Dashboard swap! Seat Toledo Instrument Cluster on Cross Polo 6R
wasiesto
Drives: 6R
Re: Dashboard swap! Seat Toledo Instrument Cluster on Cross Polo 6R
Post by wasiesto »
hello everyone,
what file do you use to update the cluster?
I can't find the FRF file with the 6R0920870 firmware
til3tsio
Drives: Seat Toledo KG
Post by til3tsio »
You can use other pq25 files and edit the eeprom.
What's the part number that you have now and why do you want to update?
sejuani
Drives: POLO 6R
Post by sejuani »
til3tsio wrote: Wed Aug 24, 2022 5:05 pm I need help from the masters !
long story sort ....
I updated my toledo's 6JA SW:711 cluster with amarok 2H0 SW:729.
The problem is that the mfsw’s right wheel that used to control up and down on MFD screen does not work, it works only in the phone menu.
All other buttons work ok, everything else seems ok, also tried 7E0 SW:720, also tried restoring backed up original SEAT eeprom with no luck.
SEAT and Skoda use wheels for volume and mfd up/down and seems that something is missing there, but why work only on one menu is a mystery. Also came to the conclusion that 6JA 711 firmware was in clusters that were produced long after the VW x7xx firmware, but together with the x8xx.
As I do not have access to my original frf file as it was not available on Erwin disks, using newer VW files x8xx or 100x seems a promising solution. There are references that people used these files but they are kept secret so I cannot find them.
I am open to suggestions / directions of any kind.
Hi, til3tsio, do you have any tips for the final version FL on your 6JA920840 IC?
I have a 6JA IC (SW: 6JA 920 940 C, HW: 6JA 920 940 C, H05 0709), and I hope it can be updated to 0805 for RTA. Thanks!
I saw that you said the MFSW’s right wheel does not work on 2H0 SW:729.
til3tsio
Post by til3tsio »
It did not work in my case but only because I have a Seat steering wheel.
Seat steering wheels have scroling wheels insted of the "legacy" up/down buttons .
I had to update to 1xxx firmware to fix this issue.
from erwin disks seems that frf software on 7xx do not support RTA , I have tested 5C6 710, 6JA 711, 7E0 720, 2H0 725
I have also tested 5C6 818 and it had RTA
2H6 1120 has RTA but I was not able to find out the corect wheel wheel circumference for my car.
there is also a "custom" 2H0 1009 obx file available that supports RTA.
if you go over 1xxx you are going to lose the green side assist led functionality
if you go to 818 and over something is changing on the security algorithm and you can not downgrade again to 7xx via obd and also you can not access it throught obd using cloned tools like fvdi 2014.
and of course any firmware that you try needs eeprom editing to adjust it to your cluster layout
sejuani
Drives: POLO 6R
Post by sejuani »
til3tsio wrote: Sat Sep 28, 2024 6:32 am It did not work in my case but only because I have a Seat steering wheel.
Thanks for replying. 🙏
Sounds great. I’m excited to try 5C6 818 if I can find the FRF.
The side assist LED is fine; I didn’t add it to my IC.
I’ll back up my EEPROM before doing the update. By the way, is it necessary to back up the immobilizer to prevent any anti-theft errors?
til3tsio
Post by til3tsio »
There is always risk on updating software on all the modules.
I haven't faced any issues with immobilizer, but I definitely had to do eeprom editing.
In what car you are going to install it , a polo ?
What is it a tsi or a tdi ?
I can help with the file.
sejuani
Drives: POLO 6R
Post by sejuani »
til3tsio wrote: Sun Sep 29, 2024 8:17 am There is always risk on updating software on all the modules.
Thanks for your help.
I have a POLO with a CLSA engine, and the following are the results from my VCDS scan:
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CLSA)       Labels:
   Part No SW: 03C 906 014 FR    HW: 03C 906 014
   Component: CLSA-MM7GV-G  H02 8635
   Revision: --H02---    Serial number:
   Coding: 001A0014022400000000
   Shop #: WSC 12345 123 08192
   VCID: 72E1870AAEAF28DFAA-5178
Readiness: 0010 0001
Address 02: Auto Trans        Labels: 09G-927-750.clb
   Part No SW: 09G 927 750 LK    HW: 09G 927 750 LK
   Component: AQ 250 6F           2601
   Revision: 00H98000    Serial number:
   Coding: 0000328
   Shop #: WSC 00000 000 08192
   VCID: 050BCCD64F212F679F-5178
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.lbl
   Part No SW: 6R0 907 379 CB    HW: 6R0 907 379 AS
   Serial number: --------------
   Coding: 61DD2463422603C2861A246E4259C0400809
   Shop #: WSC 00049 770 08192
   VCID: 0005DDC29B030A4FAC-8054
   Serial number: 02081613470700
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF9A33AE1F77CBFDE-802A
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 418318C6D889C347E3-8014
   Part No SW: 6RU 937 087 P    HW: 6RU 937 087
   Component: BCM IM H+4    H41 0444
   Revision: BZ041001    Serial number: 8700 110170564
   Coding: 3AB02FF808F36E00B33800006DAB969000C860FF608E0100220000000A00
   Shop #: WSC 124697 483 00190
   VCID: 6FE78E7EBE9D053745-803A
   Component: RLHS 091221 0  50  0107
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 EC    HW: 6R0 959 801 EC  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  023 2551
