Trunk light refuses to work
Cruzor
Drives: VENTO 1.5TDI
Post by Cruzor »
Hi, I own a vento and suddenly my trunk open light is not working. The bulb is okay but it is not lighting up. I have used different bulbs also. The socket wire is good, I can see voltage at it. But when bulb is connected, trunk open warning light is not showing. When bulb is disconnected, trunk open light is showing in dashboard.
I checked online and see that the switch in latch is bad, but if that was the case the indicator would not show. I checked current flow diagram but I don’t understand how is the bulb circuit connected is so unfortunately I’m stuck. If anybody else has faced this issue please do let me know. Thanks in advance.
Re: Trunk light refuses to work
i think it is due to broken latch micro switch.
Vw seems to have issues with micro switches, i wish they made it easily serviceable, but they like their euros
You also have a diode where you put the bulb, bud i doubt it failed. You can check it
CarbonChaos
Post by CarbonChaos »
So at the trunk light you have 12v at the connector ? The micro switch sends the negative/ earth side to switch the light on.
With the bulb out there is no load on the circuit this maybe why the dash light works , please check the wiring in the trunk lid hinge area first , you may have a broken wire or a damaged wire .
Cruzor
Post by Cruzor »
amer6R wrote: Sun Dec 31, 2023 5:10 pm i think it is due to broken latch micro switch.
I too thought the same, even replaced the diode it didn’t work.
CarbonChaos wrote: Mon Jan 01, 2024 8:27 pm So at the trunk light you have 12v at the connector ? The micro switch sends the negative/ earth side to switch the light on.
Yes there’s 12v at the connector. Thanks for the info, I’ll check the wires. I should have continuity from the negative side to ground when the trunk is open, right?
Edit- It was the microswitch, it’s working fine now. Not sure how it broke in the first place, especially as it’s a sedan so like the hatch it’s not due to water from the rear wiper wash system. Anyhow, vw is 50eur richer now.
Cruzor wrote: Tue Jan 02, 2024 9:32 am
they dont make it like they used to....
