Need help on Side Assist
sejuani
Drives: POLO 6R
Post by sejuani »
Hellow everyone,
I'm sejuani from Taiwan.
I have a POLO 6R 1.6 105hp CLSA hatchback.
Thanks to the information given by masters like ciclo and iichel on this forum,
I have successfully installed Alarm Horn, Boots Lights, Cruise Control, DRL, OPS and RLHS myself
Now, I want to install 3C-Lane Change(side assist) but stucked at some processes
At present, I have finished following steps:
1. Upgrading the instrument cluster from Midline to MFA (6JA 920 940 C SW 0709)
2. Editing the instrument cluster EEPROM, Activating Lane Assistance and Side Assistance
3. Installing the BSD module and Wiring (Not include indicators, still need some time)
2. Coding, 03 01 11 02
3. Chacking 3C-Lane Change in 19-CAN Gateway install list
4. Updating the BSD module HW(5Q0 907 686 C 0080) to 0081
5. Filling the parameterization V03935276UZ
6. Activating the Analysis 4 in adaptation channel(with entering the access code 20103)
7. Auto calibration to 100%
Eventhouhg I have completed the previous steps, I still cannot see Side Assist on my instrument cluster.
After seaching information on this forum and drive2, I come up with 2 possible solutions
First,changing BCM from 087 to 090 or 18D 937 087(unconfirmed information from china forum)
Second, changing radio from RCD330 to discover media
Or if there is any other possible solution that I have missed?
I'll be really appreciated if anyone can give me some advices.
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CLSA)       Labels:
   Part No SW: 03C 906 014 FR    HW: 03C 906 014
   Component: CLSA-MM7GV-G  H02 8635
   Revision: --H02---    Serial number:
   Coding: 001A0014022400000000
   Shop #: WSC 12345 123 08192
   VCID: 72E1870AAEAF28DFAA-5178
Readiness: 0010 0001
Address 02: Auto Trans        Labels: 09G-927-750.clb
   Part No SW: 09G 927 750 LK    HW: 09G 927 750 LK
   Component: AQ 250 6F           2601
   Revision: 00H98000    Serial number:
   Coding: 0000328
   Shop #: WSC 00000 000 08192
   VCID: 050BCCD64F212F679F-5178
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.lbl
   Part No SW: 6R0 907 379 CB    HW: 6R0 907 379 AS
   Serial number: --------------
   Coding: 61DD2463422603C2861A246E4259C0400809
   Shop #: WSC 00049 770 08192
   VCID: 0005DDC29B030A4FAC-8054
   Serial number: 02081613470700
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF9A33AE1F77CBFDE-802A
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 418318C6D889C347E3-8014
   Part No SW: 6RU 937 087 P    HW: 6RU 937 087
   Component: BCM IM H+4    H41 0444
   Revision: BZ041001    Serial number: 8700 110170564
   Coding: 3AB02FF808F36E00B33800006DAB969000C860FF608E0100220000000A00
   Shop #: WSC 124697 483 00190
   VCID: 6FE78E7EBE9D053745-803A
   Component: RLHS 091221 0  50  0107
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 EC    HW: 6R0 959 801 EC  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  023 2551
   Serial number: 13102851160307203215
   Coding: 640000
   Subsystem 3 - Part No SW: 6R0 959 802 EG    HW: 6R0 959 802 EG  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  023 2551
   Serial number: 13102850160217193348
   Coding: 640000
   Subsystem 4 - Part No: 6RU 951 171
   Component: Sensor, DWA 0  005 0502
   Subsystem 6 - Part No: 6RU 951 171
   Subsystem 7 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Serial number: 0431722560500067AB2B
   Coding: 240000
   Subsystem 8 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
   Component: J388__TSG_HL  022 1552
   Serial number: 13202728170223141457
   Subsystem 9 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
   Component: J389__TSG_HR  022 1552
   Serial number: 13102729170223103338
   Part No SW: 7E0 919 475 L    HW: 56D 919 475
   Component: PARKHILFE 8K  H02 0106
   Revision: --------    Serial number: 35841522901332
   Coding: 308001
   Shop #: WSC 01681 002 104857
   VCID: 3B7F6A2EB265A997B9-806E
   Component: VW10AirbagU0J H10 0020
   Revision: --------    Serial number: 003GW019WCZB
   Coding: 00304A
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 499300E6E8B90B073B-801C
   Part No SW: 6JA 920 940 C    HW: 6JA 920 940 C
   Component: KOMBI         H05 0709
   Coding: 141800
   Shop #: WSC 73430 031 00209
   VCID: 3C7D6932B76BAEAFB0-8068
Address 19: CAN Gateway (J533)       Labels:
   Part No SW: 6RU 909 901     HW: 6RU 937 087
   Component: GW-K-CAN TP20 H41 0444
   Revision: BZ041001
   Coding: 002204
   VCID: 193390A61099BB874B-804C
   Component: IMMO          H05 0709
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD19F6A8D7FE01F12-803E
Address 3C: Lane Change (J1086)       Labels:. 5Q0-907-686.clb
   Component: HRE_Master    H12 0081
   Serial number: 0484698770
   Coding: 03011102
   Shop #: WSC 00046 123 12345
   ROD: no
   VCID: 3D7B6436AC71A7A787-8068
No ASAM Dataset: "EV_HREntryHella" (VW25)
   Part No SW: 1S1 909 144 P    HW: 1S1 909 144 P
   Component: EPS_ECU       H51 1702
   Coding: 0001000101000000
   Shop #: WSC 33930 004 1048576
   ROD: EV_SteerAssisNSK_014.rod
   VCID: 40851DC2DB83CA4FEC-8014
   Component: MIB2-S-R-CN   036 0358
   Revision: -----001    Serial number: VWZ6Z2Q7089808
   Coding: 1E000440040000
   Shop #: WSC 00081 790 00126
   VCID: 46890BDAF1A7E47FD6-8012
Re: Need help on Side Assist
Interesting, SW 0709 was ok for my cluster menu.
patil
Post by patil »
@ sejuani welcome! nice to see a detailed post.πŸ‘Œ
It's highly likely that your present gateway (6RU) won't support side assist. 7E0 gateway( 7E0 BCM's) definitely supports it. And also, Discover media/ composition media is required for rear traffic alert (RTA) guide lines to work. I don't think DM/CM is required for side assist to work, but I am not 100% sure.
Unless you have a working side assist menu in cluster to activate side assist, there is no way you can have working side assist even though you have done complete installation.
I would start looking at your edited eeprom dump to begin with. Please share your edited IC eeprom dump here. Upload it to some file hosting site and post the link here. Thank you
sejuani
Drives: POLO 6R
Post by sejuani »
iichel wrote: Wed May 22, 2024 12:01 pm Interesting, SW 0709 was ok for my cluster menu.
patil wrote: Wed May 22, 2024 6:30 pm @ sejuani welcome! nice to see a detailed post.πŸ‘Œ
Thanks for your reply, I'll buy a CH341A Programmer first and try to load my EEPROM.(Actually, the EEPROM editing above is done by my friend)
So, I need to check 0454, To activate side assist, bit 0 must be 1, is that correct?
Edit, updated!πŸ™
Side Assist indication, instrument cluster non-3D. MaDwArLoCk IC :arrow: https://a.d-cd.net/PyAAAgCH-uA-1920.jpg , https://www.drive2.ru/l/531400018091835697/
02DB ... enable bit1
Side Assist indication, instrument cluster 3D.
02F6 ... from 18 to 98 ... enable bit7
Side Assist menu.
0454 ... from 10 to 13 ... enable bit0 and bit1
til3tsio
Drives: Seat Toledo KG
Post by til3tsio »
sejuani wrote: Thu May 23, 2024 2:59 pm
In my 6JA cluster , when I had software 0711 I had to change x0454 from 20 to 13 (it disables PDC menu), 23 or 33 does not work , you must disable pdc menu bit !
and if you solder the 2 leds and the other components for the indicators in your cluster, change x02db from 80 to 82 (bit 1 on) and make sure x02f9 bit 1 is on (7e in my case).
sejuani
Drives: POLO 6R
Post by sejuani »
First, I want to thank iichel, patil, ciclo and til3tsio again.
