Hi there,
I noticed on my parents octavia that the rpm rise to 1k when lifting the clutch a little, even if the throttle is not used. I figured this is done to make it easier to get going. When I got into my 6R I saw it does not do that. I read somewhere that some polos do have this feature. Can it be enabled with vcds or something similar or is it just a newer feature that is not available on the 6R?
Thanks for the help.
RPM increase when lifting the clutch in a 6R
- mirceaculita
- Drives: 6R 1.2TDI 75hp
- Platinum Member
Re: RPM increase when lifting the clutch in a 6R
mine 6r has it
It's indeed a helpful feature, and by design. I'm not aware of VCDS being able to do it though. I've only seen it in the MQB TSI engines, but I've hardly driven any MQB TDI engines.
I've never seen it on 6R, Amer6R is the first I hear about it, so that's nice to know![Smile :)](./images/smilies/icon_smile.gif)
- Platinum Member
im pretty sure it has anti stall. You release the clutch a bit the revs go up a little bit. And its pretty annoying in slow bumper to bumper traffic when you need to slow down as it's kicking in.
Maybe its not as aggressive as in newer models.
Anti-stall and fuel saving. Keeps the idle speed very low, just picks it up when ready to go. I kinda like it on my CJZD 6C as I can get up my driveway without giving gas.
But I do wonder if this is why my one bogs down so often when pulling away. I give some revs, release clutch, start moving and revs just drop to near stall and it bogs. Maybe I'll never get used to hydraulic clutch. A miss my cable clutch feel.
For my 6R 1.2 TSI CBZC 5-MT (2013) w/o Start/Stop with 125hp ECU tuning 🏎, the rpms only drops from 800 to 625 approx (idle, 0.6l/100km) when the vehicle is completely stopped and in Neutral, that is, if you have the clutch depressed and the vehicle is moving due to inertia, the rpms will be 800 (approx). I like it.
- Platinum Member
Very similar in my tdi, (800 idle 0.2l) when you let of the clutch slightly to get moving rpm 900-950ciclo wrote: ↑Fri Sep 22, 2023 5:31 pm For my 6R 1.2 TSI CBZC 5-MT (2013) w/o Start/Stop with 125hp ECU tuning 🏎, the rpms only drops from 800 to 625 approx (idle, 0.6l/100km) when the vehicle is completely stopped and in Neutral, that is, if you have the clutch depressed and the vehicle is moving due to inertia, the rpms will be 800 (approx). I like it.
I've been watching videos of newer cars, nah its not even close as aggressive. Those basically will raise rpms even more if needed to not bog down.
I think this more aggressive anti stall can be useful when you need that like crawl speed, like steep hill but you need low speed if you need control for precise manoeuvres not to ride the clutch. Because it doesn't have enough displacement to overcome the terrain.
I wish they made a 2.0 tdi, i think it would be ideal....
- mirceaculita
In my 1.2tdi the rpms hold at just under 1000 if the car is moving and in neutral/clutch pressed, but the second it stops it drops to 800. When stopped and releasing the clutch nothing happens. Sadreactsonly since it would pretty nice to have on this little engine.
