Pauls Polo 6R Trendline conversion road to OEM++
Paulpelz
Drives: Polo 6R 2012 Style 1.2 -> 1.4 TSI OEM++
Re: Pauls Polo 6R Trendline conversion road to OEM++
Post by Paulpelz »
Now here the promised pictures:
My extremely helpful colleague, happily standing in my completely stripped out engine bay:
Jemand im Motorraum.jpg (773.85 KiB) Viewed 4347 times
And my kind of finished looking engine bay about three hours later (ignore the crooked wiper :lol: ):
Eingebauter Motor bearbeitet.jpg (1.04 MiB) Viewed 4347 times
Things left to do: driveshafts (yes I know I should have done it right after putting the engine in), AC compressor, alternator, belt, exhaust system, starter. In other words: Just a few hours of work left and I might hear my car come back to live after more than half a year :D
Paulpelz wrote: Thu May 16, 2024 1:10 am
iichel wrote: Wed May 15, 2024 12:48 pm if you're using the same instrument cluster and key, probably only need to code the abs controller
Does this even apply if the ECU and the engine are not from the same donor car?
the ecu doesn't care where the engine is from, as long as it's the correct engine code. immo is a triangle of ecu, cluster and key. abs needs all VINs to match.
Paulpelz
Post by Paulpelz »
Update number 29401ß0348?
It runs! And pretty good actually! I am absolutely over the moon and have a massive smile on my face since the time I twisted the keys. :D
Now the annoying bits: Ironing out all the little remaining faults:
- Basic setting of the steering angle sensor. I had this problem some months ago, so this shoudn't be a big one.
- Disassembling and rebuilding the back axle because I screwed up and mounted the shieldplate underneath the axle stump.
- Fixing the exhaust, since it is leaky AND banging on the chassis.
Also, there are some faults I cannot make sense of, so I hope you all can:
1. When the engine is running (and only then) I have the following fault codes (please excuse my use of OBD11, my VCDS-laptop is broken-ish):
P11AB00 - Cam Shift Actuator "B" Cylinder 3 Circuit/Open
static
P11A700 - Cam Shift Actuator "B" Cylinder 2 Circuit/Open
static
P31AB00 - Cam Shift Actuator Outlet "B" Cylinder 3 Circuit Low
static
P31AA00 - Cam Shift Actuator Outlet "B" Cylinder 2 Circuit Low
static
P11A900 - Cam Shift Actuator "A" Cylinder 3 Circuit/Open
static
P11A500 - Cam Shift Actuator "A" Cylinder 2 Circuit/Open
static
P31BB00 - Cam Shift Actuator Outlet "A" Cylinder 3 Circuit Low
static
P31BA00 - Cam Shift Actuator Outlet "A" Cylinder 2 Circuit Low
static
P11C100 - Cam Shift Actuator Outlet "A" Cylinder 2 Range/Performance
static
Of course all four actuators could be broken at once but I don't really think so. Do they have to get learned to the ECU or is there something else I am missing, maybe some adress-19-shenanigans?
2. Adress 08: Air conditioning:
I mentioned it previously, but here is the situation again: The Polo 6R Blue GT doesn't have a coolant fan relay. The fan has the relay built into the hub and gets triggered by the ECU, so there are only four wires going into the fan. So far so good. But "normal" Polos have two additional wires from the Climatronic/Climatic/Manual Unit to the fan relay, triggering the fan if A/C is activated. These two wires are now unconnected on the fan side of my Polo, which unsurprisingly gets moaned about by the Climatronic unit. Is there a way to make it shut up about this and (probably) use the CAN network to call for the fan?
change some adaptation channels in 08 hvac to fix the fan issues
Paulpelz
Post by Paulpelz »
Thanks! That has got to be it!
Sadly, there are no labels in VCDS for the adaption channels, so I just guessed and changed the following:
Ch 1: 0 -> 1
Ch 2: 0 -> 1 (I installed one of these coombined rain and moisture sensors ages ago together with my high beam assist conversion)
Ch 3: 1 -> 0
Ch 4: I don't know the value, but I haven't changed it
Ch 5-7: 0 -> 1
Now it stopped moaning about the missing wires, but instead started infoming me about being coded wrong. So there is still some experimenting left to do. But thanks Michel, without your picture i would never have been able to fix that issue. :D
Paulpelz
Post by Paulpelz »
Paulpelz wrote: Tue May 21, 2024 12:08 am Also, there are some faults I cannot make sense of, so I hope you all can:
static
static
static
static
static
static
static
static
static
Here I found my issue: I accidentially swapped the Pins 5 and 6 in the connector between engine harness and central harness. Swapping those into their proper positions resolved my issues. Now my engine is running like a charm and there are only some minor sporadic faults stored. :D
I guess it's time to change your signature then. Well done, keep it posted.
Paulpelz
Post by Paulpelz »
You are absolutely right, thanks for reminding me! :lol:
Now one of the only remaining things to rectify before I can bring my car to its technical inspection is to get the start-stop system working.
As of now, everytime I start the car, the instrument cluster tells me "Fault: Start-Stop". The button in the center console also does nothing.
I suspect I only have to tick some boxes in the coding of some control units or have to fiddle around with some adaption channels to get it to work. Does anyone know which control units have something to do with the start-stop functionality?
I will later post an updated Autoscan.
Also, just for completeness: I didn't yet code my ABS system for the new engine. I assume this might have something to do with the problem. I will try some codings later today, so maybe this entire post was a complete waste of time :lol:
Paulpelz
Post by Paulpelz »
Well, looks very much like a waste of time it was...
Since I fiddled around with the ABS coding a little bit, start-stop miraculously started working. Funny enough however: My deactivation button does not work. As pointed out in one of my previous posts, the wiring diagram is just wrong concerning that matter, so I have to keep trying. How hard could it be?! Famous last words...
On a side note, below is a current autoscan from earlier today(ish).
Saturday,25,May,2024,14:38:53:44001
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.5.0.0 (x64)
Data version: 20240429 DS355.0
www.Ross-Tech.com
VIN: WVWZZZ6RZCY154963   License Plate:
Mileage: 130620km-81163mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 37 44 47 55 5F 61
VIN: WVWZZZ6RZCY154963   Mileage: 130620km-81163miles
47-Sound System -- Status: Malfunction 0010
Address 01: Engine (J623-CPTA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 Q    HW: 04E 907 309 D
   Component: 1.4l R4 TSI   H08 7599
   Revision: WCH08---    Serial number:                CVN: CFB85C3E
   Coding: 00190032242411000000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM14TFS01104E906016Q 002011
   ROD: EV_ECM14TFS01104E906016Q_002.rod
   VCID: 306898F86B88B216F3-8064
   VINID: 9E69EAAAA1A2A93A411442460C9D751C47
1 Fault Found:
5583 - Oil Pressure Switch for reduced Oil Pressure
          P164C 00 [01100000] - Implausible Signal
          Intermittent - Not Confirmed - Tested Since Memory Clear
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 130623 km
                    Date: 2024.05.24
                    Time: 23:35:56
                    Engine RPM: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 88 °C
                    Intake air temperature: 44 °C
                    Ambient air pressure: 1010 mbar
                    Voltage terminal 30: 12.604 V
                    Mass flow through throttle valve: 2.6 kg/h
                    Mean injection time: 0.797 ms
                    Engine operating condition: Idle
                    Engine operating condition-Test_Program_Channel 87: 5
                    A/C compressor: load current: act. value: 152.50 A
Readiness: 0110 0001
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H02 0002
   Serial number: --------------
   Coding: 21DD4885232800C4841D126FC45400550904
   Shop #: WSC 01383 785 00200
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   ROD: EV_Brake1ESP90iBOSCH_VW25.rod
   VCID: 0F2A3B04D6F68DEECA-805A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H12 0812
   Revision: V0000000
   VCID: 3878A0D88BF86A56BB-806C
1 Fault Found:
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 13
                    Mileage: 130618 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 04:24:49
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 259171299
   Coding: 3CB02BBF4821000021380FE06EEB9FD1C6C067CF608D7850210000030800
   Shop #: WSC 12345 123 61029
   VCID: 2B528F944AAED1CEC6-807E
   Component: RLHS 200618 0  50  0107
   Coding: 008F77
   Subsystem 2 - Part No SW: 6R0 959 801 DJ    HW: 6R0 959 801 DJ  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  004 0610
   Serial number: KU0KU021031770802804
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 DN    HW: 6R0 959 802 DN  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 0610
   Serial number: KU0KU005081662186418
   Coding: 1000AB
   Subsystem 5 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU011111100010576
   Coding: 08BC32
   Subsystem 6 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU014111100016138
   Coding: 08BC32
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28231921103426
   Coding: 308009
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   VCID: 71EE5DFCA002FB1EBC-8024
   Component: VW10Airbag01M H09 0020
   Revision: --------    Serial number: 003GX0108L3% Dataset Number: v00305696R0 0001
   Coding: 00314D
   Shop #: WSC 00788 648 00255
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A9CEA10ED14E8C6DD-801E
   Serial number: 3575HRB405R0UJCIB1I5
   Serial number: 3585HRB405F0UJCI4H6Y
   Serial number: 3515RRB40650TGJKB0CT
   Serial number: 3525RRB40610UT98K0GV
   Part No SW: 6R0 920 870 D    HW: 6R0 920 870 D
   Component: KOMBI         H04 0709
   Coding: 140E00
   VCID: 3664AEE089EC9C26A9-8062
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 002201
   VCID: 68D830989BD83AD6EB-803C
Address 20: High Beam Assist. (J844)       Labels:. 8S0-857-511.clb
   Part No SW: 7E0 857 511 F    HW: 7E0 857 511 C
   Revision: AA001001
   Coding: 0404000000000000010000
   Shop #: WSC 02739 790 50316
   ROD: N/A
   VCID: 2D56818C7CBADFFED8-8078
No ASAM data for: "EV_HighBeamAssisAU316" (VW25)
   Component: IMMO          H04 0709
   Serial number:
   Shop #: WSC 09402 015 1048576
   ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
   VCID: 6ADC4A908DD408C6FD-803E
Address 37: Navigation
Cannot be reached
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R1 909 144 AJ    HW: 6R1 909 144 E
   Component: EPS_TRW_ALow  312 3132
   Serial number: CF8D0787 Dataset Number: 8XA909852D  0019
   Coding: 000300
   Shop #: WSC 00046 412 54321
   ASAM Dataset: EV_SteerAssisUDSTRW 016029
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 7F0A8BC4E6569D6E3A-802A
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0000022 Dataset Number: 0001
   ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
   ROD: EV_AudioVerst10KanalSTT4_VW36.rod
   VCID: 285870985358FAD62B-807C
2 Faults Found:
9462035 - Front Left Treble Speaker
          B1061 13 [00001001] - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 12
                    Mileage: 130617 km
                    Date: 2024.05.21
                    Time: 00:01:33
9462803 - Front Right Treble Speaker
          B1064 13 [00001001] - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 12
                    Mileage: 130617 km
                    Date: 2024.05.21
                    Time: 00:01:33
   Revision: --------    Serial number: -------------- Dataset Number: 6R0036v____ 0005
   Coding: 011A000001000000
   VCID: 77FA63E4CE66A52E72-8022
   Component: MU-S-ND-ER    H41 0478
   Serial number: VWZAZ2U0997762 Dataset Number: V03935266VJ 0001
   Coding: 02620001AA00000011111103C00D0A201F0110D400200100CE
   Shop #: WSC 00012 790 50316
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 254679AC244AE7BE10-8070
   Data carrier:
   Subsystem 1 - Part No SW: 5NA 919 866 BK    HW: -----------
   Component: ECE AS 2022  --- 1720
3 Faults Found:
1555 - Check Software Version Management
          B201A 00 [00001001] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 15
                    Mileage: 130620 km
                    Date: 2024.05.23
                    Time: 20:42:15
                    Voltage terminal 30: 12.4 V
                    Status_Software_Version_Management-module_name:
1556 - Internal Control Module Memory Check Sum Error
          B2000 87 [00001001] - Missing Message
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 15
                    Mileage: 130620 km
                    Date: 2024.05.23
                    Time: 20:45:13
                    Voltage terminal 30: 12.5 V
                    System_Software_Error-SW_Status_Consistency: 04 01 01
                    System_Software_Error-SW_Status_Device: o
15360256 - Component Protection
          U1101 00 [00001001] - Active
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 15
                    Mileage: 130620 km
                    Date: 2024.05.23
                    Time: 20:42:15
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 032B7A64
   Shop #: WSC 12345 123 12345
   Subsystem 1 - Part No SW: 6R0 915 181 E    HW: 6R0 915 181 E
   Component: J367-BDM  H08 0181
   Serial number: 50231J15312031943146
End-------------------------(Elapsed Time: 03:36)--------------------------
The oil pressure switch is probably just faulty, so I'll fire the parts cannon at it. The part is cheap and I don't feel like checking wires.
