iichels VW Passat 2.0 TSI DSG 4-Motion 2017
Re: iichels VW Passat 2.0 TSI DSG 4-Motion 2017
I'll send you a PM for your mail address, and I'll send the needed info.
raduss
Drives: Passat b8
Post by raduss »
I need coding and adaptation of block 09, 6D, B7.
raduss
Drives: Passat b8
Post by raduss »
Block B7
adaptation:
[VN]_Rear_lid_power_opening_control_unit_sender_1_threshold_1:
[LN]_sensor_1_treshold_1: 69
[VN]_Rear_lid_power_opening_control_unit_sender_1_threshold_2:
[LN]_sensor_1_treshold_2: 16
[VN]_Rear_lid_power_opening_control_unit_sender_1_threshold_3:
[LN]_sensor_1_treshold_3: 16
[VN]_Rear_lid_power_opening_control_unit_sender_1_threshold_4:
[LN]_sensor_1_treshold_4: 16
[VN]_Rear_lid_power_opening_control_unit_sender_1_threshold_5:
[LN]_sensor_1_treshold_5: 16
[VN]_Rear_lid_power_opening_control_unit_sender_2_threshold_5:
[LN]_sensor_2_treshold_5: 224
[VN]_Rear_lid_power_opening_control_unit_sender_1_timer_value_3:
[LN]_sensor_1_timer_3: 9
[VN]_Rear_lid_power_opening_control_unit_sender_1_timer_value_4:
[LN]_sensor_1_timer_4: 33
[VN]_Rear_lid_power_opening_control_unit_sender_2_timer_value_3:
[LN]_sensor_2_timer_3: 168
[LN]_sensor_2_timer_3: 147
[VN]_Rear_lid_power_opening_control_unit_data_set_version:
[LN]_Data_Identification: 0
[VN]_Rear_lid_power_opening_control_unit_sender_1_timer_value_5:
[LN]_sensor_1_timer_5: 34
[VN]_Rear_lid_power_opening_control_unit_sender_2_timer_value_5:
[LN]_sensor_2_timer_5: 23
[VN]_Rear_lid_power_opening_control_unit_vehicle_type:
[LN]_Rear_Lid_Opening_Sender_vehicle_type: 22
raduss
Drives: Passat b8
Post by raduss »
If you set you will have a VIP error.
raduss
Drives: Passat b8
Post by raduss »
TEST VIP
1
2
2
3
3
Cool, thanks, I'll give it a go. I retrofitted the kick to open and I tried several parameters for the antenna unit. The basic setting was indeed a disaster haha.
raduss
Drives: Passat b8
Post by raduss »
I am reviewing your scan, at my place is BCM BR, I did the upgrade from BH to BR. Did you do the AID update to 3G0920791D or did you buy the car with the meter updated? Does the view button on the steering wheel work for you? Because at my place it doesn't work, and I have AID 3G0920791C
Zrzut ekranu 28-11-2023 21.37.06.jpg (311.83 KiB) Viewed 10074 times
my car came from the factory with AID SW C and a MFSW without view button.
I changed the MFSW to the 5H0 steering wheel with 1EA touch buttons with view button and AID software to D. D supports view button.
This is the car when I received it: https://forums.ross-tech.com/index.php? ... ost-297982
I have BCM 5Q0 937 084 EC and 5Q0 937 084B ready for upgrade. The most recent flash file I can find for 5q0937086x is BM so I didn't update that one.
raduss
Drives: Passat b8
Post by raduss »
I'm dreading this upgrade from SW from C to D.
1
2
2
Zrzut ekranu 28-11-2023 22.22.14.jpg (65.17 KiB) Viewed 10060 times
Upgraded the 3Q0 side assist radars to 2Q0. 3Q0 wasn't completely compatible with the 3Q0..AR gateway software.
Otherwise I was pretty happy with the performance of 3Q0 (side assist, TJA, RTA, etc).
The process was pretty simple, take off bumper, swap the radar + brackets, wire it up and remove CF from the gateway.
I had to flash parameters for Passat with ODIS-E, that was easy as well. Then coding. Calibration was not needed and in the first 100 meters, a cyclist was detected.
Parts:
Brackets 3G0907455A 3G0907456A
Connector 2x 1J0973714
Radar: radar 2Q0907685B 2Q0907686B
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H07 0150
   Serial number: 00000591782366  Dataset Number: V03935345YL 0001
   Coding: 62954640
   ROD: EV_HREntryHellaGen3Kl15.rod
   VCID: 392FD0A549DB770228D-806C
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H07 0150
   Serial number: 00000606636104
(I wrapped it up in tape an put on a clamp to hold the wiring :) )
2Q0 wiring:
all other images:
https://imgur.com/a/FCnrTFh
patil
Post by patil »
iichel wrote: Wed Nov 29, 2023 12:19 pm Upgraded the 3Q0 side assist radars to 2Q0.
I hope you could able to appreciate the subtle updates made in 2Q0 radars.👍
I am yet to discover them to be honest haha. Performance seems pretty similar.
To get rid of the error in PDC module:
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 L    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H07 0074
   Serial number: 000308417617172 Dataset Number: V03935315EN 0001
   Coding: 0A71267951
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 59EF7025A99B970208D-800C
2 Faults Found:
12716048 - Databus
          U1121 00 [00001001] - Missing Message
          [T¸rsteuerger‰t - Spiegel_01 - fehlende Botschaft]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 53
                    Mileage: 168212 km
                    Date: 2023.11.29
                    Time: 12:12:52
12650512 - Databus
          [Steuerger‰t f¸r eCall - TM_01 - kein Signal/keine Kommunikation]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 53
                    Mileage: 168212 km
                    Date: 2023.11.29
                    Time: 12:12:52
Slavik told me the second error is fixed with an adaptation channel but I'm unable to discover it.
patil
Post by patil »
Check this adaptation channel in address 76 in ODIS-E. It shouldn't be active in your case. In VCDS adaptations list of address 10, this adaptation channel is not there! :shock:
