iichels VW Passat 2.0 TSI DSG 4-Motion 2017
Re: iichels VW Passat 2.0 TSI DSG 4-Motion 2017
I guess i should use more Odis then! Thank you very much patil
edit:
And done!
Also flashed the dataset for easy kick and set the parameters in the control module... no luck for that unfortunately
edit:
And done!
I compared mine and yours with coding + adaptations. Only I don't have PLA 3.0 activated yet because there was no time to install additional sensors, but I already have the module installed just activated under eight sensors
- Zrzut ekranu 01-12-2023 20.40.59.jpg (284.37 KiB) Viewed 10948 times
That's a really cool comparison. Is that a publicly available tool or one you made yourself?
ODIS-Explorer
A new addition to my autobiography:
Current door controler (HW: 5Q0959593B / SW F)
Desired one (HW: 5Q0959593F / SW L):
Will it fit? Nope...
Old connector: 1K0971975
New connector: 4M0971975
They rotated the power plug. Why?
And of course for all four doors.
What else didn't work?
Slip ring: 5Q1953549A / C / F = facelift B8.5 / G7.5 / golf 8 with heating
It needs 5Q1 stalks too.
Will it fit B8 pre-facelift (5Q0 stalks/slip ring from factory)? Physically, yes! Change wiring? Yes! One new wire for LIN, CAN is left over.
Connector is (still) 5Q0972726
Credits to unknown (probably Polish) author.
Wires need to be moved. There is an error in this page, LIN is from T73c/54, not a/54!
Coding is easy, set adaptation channel in BCM:
Address 09 5Q0 937 086 BM
channel ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter
adapted from CAN
to LIN
Remove address 16 from CAN installation list
One error persisted in the DSG gearbox for selector lever P position. I made a new wire to BCM A24 for this, but no luck, the gearbox really needs address 16.
BCM was also sad about P input signal. Perhaps FL BCM will solve this, but for now I put back my 5Q0 slip ring.
I'm pretty sure this will work on a manual gearbox. Heating was working just fine.
A morning of failure and cold.
adapted from CAN
to LIN
In the Golf7.5 there are also these small differences (door module connectors, ring/stalks), for example Slavik's Golf7.5 (MY J) vs my Golf7.5 (MY K).
Maybe you can find something new/differences in the Golf 7-7.5 diagrams - by comparison - that could be useful to you.
The wiring of the dual-clutch gearbox that corresponds to each model is specified...
It's just an idea.
VW is playful with the naming of the BCM MQB connectors depending on the model... although it is specified at the end of the diagrams (in the images of the units).
It's just an idea.
The funny thing is, my dq250 gearbox was cancelled with the introduction of the mk 7.5, more or less. I could not find a scan with both the dq250 gearbox and the 5q1 stalks.
I connected the wire from the shift lever P position to BCM a24, like in the facelifted models. But these come with dq200, dq381, dq400e and dq500 But the databus missing communications persisted. I guess the dsg really must see the module 16, since it always had cars with that module present, bar perhaps one year of polo 2g GTI.
One thing I failed to test is to let the car sleep. I'll follow up on that.
New battery, yeay! Preventive maintenance on my factory fitted 92Ah AGM battery. It's replaced with a brand new 96Ah Exide AGM battery.
And since the Passat has an aux heater, big battery, battery in the boot, for extra struggles while changing.
To finish it off, changed the serial number in battery adaptation, so the car knows it has a new battery and will charge it accordingly.
The old battery wasn't sure about being a VW battery, a Varta or a JCB. And the Varta is actually from the Bosch factory.
patil
Let's restore back the reputation of VCDS.patil wrote: Fri Dec 01, 2023 5:24 pm
Check this adaptation channel in address 76 in ODIS-E. It shouldn't be active in your case. In VCDS adaptations list of address 10, this adaptation channel is not there!![]()
The adaptation is there albeit with confusing label. ODIS adaptation is more clear though.
Thanks patil for re-instating my trust in my favourite tool!
Will it now fit? Yes, I bought myself four correct connectors.