The HVAC fault is expected, since I haven't filled the AC system back up yet.
The sound system is indeed missing the two treble speakers, I have to repair the bloody A-pillar-covers... again.
And the MIB-PQ unit is complaining about that stuff since I installed it, but is working absolutely flawless. So whatever.
All in all: I am almost done. Incredible... :shock:
Paulpelz
Post by Paulpelz »
A few days later, and nothing changed. Well, that's not completely true. I fixed a knocking in the steering assembly (it turned out we forgot to tighten the nuts of the tie rod ends... whoops :lol: ), also I installed the underbody covers and fiddled a bit with the exhaust, so that it doesn't touch the heatshields anymore. Though I am still not completely satisfied with the result as the tips don't sit absolutely perfectly in the middle of the bumper cutout... that's a later problem.
Concerning the start-stop-button I still haven't found the solution. Start-Stop itself is working on the other hand, so I might just procrastinate on that problem a little bit. For the technical inspection it just has to work at all.
Now my question for the day: Is there a possibility to test the 2-Cylinder-Mode on the car? I mean: other than to actually drive and accidentially stumble across the narrow area where it will switch the two cylinders off? Maybe a VCDS readout or something? Because I don't know if my instrument cluster will display the message, since it is out of a Toledo... :shock:
Paulpelz
Post by Paulpelz »
Paulpelz wrote: Wed May 29, 2024 2:35 pm Concerning the start-stop-button I still haven't found the solution. Start-Stop itself is working on the other hand, so I might just procrastinate on that problem a little bit. For the technical inspection it just has to work at all.
Wrong. I couldn't leave it alone. And it turns out I'm an idiot.
I wired negative cables to two pins that should have +12 volts. I have absolutely no idea how I f*cked this up. I'll fix it tomorrow and report again!
Paulpelz
Post by Paulpelz »
Hi! Here's a little update from my car...
First of all: I finally got my MOT scheduled for thursday, so it's getting real. I got the start-stop-button working and my instrument cluster is now showing when my engine goes into the 2-cylinder-mode.
Thus, there are two problems remaining, that I hope to be able to fix beforehand. I would love to hear your ideas:
1. I still have the P164C00 fault code stored in the ECU. Replacing the oil pressure switch for reduced oil pressure sadly didn't help. Annoyingly it's an intermittent fault, so finding the cause is difficult...
I heard of two possible solutions: Maybe the other oil pressure switch, the one for the high pressure isn't working properly so as a result the reduced pressure one doesn't have a reference value, which might cause the fault. The other possible cause I read about was that that the oil pressure regulating valve isn't working properly. Interestingly, this was one of the parts on the engine I had to buy a replacement for, since the one on the engine was damaged. I had bought a cheap and used one, so maybe this one is actually bad. Do you guys have any other ideas?
2. I noticed my auto leveling headlights aren't working properly. I retrofitted the OEM LED headlights, similar to iichel. Since my last autoscan I changed my coding of Adr. 55 to iichels coding (011A000001000000 --> 0192000001000000) and got it working to a point, where there are no faults. I also was able to perform the basic setting of the headlights and they are regulating when I put weight on the back of the car. BUT: They are regulating in the wrong direction! When the back of the car goes down, the headlights regulate up! I am a bit stumped on what might cause it. Today, I will try to measure my wiring to the sensor (Maybe I accidentially switched two wires?). Also I will try a different control module. Maybe the one in my car has some secret changes in the adaption values that might cause that... Has anyone else an idea?
you probably have an AFS module for bixenon and LED headlights? so parameters are wrong
Paulpelz
Post by Paulpelz »
Might very well be the case. Is there a way to change it with VCDS? And if yes, what do I change it to?
i think vcds can not write parameters, it must be done with vcp or odis. you'll need to get a parameter file or perhaps even a new module. it got mine via firegrafik from russia. it works perfectly
