Polo 6R - Sanket's 1.0 TSI
SanketM
Drives: VW Polo 1.0 TSI Highline Plus
Re: Polo 6R - Sanket's 1.0 TSI
Post by SanketM »
I finally got the C version of AFS Yesterday.
After installation, I updated the AFS code to the one used & shared by iichel and height adjustment worked right away :D. Thank you iichel 🙏
And a big thanks to Ciclo for guiding me in the right direction 🙏❤️
36-Seat Mem. Drvr -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
Address 01: Engine (J623-DSHA)       Labels: None
   Part No SW: 04C 906 026 CJ    HW: 04C 907 309 AG
   Component: R3 1.0l TFS   H22 1621
   Revision: WTH22---    CVN: FCB89011
   Coding: 001A0012232410000000
   Shop #: WSC 07726 005 104857
   ASAM Dataset: EV_ECM10TFS01104C906026CJ 002003
   ROD: EV_ECM10TFS01104C906026CJ.rod
   VCID: 6BD572AB8285F9CB06-803E
   VINID: 755A1D08018025D901044244208FC59082
Readiness: 1110 0001
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 09G 927 158 FB    HW: 09G 927 158
   Component: AISIN AG6 G3  202 3724
   CVN: AC17BF15
   Coding: 0000000000000000010000000000000000000000
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_TCMAQ250031 003021
   ROD: EV_TCMAQ250031_003_VW25.rod
   VCID: 78FF5DE7C3D34253FB-802C
   Part No SW: 6R0 907 379 CB    HW: 6R0 907 379 AS
   Serial number: --------------
   Coding: 62DD2863422403C4461D146D4259C0800808
   Shop #: WSC 12345 123 12345
   VCID: 000F35079B030A93C3-8054
   Serial number: 09092013470170
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF34BFFE1F77C63B1-802A
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 4189F003D889C39B8C-8014
   Revision: B9084001    Serial number: 2502 306190003
   Coding: 3AB02BF848A10000013806F67EEB9E90FFC0670F608C2101230000020000
   Shop #: WSC 00046 123 12345
   VCID: 2D51BCB3741137FB58-8078
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 030720 05  50  0106
   Coding: 0368DD
   Subsystem 2 - Part No SW: 6R0 959 802 EF    HW: 6R0 959 802 EF  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  023 2551
   Serial number: 13202848200915172242
   Coding: 350000
   Subsystem 3 - Part No SW: 6R0 959 801 ED    HW: 6R0 959 801 ED  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  023 2551
   Serial number: 13102849200915195602
   Coding: 040000
   Subsystem 4 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Serial number: 2532005083600332AB2B
   Coding: 240000
   Subsystem 5 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
   Component: J388__TSG_HL  022 1552
   Serial number: 13102728200824232744
   Subsystem 6 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
   Component: J389__TSG_HR  022 1552
   Serial number: 13202729200825011617
Address 15: Airbags (J234)       Labels:. 6C0-959-655.clb
   Part No SW: 6C0 959 655 Q    HW: 6C0 959 655 Q
   Component: Airbag VW12   001 0503
   Revision: --------    Serial number: 003FZAEVZ14J   Dataset Number: V03935319CK 0001
   Coding: 880000000000000054000000008000000065
   Shop #: WSC 01383 785 00200
   ASAM Dataset: EV_AirbaVW12TS6VW25X 001001
   ROD: EV_AirbaVW12TS6VW25X_VW25.rod
   VCID: 4189F003D089C39B8C-8014
No ASAM data for: "EV_AirbaVW12TS6VW25X" (VW25)
   Part No SW: 6R0 920 870 F    HW: 6R0 920 870 F
   Component: KOMBI         H04 0729
   Coding: 140E00
   Shop #: WSC 00078 790 12345
   VCID: 387F9DE7835382533B-806C
   Revision: B9084001
   Coding: 002300
   VCID: 68DF0DA79B73D2D36B-803C
   Component: IMMO          H04 0729
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6ADB77AF8D7FE0C37D-803E
Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760 B    HW: 3C8 959 760 B
   Component: Sitzmemory    H02 1001
   Revision: 00H02000
   Coding: 000039
   VCID: 3467A9D7973B663317-8060
3 Faults Found:
01901 - Lumbar Support Height Adjustment Motor (V229)
            005 - No or Incorrect Basic Setting / Adaptation
                    Fault Status: 01100101
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 118
                    Mileage: 114999 km
                    Time Indication: 0
                    Date: 2025.01.23
                    Time: 06:49:14
            014 - Defective
                    Fault Status: 01101110
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 118
                    Mileage: 114999 km
                    Time Indication: 0
                    Date: 2025.01.23
                    Time: 06:49:14
00003 - Control Module
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 118
                    Mileage: 114999 km
                    Time Indication: 0
                    Date: 2025.01.23
                    Time: 06:49:14
Address 37: Navigation
Cannot be reached
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Dataset Number: V03935277QZ 0001
   Coding: 0001000000000000
   ROD: EV_SteerAssisNSK_014_VW12.rod
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Revision: --------    Serial number: -------------- Dataset Number: 0002
   Coding: 0D4A000001000000
   ROD: EV_HeadlRegulVWLWRCC.rod
   VCID: 3A7B87EFBD5F9043CD-806E
1 Fault Found:
5275220 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Fault Status: 00000001
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 41965 km
                    Date: 2024.07.01
                    Time: 21:18:59
   Part No SW: 5C0 035 680 F    HW: 5C0 035 680 F
   Component: MU-S-N-ER     H44 0480
   Serial number: -------------- Dataset Number: V03935270BD 0001
   Coding: 0262000EBE0000005111000601080A001F0100D601200100CE
   Shop #: WSC 12345 102 209715
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 244759972FDBF6B387-8070
   Data carrier:
   Subsystem 1 - Part No SW: 5NA 919 866 EA    HW: -----------
   Component: MRM2 2024  --- 2110
9 Faults Found:
1555 - Check Software Version Management
          B201A 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 41965 km
                    Date: 2024.07.01
                    Time: 21:17:19