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 L HW: 5QA 919 298 A
Component: PLA 3.0 12K H07 0074
Serial number: 000308417617172 Dataset Number: V03935315EN 0001
Coding: 0A71267951
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_EPHVA2CAU3700000 009055
ROD: EV_EPHVA2CAU3700000_009_VW37.rod
VCID: 59EF7025A99B970208D-800C
2 Faults Found:
12716048 - Databus
U1121 00 [00001001] - Missing Message
[T¸rsteuerger‰t - Spiegel_01 - fehlende Botschaft]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 53
Mileage: 168212 km
Date: 2023.11.29
Time: 12:12:52
12650512 - Databus
[Steuerger‰t f¸r eCall - TM_01 - kein Signal/keine Kommunikation]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 53
Mileage: 168212 km
Date: 2023.11.29
Time: 12:12:52
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 190417EDJ1110A Dataset Number: V03935256EF 0001
Coding: 00351A20D200028000111000
Shop #: WSC 30389 123 56831
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 43D3B24D3B173DD2721-8016
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 170617EFH29274 Dataset Number: V03935256ZD 0001
Coding: 00351020DE00028200111000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 42DDB749240D34DA797-8016
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 070617EF614855 Dataset Number: V03935256XR 0001
Coding: 000410200100028000001000
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
VCID: 45D7AC55352303E25C5-8010
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 020 0041
Serial number: 070617EF613546 Dataset Number: V03935256NT 0001
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
No fault code found.Code: Select all
Coding: 8A79267951
VCID: 59EF7025A99B970208D-800D
Part No SW: 5Q0 959 593 L HW: 5Q0 959 593 F
Component: TSG FS003 0350
Serial number: YE007VFP28434 Dataset Number: V03935363WB 0001
Coding: 00351A20D200028000011000
ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001018
ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
VCID: 4ACD9F691C3DEC9AB17-801F
Part No SW: 5Q0 959 592 L HW: 5Q0 959 592 F
Component: TSG BFS003 0350
Serial number: YE007VF20444B Dataset Number: V03935358AV 0001
Coding: 00351020DE00028000011000
ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001018
ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
VCID: 49CFA065193BE782B8D-801D
Part No SW: 5Q0 959 595 L HW: 8W1 959 595 D
Component: TSG HFS005 0350
Serial number: YE007VBO10863 Dataset Number: V03935306SB 0001
ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
ROD: EV_DCU2RearDriveMAXHKLO_VW37.rod
VCID: 4CC199711649F2AA83B-8019
Component: TSG HBFS005 0350
Serial number: YE007VBO13878 Dataset Number: V03935306RQ 0001
ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
ROD: EV_DCU2RearPasseMAXHKLO_VW37.rod
No fault code found.- changed rear controllers, wrote dataset and coded correctly (donor was audi A3)
- learn window end stops
- clear all errors
- changed some small codings (dimming exterior mirror via FLA, memory passenger seat disabled)
- enjoy
casually picking up some new toys
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 3G8 907 044 T HW: 3G8 907 044 T
Component: Climatronic H10 0221
Coding: 12020024104411011115500D0018592A
ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 002004
ROD: EV_AirCondiBHTCMQB3rTranc_002_VW37.rod
VCID: 3E25C3B950F5503A1DF-806B
Air quality sensor:
Humidity sensor: exterior:
Rear air conditioning block 1:
Subsystem 3 - Part No SW: 11A 907 049 A HW: 11A 907 049 A
Component: E265 KPH SH H02 0183
Serial number: G04S01.11.2100972191
Coding: FFFFFF
Oh right, the local village idiot bought some Arteon seats for his Passarteon ...
https://imgur.com/a/qOwIdiQ
Will convert the 'normal' electric seats to
- Both sides memory (driver on address 36, passenger on address 06), needs a GND to T32/2 and the same 3Q0/5Q0 module, and an adaptation channel set to 'passenger'
- Both sides ventilation
- Both sides massage (like my earlier trick --> viewtopic.php?p=597034#p597034)
So I've been putting stuff into cars that don't belong there. Again. I know, you must be getting really tired of me. I'm sorry.
A while ago I saw some Arteon seats for good money.
They needed some love, some airbags, some plastic trim, switches and some seatbelt locks.
So I bought them, bought all the extra parts and decided to get myself an upgrade for a memory passenger seat too.
The current passenger seat was a full electric one with 'dumb' switches.
Shouldn't be that hard and the Superb came with those from factory. And why wouldn't you?
https://forums.ross-tech.com/index.php?threads/29947/#post-251560
It's basically the same module as the driver seat, with an extra GND to to T32/2.
