Active TPMS on PQ26?
Bepis
Drives: 2017 6C GTi Manual
Post by Bepis »
As the title says I'm just seeing if it's possible to retrofit an active TPMS system to PQ26 platform vehicles (6C) as from what I understand no PQ26 platform vehicle had it from the factory but the retrofit to PQ25 (6R) is fairly well known.
Any info or ideas?
Re: Active TPMS on PQ26?
I'd start with checking if the gateway supports address 65
Bepis
Post by Bepis »
My gateway has address 65 :D
BCM
6C0 937 089 D
Gateway
6C0 909 901 A
IC - MFD
6C0 920 946 C
Head-unit
MIB2STD2 | 3Q0 035 842 B
I'd probably go with the 5Q0 TPMS unit and see what happens. Wiring is easy.
Bepis
Post by Bepis »
I'm assuming you're referring to 5Q0 907 273 B antenna/module and 5Q0 907 275 B pressure sensors?
Please Bepis, read it :arrow: https://www.drive2.ru/l/616081105128261542/
The Goofle translator works quite well for both English and Spanish.
The PQ26 platform was something radical and I think something unexpected.
Bepis
Post by Bepis »
Seems it may not be possible on PQ26 :(
Due to the constant presence of an error regarding the absence of a message in block 65, a verdict was made - there is no support for the RDKS protocol in the BCM blocks/gateways of the PQ26 platform :(
giannis20vt
Post by giannis20vt »
ciclo wrote: Mon Jun 24, 2024 4:21 pm Please Bepis, read it :arrow: https://www.drive2.ru/l/616081105128261542/
Excellent thread. Thanks for the link Fernando.
Bepis wrote: Mon Jun 24, 2024 8:53 pm Seems it may not be possible on PQ26 :(
Yeah. I know that you in particular would appreciate the information about the active TPMS on your MFD.
I feel sorry for you, accompany you in disappointment.🤗
@giannis20vt, yes, it's an excellent job.💎👌