After long time waitting, I received my CH341A for loading EEPROM few days ago.
I follow your suggestions to check 0454 and change from 21 to 13.
Guess what?It works!
I am so glad to see Side Assist menu finally show up on my cluster :D :D :D
patil
Post by patil »
Excellent πŸ‘
Now we know that 6RU gateway does support side assist.πŸ‘Œ
When I did the installation of side assist in my 6R, I didn't have to edit eeprom to enable the side assist menu in my Polo gti cluster (sw 805). The side assist menu along with the RTA menu ( DM previously installed) appeared automatically. This means that, both the menus are activated by default in my cluster.
Out of curiosity, I checked my IC eeprom dump today. The byte address 0454 value is "10" instead of expected "13".
Probably the side assist menu byte address is different in Polo gti clustersπŸ€”
My 6R GTI IC eeprom (original).
The eeprom address for the Side Assist in the 0805 SW 6R GTI IC 2015-->... is the same as the same eeprom models.
From what I have been able to observe, the Side Assist, Lane Change, BSD, RTA, RCTA, Brightness intensity, will appear on the different MFD screens depending on the radar models installed, and it may appear in several menus/screens so that it is fully accessible.
@Patil
Do you also have access to side assist from the MFD main menu? Or only from the assistants menu?
The darkness confuses us... :lol:
til3tsio
Post by til3tsio »
Let me write down my observations.
I have used on my Toledo 6J instruments many different firmwares to test them out.
I have tested 06xx, 07xx, 08xx, 100x, 11xx from different pq25 vehicles.
I have 5q0..C radars and for the rear traffic alert menu to appear you have to use a firmware that is 08xx or newer, it is dependent neither on radio nor BCM.
In the x454 address staring from 08xx firmware the default is 10 and the menus appears without editing, also on transporter 1xxx eeprom I have seen 14 and the menu also appears.
All these test were done using firmwares that are available online on the "disks" except the 1009 amarok together with the vdo editor libraries.
Almost 2 years now am using 1009 amarok firmware and everything was working but a few weeks back the blindspot menu that is located in settings > assistants disappeared but everything is still visible on the MFD assistants specific page and I have no clue what is wrong.
In relation to the loss of the BSD menu in the settings menu, you already know that due to very diverse and different reasons, communication failures occur between units, consequently wrong messages are generated, which can partially or completely disable the functions of the units involved.
I assume you have scanned your car to find out something about it.
Have you recently noticed any malfunctions with your radars? False detecctions/positives.
Have you done any other retrofitting recently? :)
Have you tried to remove the negative battery ('hard reset') to see if you can recover it?
til3tsio
Post by til3tsio »
Blindspot is still working as it should and it is still available on MFD assistants screen and I can toggle activation normally.
But assistants menu is not available in settings screen anymore.
The only error that I have is on pdc because I have a 1k8 unit and I have already tried "hard resetting" the car, also nothing changed in the car to trigger the loss of the menu.
In the bottom line if I can still see it from the main screen and it is working ok I don't mind , but I am just wondering how it disappeared from settings
patil
Post by patil »
ciclo wrote: Sun Jun 09, 2024 3:46 am
@Patil
I have the side assist option only in assistants as I shown in the above post. In the main menu, after installing 1K8 OPS module, I got a separate menu for park assist through which I can enable or disable auto 8K ops.
@til3tsio thank you for additional information.πŸ‘
I guess all these assistants display on MID depend on IC firmware, Gateway version, Radio MIB models etc.. which will have different communication protocols with involved modules.
OK, thanks Patil.πŸ‘
I exactly wanted to know if 'Assistants' appeared in the settings/main menu, ... in addition to the Assistants menu.
To understand us, without the BSD radars installed (at this time), I do not have the 'Assistants' in the settings, however, I have the Assistants menu where is the Driver Alert.
patil
Post by patil »
@Patil
Apologies for sharing incomplete information, my bad🀭
I do have separate blind spot sub menu inside the assistant menu in settings. I can access side assist in both settings as well as in the main screen.
πŸ™
Return to β€œMK8 and MK9 (6R/6C) Polo (inc GTI) - Years 2009-2017”