Typically the driver gets a 3Q0 (memory + massage) and the passenger gets a 5Q0 (memory).
I went the 3Q0 + 3Q0 way, because why not, so I got going. Wired it up like a RHD driver seat with memory and massage.
That was pretty easy, I didn't have to change any motors.
So, next step is to do coding and basic settings. I started with the driver seat disconnected and talked to the module on address 36.
Adaptation:
channel IDE06869-installation position
adapted from
Memory seat driver side
to
Front passenger side memory seat
Power off, lock, wait and reboot. Now the module shows up at address 06.
Next step was to check for errors and sure enough, dataset was invalid. So I got myself an Arteon driver seat dataset via SVM tricks and changed the header from 0x0036 to 0x0006.
This way I could use the O-tool to write the dataset to module that now identified as 06. I had to do it via Skoda project 48, since VW 48 wasn't very familiar with module 06.
Next step, basic settings. Of course the seat was pretty unhappy and it took some coding...
Experimental coding allows for many of these motors to be set:
SLV - Sitz Lange Verstellung - Seat front/rear
LNW - Lehne Neigung Verstellung - Backrest angle
SHV - Sitz Höhe Verstellung - Seat height
SNV - Sitz Neigung Verstellung - Seat tilt
LDH - Lehne D? Höhe - Lumbar height
LDW - Lehne D? Weiten - Lumbar front/rear
I set the first four to SLP_with_SLP_ErrorTest and the lumbar gear to Hall_with_Hall_ErrorTest
All basic settings ran just fine, except for the front/rear. I tried a lot but I got fed up and decided to take matters into my own hands.
So I put the passenger module underneath the driver seat (with position sensor for front rear, coded for Hall_ErrorTest) and did the basic setting for that axis on the driver seat.
And then put back the module to the passenger seat. Guess what? That works! Pretty dumb huh?
So, all errors gone, coded the modules like I described here: https://forums.ross-tech.com/index.php?threads/40896/
Now everything works. Pretty neat result. Pretty useless as well, but hey, that's me.
Adaptation:
adapted from
to
Thursday,11,January,2024,21:16:17:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
Workshop Code: 123 30389 056831
VIN: License Plate:
Mileage: 173093km-107555mi Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 18 19 22 2B 36 3C 42
44 47 4B 52 5F 65 69 6C 6D A5 BB BC CA D6 D7
VIN: Mileage: 173093km-107555miles
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
47-Sound System -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-CJXB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 F HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13--- CVN: B7DB7878
Coding: 091D003A2476050B3004
ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
ROD: EV_ECM20TFS0205G0906259J.rod
VCID: 313FE88591ABBF4290D-8065
VINID: 9E69EAAAA0D3A9A54008518520274044B7
2 Faults Found:
15170 - Engine Oil Temp. Sensor (G8)
P0198 00 [00101111] - Signal too High
Fault Priority: 2
Fault Frequency: 1
Mileage: 171917 km
Date: 2024.01.04
Time: 16:32:32
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 70 ∞C
Intake air temperature: 59 ∞C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.953 V
Engine: operating status: ES
STATE_LS_SAE[1]: INI
T_AST_SAE: 0 s
MAP_MES_SAE: 100 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
FAC_TPS_1_SAE: 16.406250 %
FUP_H_SAE: 13090.0 kPa
15171 - Engine Oil Temp. Sensor (G8)
P0196 00 [00101111] - Implausible Signal
Fault Priority: 2
Fault Frequency: 1
Mileage: 171917 km
Date: 2024.01.05
Time: 10:44:08
Engine RPM: 1060.25 /min
Normed load value: 11.0 %
Vehicle speed: 15 km/h
Coolant temperature: 10 ∞C
Intake air temperature: 9 ∞C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.140 V
Engine: operating status: PL
STATE_LS_SAE[1]: OL_CDN
T_AST_SAE: 32 s
MAP_MES_SAE: 75 kPa
FAC_TPS_1_SAE: 17.968750 %
FUP_H_SAE: 8460.0 kPa
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 018 C HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5297
Revision: 06454104 Serial number: TFK01706160335 CVN: 000099EF
Coding: 0014
