and paste the latest BCM coding, go to Autoscan_click on GW installation list_click on Clear All DTCs_do a new Autoscan. Please post it here.
03429 - Activation of the right adaptive light.
This is the static cornering light in front fog light. SCL.
- Check installation, bulb.
- IMP: do not have a low consumption LED bulb installed.
00901 - Backup lamps.
01504 - Bulb for License-Plate Light (X).
- Do what was indicated in the previous post.
By design (dataset), the BCM Max only understands an electrical installation as indicated in the previous post.
It is likely that these lights are working correctly due to the old electrical installation, but that old electrical installation is not correct for the BCM 'Max' diagnosis.
02745 - Bulb for daytime running lights; On the left.
02746 - Bulb for Daytime Running Light; On the Right.
- The headlight LED module acts as DRL (maximum brightness, LS=0) and Parking/side lights (less brightness, LS=POS or LOW). The BCM detects an inadequate and 'intermittent' operation in one of the two functions of the LED module. We will see what happens when you reprogram your BCM Max with the VCP.
01495 - Bulb for High-Beams; Left (M30).
01499 - Bulb for High-Beams; Right (M32).
- These bulbs don't really exist, they are the shutters/discharge lamps (T73a/62). We will see what happens with the latest BCM coding.
Once the electrical installation is correct and the BCM Max is reprogrammed, no faults will be reported in the Autoscan or a warning light on the instrument cluster. If you want, report with a last Autoscan in these last conditions so that other users can benefit from your work.
peter222
Drives: amarok 2012
Post by peter222 »
Good day . everything adjusted. the lights work. the problem is that the remote light works but displays an error.
on the last coding, it says the error of the reversing light.additional lights are installed there.
on the previous coding, it says the reversing light, but the fault does not light up. it can be like this
this coding may be, I need to solve the remote lights, it says a fault, an error lights up.can it be changed by coding? Thanks for help :D
Fault Priority: 3
Fault Frequency: 1
Reset counter: 7
Mileage: 145509 km
Time Indication: 0
Date: 2018.02.10
Time: 16:14:15
Fault Priority: 3
Fault Frequency: 1
Reset counter: 7
Mileage: 145509 km
Time Indication: 0
Date: 2018.02.10
Time: 16:14:15
peter222
Drives: amarok 2012
Post by peter222 »
can the control of the bulbs on the fog lights be turned off? thank you
Some magic is possible, but miracles do not exist.😁
The coding tells the BCM how it should work, but the defined parameters/values ('data set') will work as intended, not as unintended.
It will depend on the factory predefined parameters/values for your second-hand BCM Max that were defined for the donor car of this BCM.
There are many BCM Max in which these factory values are different. Many!
1
Trying to understand what you mean by "remote lights", we realize that you are using the Slovak to English translator. (diaľkové svetlá)
That is, we assume that you are referring to the high beams.
'Assuming' the new wire reaching T73a/62 is installed correctly, we will 'try' to do something in the BCM coding, ... see Coding at the end of this post.
2
When were you planning to tell us that you have "additional" reversing lights installed?... What should we assume?... You have two reversing lights and no rear fog light (possible from the factory)? or did you install those additional reversing lights later?
... you could show us a photo of those additional reversing lights in case other users think this is a brilliant idea for them.
3
On the other hand, we imagine that you want to avoid the diagnosis of static cornering lights because you have installed low-consumption LED bulbs for the front fog lights, right?
If LED bulbs are essential for you in the front fog lights, it would be best to install LED bulbs with a small additional control unit that, due to consumption, would avoid the fault in the diagnosis. e.g viewtopic.php?p=555624#p555624
Note: the diagnosis is not the same on a Golf (mqb) as on an Amarok (pq25).
BCM Coding/parameterization (VCDS/VCP).
The 'definitive' BCM coding I did is the correct one, but we will 'try' a new BCM coding based on your 'particular circumstances'.
3C0002380C01000000300C616C4B84D49680656F60843040300000020000
If you don't get the results you need with this BCM coding, you can modify/edit the values/parameters with VCP in the same way you did for the parking lights (POS). Take a look at all the values and then act accordingly. Remember to make a backup of the original values before you start modifying values ​​crazily.🤭
peter222
Drives: amarok 2012
Post by peter222 »
well thank you . everything is fine with the previous coding, except for the high beam malfunctions. I know there are no light bulbs, but an aperture. but the managing director thinks that there are light bulbs. that's why I thought if we couldn't solve it by coding 😬 I'll try coding today, thank you
yes, turning off the bulb control for the LED fog lights :-) . I disconnected the reverse lights when installing the xenon headlights so that it wouldn't be a problem. I will send a photo
peter222
Drives: amarok 2012
Post by peter222 »
after the last coded everything works. does not display a fault on the dashboard. but in the 09 address, there are defects regarding the high beams.
VIN: WV1ZZZ2HZCA056596 Mileage: 145520km-90421miles
25-Immobilizer -- Status: Malfunction 0010
Readiness: 0 0 0 0 0
Revision: 00H44001
Revision: 00001003
Coding: 0000000002
1 Fault Found:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 10
Mileage: 145512 km
Date: 2023.09.22
Time: 04:30:57
Coding: 3C0002380C01000000300C616C4B84D49680656F60843040300000020000
Coding: 100000
Coding: 100000
Coding: 100000
Coding: 100000
3 Faults Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 10
Mileage: 145528 km
Time Indication: 0
Date: 2018.02.12
Time: 23:41:01
Fault Priority: 3
Fault Frequency: 1
Reset counter: 10
Mileage: 145528 km
Time Indication: 0
Date: 2018.02.12
Time: 23:41:04
Fault Priority: 3
Fault Frequency: 1
Reset counter: 10
Mileage: 145528 km
Time Indication: 0
Date: 2018.02.12
Time: 23:41:04
Coding: 150800
Revision: B9074001
Coding: 742200
Coding: 0000013
Serial number:
1 Fault Found:
9456681 - Key
B104C 29 [008] - Implausible Signal
Fault Priority: 6
Fault Frequency: 1
Mileage: 145528 km
Date: 2023.09.22
Time: 07:15:36
Coding: 000001
