As the title says I'm just seeing if it's possible to retrofit an active TPMS system to PQ26 platform vehicles (6C) as from what I understand no PQ26 platform vehicle had it from the factory but the retrofit to PQ25 (6R) is fairly well known.
Any info or ideas?
Active TPMS on PQ26?
Re: Active TPMS on PQ26?
I'd start with checking if the gateway supports address 65
Bepis
- Drives: 2017 6C GTi Manual
My gateway has address 65
BCM
6C0 937 089 D
Gateway
6C0 909 901 A
IC - MFD
6C0 920 946 C
Head-unit
MIB2STD2 | 3Q0 035 842 B
BCM
6C0 937 089 D
Gateway
6C0 909 901 A
IC - MFD
6C0 920 946 C
Head-unit
I'd probably go with the 5Q0 TPMS unit and see what happens. Wiring is easy.
Bepis
I'm assuming you're referring to 5Q0 907 273 B antenna/module and 5Q0 907 275 B pressure sensors?
Please Bepis, read it
https://www.drive2.ru/l/616081105128261542/
The Goofle translator works quite well for both English and Spanish.
The PQ26 platform was something radical and I think something unexpected.
Bepis
Seems it may not be possible on PQ26
Due to the constant presence of an error regarding the absence of a message in block 65, a verdict was made - there is no support for the RDKS protocol in the BCM blocks/gateways of the PQ26 platform
giannis20vt
Excellent thread. Thanks for the link Fernando.ciclo wrote: Mon Jun 24, 2024 4:21 pm Please Bepis, read ithttps://www.drive2.ru/l/616081105128261542/
Yeah. I know that you in particular would appreciate the information about the active TPMS on your MFD.Bepis wrote: Mon Jun 24, 2024 8:53 pm Seems it may not be possible on PQ26
I feel sorry for you, accompany you in disappointment.
@giannis20vt, yes, it's an excellent job.