Shop #: WSC 05311 115 00065
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 1C612931E629222AD3B-8049
2 Faults Found:
10657 - RPM Signal from ECU
P0726 00 [00000010] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
10763 - Starter Enable from Selector Lever Sensor System
P1734 00 [00000010] - -
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5Q0 614 517 FM HW: 5Q0 614 517 AH
Component: ESC H62 0755
Revision: 00000000 Serial number: 61907000000236
Coding: 0FEC6B8F54222371477D070540CB69F0D62AC4E2E00296753842508842A9420000000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
VCID: 015F7845618BEFC220D-8055
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0906
Revision: 00037000 Serial number: 0448732144 Dataset Number: V03935260TX 0001
Coding: 1F20200723
ASAM Dataset: EV_KessyHellaMQBAB 004041
ROD: EV_KessyHellaMQBAB.rod
Rear lid opener control module:
Subsystem 1 - Part No SW: 3G0 962 243 HW: 3G0 962 243
Component: GEB.F.Heckoef H17 0812
Serial number: ;8001216
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 3Q0 959 760 D HW: 3Q0 959 760 B
Component: Sitzmemory H05 0024
Serial number: Y0006PKA28228 Dataset Number: V03935285VX 0001
Coding: 001800020000150081C480808080000000008181000000F400
ASAM Dataset: EV_SeatMemorPasseSide 002022
ROD: EV_SeatMemorPasseSide.rod
VCID: 3C21C9B146E9422A33B-8069
Air quality sensor:
Coding: FFFFFF
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 086 BM HW: 5Q0 937 086 BH
Component: BCM PQ37BOSCH 034 0242
Revision: -------- Serial number: 865829061700DO Dataset Number: V03935260TT 0001
ASAM Dataset: EV_BodyContrModul1UDSBosc 018001
ROD: EV_BCMBOSCH_018.rod
VCID: 06556B5948A5C8FA15F-8053
Wiper motor control module:
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 170615 042 0607
Serial number: 170629234856
Coding: 0F4DFD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S4Y17M06D29H19M25S21
Coding: 06A8DD
Light switch:
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 14 04 2017 10001690
Anti-theft alarm system sensor:
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY1714382PB
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000070188699
Humidity sensor: interior:
Blower 1 for left front backrest:
Subsystem 7 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0101
Serial number: ESE0158736
Blower 1 for left front seat cushion:
Subsystem 8 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Blower 1 for right front backrest:
Subsystem 9 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0145994
Blower 1 for right front seat cushion:
Subsystem 10 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0146336
Coding: 8A79267951
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 S HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0780
Dataset Number: V12345678AA V315
Coding: 351F5FFBDFFFCF28979F813681500D80000000000099000032
ASAM Dataset: EV_ACCBOSCHVW416 003015
ROD: EV_ACCBOSCHVW416_003_VW41.rod
VCID: 47CBA65D0F2F11F2AE9-8013
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 C HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0130
Serial number: 25061741350001 Dataset Number: V03935290WM 0001
ASAM Dataset: EV_DRCONTITEMIC 001019
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 392FD0A549DB770228D-806D
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 3Q0 959 655 CP HW: 3Q0 959 655 CP
Component: Airbag VW21 006 0721
Revision: -------- Serial number: 003Z4PGADL1% Dataset Number: V03935283XG 0001
Coding: 98FCC0C0008000005C5400CF000800000065
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
ROD: EV_AirbaVW21TS6VW48X_VW37.rod
VCID: 0E45537920D580BAADF-805B
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1040
Serial number: 3G0857705 0031T01500
Coding: 80000D
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1032
Serial number: 3G1857706G0185R01460
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 001 606 17
Component: SideSensor_Df 008 0887
Serial number: 357000000000507D3628
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 454 001 806 17
Component: SideSensor_Pf 008 0887
