EA211 Oil Catch can
Re: EA211 Oil Catch can
Little by little (step by step), you will surely find the right hoses for that place.
Le_Combattant
Post by Le_Combattant »
ciclo wrote: Mon Mar 18, 2024 6:43 pm Little by little (step by step), you will surely find the right hoses for that place.
I have to make an order from...a UK/swedish sellers because in France, nothing available. Very small choice.
But I would like to go fast, when I removed the charge pipe, it was already covered by a thin lawer of oil.
2226
Post by 2226 »
You will need flourosilicone hose. Those should be resistant to oil and fuel. I think they're usually identified by a black liner on the inside.
2226
Post by 2226 »
Try Viper Performance in the UK for flouro hose.
Le_Combattant
Thanks for sharing !
2226
Post by 2226 »
I might go with just a diesel transfer hose type if it's not too rigid.
All the silicone hose I see around from the performance shops here is just air hose. They state chemical resistance, but I doubt that.
I am looking to replace the airbox to turbo intake hose with a silicone hose which might get fed some post-turbo air which might contain oil. Hopefully a catch puts less into that.
Le_Combattant
2226 wrote: Tue Mar 19, 2024 10:00 am I might go with just a diesel transfer hose type if it's not too rigid.
I made an order for flourosilicone hose. We will see, for 150 euros, I hope it will work.
2226
Post by 2226 »
Le_Combattant wrote: Tue Mar 19, 2024 10:42 am I made an order for flourosilicone hose. We will see, for 150 euros, I hope it will work.
Damn... some pricey stuff.
Le_Combattant
Yes...so It have to work now
2226
Post by 2226 »
Off-topic...
Just looking over pics again.
What is the purpose of this sensor:
It is brake vacuum or booster pressure sensor. Just curious as to what it connects to and what it is used to control.
Le_Combattant
You are right, It is brake vacuum line ;)
2226
Post by 2226 »
lol well yes, it's a vacuum line. But what's the pressure sensor for?
Can't quite tell from the option codes applicable to CJZD equipped vehicles.
Le_Combattant
Brake Vacuum Pipe Tube sensor.
Why ?
I don't know :?:
2226
Post by 2226 »
No hoses yet?
Le_Combattant
I received everything, I'm just waiting for this f*****g rain to stop.
It's been over 3-4 month it's raining almost every day.
