RLS and Autolight Retrofit
Tinman
Drives: Polo 6C 1.0 Litre R Line 110hp
Post by Tinman »
Hi, Im trying to retrofit RLS and Autolight to my car, my bcm is 6C0937089 and software version c. Correct me if im wrong, its my understanding that i need to connect a wire from T10/2 to T73a/43 for the auto function in the rotary switch to function? Its ok to use OE000979009E repair wire for this task, if not could someone point to the connect wire and terminal pins for this task. Thank in advance.
Re: RLS and Autolight Retrofit
You'll need a wire with a micro quadlock system connector and 0,35mm2 or higher diameter. Pin numbers are correct.
Tinman
Post by Tinman »
Hi, Turn out pin 2 of the rotary light harness is already wire, i was stupidly looking at pin 7 beforehand which was empty, Bought orignal switch with auto option, wire RLS ( 5Q0955559B) and coded, auto low beam work as expected but the coming and leaving home function is not working. Ive enable the setting in longcode byte 10 and adapation comfort illumination. Is there any other setting i need to do for it to work? Any help would be great, thanks in advance
Tinman
Post by Tinman »
I got coming home and leaving home working, thanks to old ross auto forum post from a member called iichel not sure if that the same iichel from this forum :mrgreen:
sure sounds like it
Tinman
Post by Tinman »
Hi, after finally fit the RLS on the windscreen and tests for a week, i find the RLS is very sensitive, auto low beam keep switch on in every over pass no matter how long the pass is. I try changing the value on those adaptations:
RLS_Night_Sensitivity -> p_lx_rs_day
RLS_Night_Sensitivity -> p_lx_rs_dawn
RLS_tunel_gateway_recognize
Assistance Light Functions -> Lichtsensorempfindlichkeit
RLS longcode byte 1 (low value less sensitive?)
I still find it to be very sensitive. My BCM is 6C0937089C and RLS is 5Q0955559B. If there other adaptation or setting i should look at? Could it be RLS module is the problem if so what is a better RLS module i can use?