Serial number: 358000000008D140C62J
Coding: 2D2D2D
Subsystem 5 - Part No SW: ----------- HW: 454 801 106 17
Component: SideSensor_Dr 301 0148
Serial number: 3510091305210000000U
Coding: 2D2D2D
Subsystem 6 - Part No SW: ----------- HW: 454 801 106 17
Component: SideSensor_Pr 301 0148
Serial number: 352002F2F52100000009
Coding: 2D2D2D
Subsystem 7 - Part No SW: ----------- HW: 454 801 406 17
Component: FrontSensor_D 304 0149
Serial number: 3550040279610000000%
Coding: 2D2D2D
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 KT HW: 5Q0 953 569 B
Component: Lenks.Modul 100 0265
Revision: FF035035 Serial number: 20170828500092 Dataset Number: V03935250KY 0001
Coding: 8410
ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
ROD: EV_SMLSVALEOMQBLRH.rod
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 3G0 920 791 D HW: 3G0 920 791 C
Component: KOMBI 406 4191
Coding: 07AD0898FE8C000C01887F0F3001000080000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009058
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 2A0DFFE9BC7DCC9A517-807F
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 K HW: 5Q0 963 272 H
Component: STH-MQB 008 0080
Coding: 9309
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_AuxilParkiHeateWOS 002018
ROD: EV_AuxilParkiHeateWOS.rod
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0401
Serial number: 00000000000000276932
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AR HW: 3Q0 907 530 C
Component: GW MQB High 518 5502
Serial number: 06071710802132 Dataset Number: V03935278KN 0001
Coding: 0B0B00347F015900DB00025E9C0F00010001070000000000000000000000
GVL: 01DE3C0008000600C0FC80000006CC0010000000000200000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_VW37.rod
VCID: 7F5BFEBD177F9932569-802B
Generator:
Component: 4-00-03-00-04
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 1EA 959 442 E HW: 1EA 959 442 E
Component: MFL H03 0219
Serial number: 17036218123222100161
Coding: AF0B00
Subsystem 3 - Part No SW: 3Q0 915 181 B HW: 3Q0 915 181 B
Component: J367-BDMHella H10 9070
Serial number: 5131394104
Inverter for electrical outlet:
Subsystem 4 - Part No SW: 5Q0 907 155 C HW: 5Q0 907 155 C
Component: U13DCAC H26 0780
Serial number: 0066181
Analog clock:
Subsystem 5 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 111 1004
Serial number: 3003201700010095
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7084
Serial number: HA1-00017.05.17 Dataset Number: v1260x015G0 0000
Coding: 0601
ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
ROD: EV_AllWheelContrHA1VW37X_004.rod
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 17000160250002
Coding: 0800000000000000
ASAM Dataset: EV_ELVMarquMQBB 001007
ROD: EV_ELVMarquMQBB_VW37.rod
VCID: 71BF2885512BFF42D0D-8025
Address 36: Seat Mem. Drvr (J810) Labels:* None
Serial number: Y0006QFD15173 Dataset Number: V03935285VX 0001
Coding: 001800020000150081C481808080000000008181000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002022
ROD: EV_SeatMemorDriveSide.rod
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H07 0150
Serial number: 00000591782366 Dataset Number: V03935345YL 0001
Coding: 62954640
ROD: EV_HREntryHellaGen3Kl15.rod
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H07 0150
Serial number: 00000606636104
Coding: 00351A20D200028200011000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5082
Dataset Number: 8V0909852AA 0001
Coding: 93070000
Shop #: WSC 00015 115 00319
ROD: EV_SteerAssisMQB_015.rod
Address 47: Sound System (J525) Labels:| 3Q0-035-466.clb
Part No SW: 3Q0 035 465 HW: 3Q0 035 465
Component: MIB2_amp_P_VW H60 0440
Revision: 00000001 Serial number: VWZ8Z1HJD00RUVL Dataset Number: V03935264BQ 0001
Coding: 1284020001AA0A2AAA0000000000
ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001018
ROD: EV_AMPMst16C3Gen2ALPI_VW48.rod
VCID: 6B833AED73071592EA1-803F
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 01071710801233 Dataset Number: V03935339UR 0001
Coding: 000000060100035207007F010A0000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 001010
ROD: EV_MultiModulContiVW48X_001.rod
