Aftermarket Steering Pump code HELP!!!
Hi Guys new to the forum I Need HELP please
I have a Polo 63 plate 3 door 1.2 Match, the battery started failing and then the steering pump failed, so bought a new part from AUTODOC, I couldn’t get the VCDS code from the original one and now I can’t get the new one working, I even changed the steering sensor with no luck, any ideas people, please help
Re: Aftermarket Steering Pump code HELP!!!
if possible, share an autoscan please
I will get one tomorrow what do you need to see
if possible, just post the whole scan please
Just added screenshots
- Scan
- 0731ec21-b2e1-40a2-a97a-353e14e8e751.jpeg (144.27 KiB) Viewed 7461 times
change the first digits of the pump coding from 112 to 101 or vice versa please and see what happens
The most common/normal coding for 6R is '11250'.
This is my current coding,
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11260
Shop #: WSC 00788
VCID: 2F3BEEC0BE5AA712A61-807A
In addition to being an absolute pleasure to which I have already become accustomed, it gives a new fun character to driving in corners, curves and other circumstances when avoiding obstacles... I only recommend it for drivers with magical hands.
edit
https://youtu.be/ByeOpqMcfcY?t=322
Thank you both but still no luck, any other suggestions
Could you please show us a link to the steering pump you bought at AUTODOC?
What part/reference number did you use to purchase the new steering pump?
edit
Watching the video in its entirety it appears that sandy anderson is having trouble coding his steering pump, and has to reset the diagnostic tool to be able to code again.
The diagnostic tool that sandy uses is similar to the one you show here, please rewatch the entire video and try to code your steering pump again according to the video.
With VCDS it is much easier.
edit
This is the pump I ordered
- IMG_0150.png (197.39 KiB) Viewed 7127 times
have tried following the video with our launch x431 scanner and the latest snap on Apolo scanner . The problem the codes doesn't match
what is the current coding?
The pump is suitable for your 6R, I leave you the diagram here in case you want to check the fuses.
SA4 is on top of the battery.
SB26 under the steering wheel.
So still no joy I have attached some more pictures of faults etc, we even replaced the steering sensor but that doesn’t seem to be able to see the pump to communicate, I have tried all the codes in this post any more codes would be appreciated and does anyone know if there are any specialist VW mechanics around Croydon, Surrey, UK, CR5 post code, no decent reviews of main dealer mechanics
- IMG_0162.jpeg (2.57 MiB) Viewed 6935 times
- IMG_0164.jpeg (4.42 MiB) Viewed 6936 times
And these
- IMG_0163.jpeg (2.11 MiB) Viewed 6934 times
- IMG_0161.jpeg (4.13 MiB) Viewed 6934 times
