POLO 6R. HEATED SEATS. OEM.
Re: POLO 6R. HEATED SEATS. OEM.
I think the light should light up briefly when you press the button, and then switch off because it doesn't detect resistance
The light didnt show up :/
I ordered a 2.4 ohm resistor.
I give it a try tomorrow
I tryed with a 2.2 ohm and 2.4 resistor. (on both sides)
Nothing happend /changed ...
the seat mats have not yet arrived :/
VIN : ---
VAG no. : 6R0937087R
Name : J519 BCM PQ25 H+4
Coding : 1E 7A8829E888610100002008F06E4B9CD80080420F60840000200000000000
SW version : 0424
Slave [1] :6R0959801AJ J386__TSG_FT Coding: 020000
Slave [2] :6R0959802AQ J387__TSG_BT Coding: 020000
Coding : 7A8829E888610100002008F06E4B9CD80080420F60840000200000000000
Did i miss something ?
the channel 63 -> not available
Before the engine starts - 12v on the plugs
br Zun
VIN : ---
SW version : 0424
br Zun
are you sure your heating module is working and powered correctly?
your coding looks okay to me
The heating module is "used"
When i pull the plug from the module -> 0V
Or should i wait till the seat mats coming ? :/
To the resolution:
Kufatec has forgotten a cable (no. 17 multi-switch) in the cable harness.
The seat heating now works
d'oh... kufatec
My cable set had numbers on the cables.
I have pinned the cables to the multiswitch.
if you have a more specific question - just ask.
br
br
X
T73 / B34 -> "Ausgang Signal Beleuchtung - Schalter und Instrumente" -> "Output signal lighting - switches and instruments"
This should already be present in the multiswitch and does not need to be connected additionally.
T73 / A36 -> "Signal Abschaltung Sitzheizung" -> "Seat heating switch-off signal"
Optional! You need VCDS to program this. If the engine is not running - your seat heating is not working.
if I remember correctly ... I used switch plus from the relay as the incoming signal for the relay in the multiswitch.
T20c/17 is the "power supply" for T20c/18 T20c/19
And T20c/18 goes to T16j/6
And T20c/19 goes to T16j/12
And if you also have the wrong Kufatec wiring harness ... There is no 4 for the seat heating
only 20 / 19 / 18 / 17 // 6 (blue / grey // should already be occupied - Backlighting) / 8 ( ) / 9 / 10
OK thank you. So I have to put a plus for wire no. 17? preferably from where?
i took the switched plus from the seat heating relay (the small black box)