   Serial number: 13102851160307203215
   Coding: 640000
   Subsystem 3 - Part No SW: 6R0 959 802 EG    HW: 6R0 959 802 EG  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  023 2551
   Serial number: 13102850160217193348
   Coding: 640000
   Subsystem 4 - Part No: 6RU 951 171
   Component: Sensor, DWA 0  005 0502
   Subsystem 6 - Part No: 6RU 951 171
   Subsystem 7 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Serial number: 0431722560500067AB2B
   Coding: 240000
   Subsystem 8 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
   Component: J388__TSG_HL  022 1552
   Serial number: 13202728170223141457
   Subsystem 9 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
   Component: J389__TSG_HR  022 1552
   Serial number: 13102729170223103338
   Part No SW: 7E0 919 475 L    HW: 56D 919 475
   Component: PARKHILFE 8K  H02 0106
   Revision: --------    Serial number: 35841522901332
   Coding: 308001
   Shop #: WSC 01681 002 104857
   VCID: 3B7F6A2EB265A997B9-806E
   Component: VW10AirbagU0J H10 0020
   Revision: --------    Serial number: 003GW019WCZB
   Coding: 00304A
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 499300E6E8B90B073B-801C
   Part No SW: 6JA 920 940 C    HW: 6JA 920 940 C
   Component: KOMBI         H05 0709
   Coding: 141800
   Shop #: WSC 73430 031 00209
   VCID: 3C7D6932B76BAEAFB0-8068
Address 19: CAN Gateway (J533)       Labels:
   Part No SW: 6RU 909 901     HW: 6RU 937 087
   Component: GW-K-CAN TP20 H41 0444
   Revision: BZ041001
   Coding: 002204
   VCID: 193390A61099BB874B-804C
   Component: IMMO          H05 0709
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD19F6A8D7FE01F12-803E
Address 3C: Lane Change (J1086)       Labels:. 5Q0-907-686.clb
   Component: HRE_Master    H12 0081
   Serial number: 0484698770
   Coding: 03011102
   Shop #: WSC 00046 123 12345
   ROD: no
   VCID: 3D7B6436AC71A7A787-8068
No ASAM Dataset: "EV_HREntryHella" (VW25)
   Part No SW: 1S1 909 144 P    HW: 1S1 909 144 P
   Component: EPS_ECU       H51 1702
   Coding: 0001000101000000
   Shop #: WSC 33930 004 1048576
   ROD: EV_SteerAssisNSK_014.rod
   VCID: 40851DC2DB83CA4FEC-8014
   Component: MIB2-S-R-CN   036 0358
   Revision: -----001    Serial number: VWZ6Z2Q7089808
   Coding: 1E000440040000
   Shop #: WSC 00081 790 00126
   VCID: 46890BDAF1A7E47FD6-8012
My original instruments were 6RF 920 861 D (H02 5006).
After changing to the new cluster, I used "VAG Dash Editor (24c32 & 24c64) V7.3" to edit the EEPROM and adjust it to my cluster layout.
til3tsio
Post by til3tsio »
RTA seems turned off in your scan.
If you turn it on does your abs and the rcd330 support it ?
sejuani
Drives: POLO 6R
Post by sejuani »
til3tsio wrote: Sun Sep 29, 2024 8:41 pm RTA seems turned off in your scan.
These are good tips.
I found that CDRX and Robert (on the T6 forum) mentioned that I need to install a 1K8 PDC module (from 7E0 919 475 L) to activate RTA, along with ABS, an ABS sensor, Discover Media/Composition Media...
Well, maybe I should give up🤣
sejuani
Drives: POLO 6R
Post by sejuani »
Today, I still tried to do something. 😅
First, I updated my PDC module to 7E0 919 475 AA and changed the coding to 30A001 (is this correct?) to enable RTA.
Second, I tried to update my IC to 5C6 818, but it failed (I tried vehicle projects VW25X and VW36X).
I also have 2H6 1120, but I know finding the correct wheel circumference is really annoying. :cry:
til3tsio
Post by til3tsio »
In VCP you have to do an extra step to trick the security algorithm using an older firmware for the firmware to update,
in odis I do not know. Maybe someone here can help.
MrCollayder
Drives: Polo 614 sedan (cczb+dq250 awd+pq35)
Post by MrCollayder »
You can use this service to convert frf to odx. And than manually change SA2 key. Also check "layer-refs"
String <LAYER-REF DOCREF="EV_KombiUDSVDDRM09_A05" DOCTYPE="LAYER" ID-REF="EV_KombiUDSVDDRM09_A05"/> consists A0x. This x MUST be the same as yours.
sejuani
Drives: POLO 6R
Post by sejuani »
MrCollayder wrote: Fri Oct 11, 2024 3:09 pm You can use this service to convert frf to odx. And than manually change SA2 key. Also check "layer-refs"
Thanks for the information.
My original IC is A04(EV_Kombi_UDS_VDD_RM09 A04723), and the "layer-refs" of the 0818 5C6 IC is also A04.
(LAYER-REF DOCREF="EV_KombiUDSVDDRM09_A04" DOCTYPE="LAYER" ID-REF="EV_KombiUDSVDDRM09_A04"/)
It's fine to upload the new FRF to the original IC, but it shows the following error:
Error during update programming; Job runtime: 0:00:05.158; Initial repetitions: 0; Total repetitions: 0; Last value of STmin: 4294967295 µs; unknown Failure - Programming aborted
MrCollayder
sejuani wrote: Sat Oct 12, 2024 9:37 am
Than it's really SA2 key fault. Try copy it from the other sw.
sejuani
Drives: POLO 6R
Post by sejuani »
MrCollayder wrote: Sun Oct 13, 2024 10:40 am
I really appreciate it.
I changed the SA2 key, and everything is good—no errors occurred.
Now I have 5C6 818 and RTA menu.
However, I have a warning for the brake fluid level on the IC.
I'll check 0x2CB later to see what's going on. Thank you again!
