Armrest question
ElAlastair
Drives: 6C
Armrest question
Post by ElAlastair »
Long story, a VW garage took some screws out of my centre armrest when trying to stop an annoying rattle and never put them back. It’s a lost cause now. Does anyone know what kind of screws go where I’ve indicated?
This is the part https://www.lllparts.co.uk/product/6R08 ... itan-black but I can’t find anything about the screws.
Thanks.
Re: Armrest question
Post by 2226 »
Don't think those are sold separate from the arm rest box.
Nothing shows on ETKA.
However, most trim screws around there 4,2x16 with part number N 906 986 06.
Given the round indentation left behind I would venture to say those are the correct ones to use.
I will check my car in a bit and see what's there.
2226
Post by 2226 »
Actually, no, those are not 4,2x16.
Just checked. Can't see nothing in the garage right now with bad lighting.
Actually don't think there's anything there, but will check this evening.
ElAlastair
Drives: 6C
Appreciated! I tried taking out the ones where the hinge is but they were far too big.
2226
Post by 2226 »
Interesting. I have no idea what's under there.
The felt lining seems glued to them. Not too sure I want to dig these out, but no harm if I need to (I think).
Seem to be small hex or torx head, but the lining doesn't help.
You sure there's nothing under there?
2226
Post by 2226 »
So you're not missing any screws. They're in there. It seems they applied the flock to the screw heads as well.
Torx T20
M4.2x5
Overall length 7.8mm, so 8mm long.
Countersunk head, diameter about 7.2mm
Didn't check thread pitch though.
ElAlastair
Drives: 6C
Oh really. I could’ve sworn it looked different but maybe I was confused by the tape they stuck all over the armrest to stop the rattle.
Thanks very much for going to all that effort.
2226
Post by 2226 »
No problem.
At least my curiousity was satisfied as well.
You never know what you don't know, so there you go, now you know.
