Oug8 update showing in car,could not download
lancslad1985
Re: Oug8 update showing in car,could not download
Post by lancslad1985 »
I never knew about this, so thanks for letting me know. I always wondered how to get to updates that didn’t install first time.
Maarten
Post by Maarten »
lancslad1985 wrote: Wed Nov 29, 2023 11:41 am I never knew about this, so thanks for letting me know. I always wondered how to get to updates that didn’t install first time.
Could be that only the FL models recieve them this way :|
MikeDO
Drives: GTI 2022 (white)
Post by MikeDO »
The update that I eventually found had been sitting there waiting to install.... is still trying to apply the update (and that's been over a month now).
It looks to have got about 40% done and just appears to be stuck there!!
Sat in a good 4G reception area (tested this and around 15mbs download is available) and still nothing happens. Even sat in the TESCO car-park waiting for someone (engine running as it was Baltic cold) for around half an hour.
So... I still remain skeptical of VW's OTA updates . A good idea... but only if it works.
Harrihealey02
Drives: 2018 SEL
Post by Harrihealey02 »
I’ve tried to update mine many times. Sometimes the notification randomly pops up saying update and if I press yes it will say that it can’t do it as I’m driving. Once that message disappears it’s very hard to predict when it will next show, and I’m going to make sure that I’m at a stand still when I accept it. My software screen looks like this when I manually try to install it, (no update is showing) see photos attached.
MikeDO
Post by MikeDO »
Looking at your last photo, you have "1" update waiting to be applied.
Try (as suggested a few posts back) swiping down from the top of the infotainment screen and then swiping left (or right, depending on your viewpoint) and it should be there waiting for you.
Good luck.
PS. I've NEVER seen an updating waiting for me going view "updates" screen shown on your photos. But doing as I suggested above, there's one sat there waiting for me to apply it. Not like it will actually do anything!
Life......................
MikeDO wrote: Thu Dec 14, 2023 9:10 pm Looking at your last photo, you have "1" update waiting to be applied.
Good luck.
With my ‘old’ 2020 pre-facelift GTI+ complete with old tech that doesn’t support OTA updates, I don’t feel like I’m missing out on too much 🤔.
Harrihealey02
Drives: 2018 SEL
I managed to do it! I did what you said, swiped down from the top and then swiped to the left to see the notifications and is now updated! Thanks :)
Maarten
Post by Maarten »
Maarten wrote: Mon Nov 27, 2023 12:17 pm use pull down menu, swipe left.
Then there will be updates visible.
Do you have a number in a circle in top bar of the infotainment?
Just do this, the update will be there
MikeDO
Post by MikeDO »
SRGTD wrote: Thu Dec 14, 2023 9:49 pm
Good luck.
Sometimes "old" is good :D
MikeDO
Post by MikeDO »
Does anyone know why the update notification (IE. the circle top left of the screen that looks to show the progress) when applying an update, is sometimes blue (as above) and sometime red (as in the case of my apparent "stuck" update)???
Maarten
Post by Maarten »
Did you try to reset the infotainment?
MikeDO
Post by MikeDO »
Maarten wrote: Fri Dec 15, 2023 6:46 pm Did you try to reset the infotainment?
I should have thought of that. You can't beat a re-boot.
I'll have a go tomorrow when I'm in a decent reception area and report back.
Thanks.
MikeDO
Post by MikeDO »
Sadly re-booting the Infotainment system appears not to have made any difference. It's still showing the following (regardless of how long you leave it with the engine running).
Not that worried ... but I'm assuming that it will though prevent any other update from downloading and installing.
MikeDO
Post by MikeDO »
Once again "I don't believe it"!
After a month of trying to get this update to install. I noticed today that there were two other updates queued to download/install. No indication what they were. But both downloaded/installed quickly and soon after that, the original "stuck" update returned (see above picture). This then proceeded to quickly install itself.
So my guess here, is that the first two small updates sorted something. Allowing the original one to then install correctly. But who knows really I suppose.
God to laugh really.
PS. And they want us to trust self driving cars. HA HA HA
