Hello Ciclo the Lightbringer,
I recently bought Multivan T5 with manual light switch and it is a nightmare (I already run out of battery few times). I read this thread a few times and I think I know what to do. But please would you be so kind and help me with coding a bit ? My current situation is that I swapped BCM from 7H0937087D to 7E0937090 (donor car, I had trouble to find new for reasonable price), run new wires from main fuse box and CAN wires to instrument cluster. And before I continue with RLS and automatic headlight I want to be sure that the new BCM is coded properly.
Old BCM autoscan
https://pastebin.com/3BpwdNn9
There are some known errors.
- J364 - webasto unit is working but control unit not responding. I know about it and it is ok for now. Although it is very strange behavior.
- J503, J401 - I removed the original radio but I did not uncheck it from installation list yet.
- Airbag - I have removed drivers seat
- Air quality - I'm waiting for new sensor
- Second error in HVAC - it seems that is related also to J364
New BCM scan
https://pastebin.com/hM28BWxq
I coded CAN Gateway same as the old one. Also I unchecked unneeded records from installation list.
I tried to transfer all of the values from old BCM to new one to be same. But apparently there is something wrong.
This error is ok
- bulb for licence plate - I read how to solve it in this thread
Otherwise it looks ok, BUT there are some errors not presented in auto scan. Which is weird ?
Error from CAN gateway - Control Module Incorrectly Coded.
Address 19: CAN Gateway Labels: None Control Module Part Number: 7E0 909 901 HW: 7E0 937 090
Component and/or Version: GW-K-CAN TP20 X80 0733
Software Coding: 042200
Work Shop Code: WSC 00001 001 28888
VCID: 6889B8BD3270259AA73-803C
2 Faults Found
000 - - - Intermittent
Freeze Frame
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 9
Reset counter: 255
Mileage: 227039 km
Time Indication: 0
Date: 2018.06.14
Time: 09:15:55
01207 - Control Module for Auxiliary Heater (J364)
004 - No Signal/Communication
Freeze Frame
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 198
Mileage: 227039 km
Time Indication: 0
Date: 2018.06.14
Time: 09:12:45
Error in module called Battery regulator. I did not have visible this module before and it cannot be unchecked in installation list. I tried to locate J367 control unit and I don't have it. It seems that this is related to start-stop system but I don't know how to disable it (I have unchecked everything related to start-stop in BCM long coding). Maybe this is also reason for the Control Module Incorrectly Coded in CAN gateway.
- 420115370_690877076560178_5159485286294243088_n.png (103.11 KiB) Viewed 6675 times
- IMG_2917.jpeg (182.19 KiB) Viewed 6675 times