VCID: 72BD2789542DC45A297-8027
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _
Component: Leimo links H02 0003
Coding: E02400
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _
Component: Leimo rechts H02 0003
Coding: E02400
Coding: 00351020DE00028200011000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 5NA 035 022 B HW: 5NA 035 022
Component: MU-H-LND-EU H54 1367
Serial number: A846F0JS020395 Dataset Number: V03935262VW 0001
Coding: 02840201000000005111110200880A301F0106E4012004009F
ASAM Dataset: EV_MUHig4CGen2HBAS 001001
ROD: EV_MUHig4CGen2HBAS_VW37.rod
VCID: 323DE78994AD845AE97-8067
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H50 9130
Serial number: VWZ6ZJT1915518
Data carrier:
Subsystem 2 - Part No SW: V03 959 809 PC HW: -----------
Component: ECE 2023 --- 0310
Compact disc data bank:
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1016
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000081630 Dataset Number: RDKS_TinyQ_ 1017
ROD: EV_RDKBERU30_006_VW37.rod
VCID: 3829D5A172D16E0AD73-806D
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N
Component: Anhaenger H27 0264
Revision: 8A001003 Serial number: 0446947174 Dataset Number: V03935259HF 0001
Coding: 0100000202000000
ASAM Dataset: EV_TrailFunctGener2Hella 001008
ROD: EV_TrailFunctGener2Hella_VW26.rod
VCID: 42DDB749240D34DA797-8017
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 5Q0 907 556 C HW: 5Q0 907 556
Component: Areaview 2 H13 0608
Serial number: C854707JG069231 Dataset Number: ----------
Coding: 01840200E70F200004314817
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
ROD: EV_CamSysRVAV2ARCE2MQBAB_006_VW37.rod
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 Q HW: 5Q0 959 107 C
Component: HDSG-Modul H12 0265
Revision: -------- Serial number: 31344982200000 Dataset Number: V03935262CS 0001
Coding: 02A8
ASAM Dataset: EV_DeckLidCONTIAU736 001016
ROD: EV_DeckLidCONTIAU736_VW37.rod
VCID: 46D5AB59082508FA55F-8013
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 2Q0 980 653 D HW: 2Q0 980 653
Component: MQB MFK 3.0 H16 1421
Serial number: E80320003220200 Dataset Number: V03935411EY 0001
Coding: 0004019821FAC02888DF14001020004000218000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 007042
ROD: EV_MFK3ValeoMQB_007_VW38.rod
VCID: 3635DB9978C5987AC5F-8063
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 D HW: 4M0 907 594
Component: SAD_STG_1 011 0003
Dataset Number: V03935218DJ 0001
Coding: 208040748202
ASAM Dataset: EV_SunRoofCONTIAU736 004008
ROD: EV_SunRoofCONTIAU736_004.rod
VCID: 372BD69D7FCF6172DE9-8063
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
ROD: EV_LEDModLeftMELCOAU736_VW37.rod
VCID: 16753B191805787AE5F-8043
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0003
ASAM Dataset: EV_LEDModRightMELCOAU736 001004
End----------(Elapsed Time: 02:44, VBatt start/end: 14.2V/14.3V)-----------
Thursday,11,January,2024,21:23:21:11868
www.Ross-Tech.com
VIN: WVWZZZ3CZJE025658 License Plate:
VIN: WVWZZZ3CZJE025658 Mileage: 173093km-107555miles
1 Fault Found:
P0198 00 [00100111] - Signal too High
Fault Priority: 2
Fault Frequency: 1
Mileage: 173093 km
Date: 2024.01.11
Time: 21:17:14
Engine RPM: 768.25 /min
Normed load value: 4.7 %
Coolant temperature: 89 ∞C
Intake air temperature: 32 ∞C
Ambient air pressure: 1030 mbar
Voltage terminal 30: 14.296 V
Engine: operating status: IS
STATE_LS_SAE[1]: CL
T_AST_SAE: 3 s
MAP_MES_SAE: 35 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.973 V
FAC_TPS_1_SAE: 12.890625 %
FUP_H_SAE: 18840.0 kPa
Readiness: 1010 0000
Coding: 0014
Coding: 1F20200723
Air quality sensor:
Coding: FFFFFF
Coding: 0F4DFD
Coding: 06A8DD
Light switch:
Alarm horn:
Coding: 8A79267951
Coding: 80000D
Coding: 80000D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 8410
Coding: 9309
Generator:
Coding: AF0B00
Analog clock:
Coding: 0601
Coding: 62954640
Coding: 93070000
Coding: E02400
Coding: E02400
Data carrier:
Coding: 02A8
End----------(Elapsed Time: 02:44, VBatt start/end: 14.3V/14.4V)-----------
Oh, I also got some new stuff:
Will elaborate on that as well, later.