                    Voltage terminal 30: 12.0 V
                    Status_Software_Version_Management-module_name:
          U1101 00 [009] - Active
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 41965 km
                    Date: 2024.07.01
                    Time: 21:17:20
0545 - Audio signal output 1
          B14F1 01 [009] - Electrical Failure
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 41965 km
                    Date: 2024.07.01
                    Time: 21:17:22
0549 - Audio signal output 2
          B14F2 01 [009] - Electrical Failure
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 41965 km
                    Date: 2024.07.01
                    Time: 21:17:22
0553 - Audio signal output 3
          B14F3 01 [009] - Electrical Failure
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 41965 km
                    Date: 2024.07.01
                    Time: 21:17:22
0557 - Audio signal output 4
          B14F4 01 [009] - Electrical Failure
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 41965 km
                    Date: 2024.07.01
                    Time: 21:17:22
2565 - GPS Antenna
          B1054 13 [009] - Open Circuit
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 41965 km
                    Date: 2024.07.01
                    Time: 21:17:20
7178 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 41965 km
                    Date: 2024.07.01
                    Time: 21:17:22
                    BAP-BAP_Function_ID: 02
0001 - Antenna 1 for Radio
          B1119 13 [009] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 41965 km
                    Date: 2024.07.01
                    Time: 21:17:20
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 03:14)--------------------------
SanketM
Post by SanketM »
Hi guys,
I am preparing to retrofit the lane change change assist in my little 6R. Having done some research I have understood that one could go for 3 different options of radars.
1) 7E0
2) 5Q0
3) 2Q0
Feature and accuracy wise is there any difference or advantage of choosing one over the other? while In terms of availability and cost 2q0 and 5q0 seem readily available and cheaper while 7e0 is difficult to find & costly too.
~Sanket
From what I can guess from the information and experience at my disposal, the 2Q0 radars for the MQB platform or new models (2018 --->) provide better performance when interacting with other driving assistance systems, but I do not think there will be major differences with the 5Q0 radars if they are installed on the PQ25.
Both radars work equally well, choose the ones that will be easiest to install/program to you.🤷‍♂️
I guess you already know that I am now on the Lane Change project for my 6R. If you are patient enough to wait a month or maybe a little longer for me to finish it, I can assure you that you will make the right decision about which parts to use, both the radars and the BSD warning lights.
I have not yet revealed a secret in my LC project that, in addition to being unexpected, is devilishly perfect!!! 💎😮 (already tested 🧙‍♂️)
I don't usually reveal my 'special' ideas until the final results. 🤭
SanketM
Post by SanketM »
Thank you so much Ciclo, I was leaning toward the 2Q0 set because they were newer and easily available. But I am unsure of parameterising it correctly & mounting it as it's a path less travelled.
I am indeed closely following your LC project. The level of detail you have gone through testing different BSD warning lights is amazing. I'll keep up with your updates and look forward to you revealing the surprise :D. Till then I'll holding off my purchase of radars.
Sanket
SanketM
Post by SanketM »
Hi Guys,
I am catching up after a long time. A lot has happened since my last update on this thread.
1) Auto folding ovrm
2) Golf 8 Steering / CCE
3) Upgrade to the front brakes to 288MM on the 17" Skoda Vega alloys & the judder.
4) GTI Interiors
5) TPMS
6) Front seats re-upholstered
And a whole host parts lying around for planned upgrades
1. Fix the Horn Terminal.
2. Passat B7 Seat heating.
3. OVRM heating
4. Passenger door handle new handle to lock all doors.
5. Dynaudio Speakers (1K8)
6. HBA (7E0)
7. Rear Footwell Lights
8. 2QO BSD
9. Interior Alarm
10. Interior new Lights connection for the front, rear, boot & Sunvisor
11. DCC
12. 8k OPS
13. Kessy.
14. Dynamic 6c Flip Camera with a CAN converter.
15. central console button wiring for all buttons.
16. Connector for CCE (Wiring)
17. A new DIN65 battery
18. Driver side grab handle.
19. Fix Fuse Box Cover
20. Cigrette lighter ring.
21. Frameless wipers
Starting in September ’24, I managed to source a suitable steering airbag locally for the Golf 8 steering wheel and was finally able to install the CCE I received from our fellow forum member Madwarlock. It worked flawlessly from the start, but I wasn’t completely satisfied with the installation, as it was done hastily due to an upcoming trip. I had been eagerly waiting for this upgrade for nearly 1.5 years. (During the process of obtaining the Golf 8 MFSW, I was even scammed by a seller in Portugal for a substantial amount.) The mechanic I consulted ended up soldering the wires. 🫣 At last, I had the steering wheel functioning properly along with the paddle shifters.
Next, I had my Passat seats re-upholstered since they were in poor condition. Now, I finally have a comfortable seat to relax in. These seats proved invaluable during the recent Indian summer, where temperatures soared to 40 degrees Celsius, made even more intense by humidity exceeding 90%.
In October ’24, I purchased a new 5Q0 TPMS antenna from a Chinese seller on AliExpress with the intent to flash it with the 3AA firmware, as the genuine 3AA antenna with the “F” suffix was prohibitively expensive. At the same time, I bought a set of 3AA TPMS sensors. I installed everything, but the antenna refused to flash using ODIS or VCP. After researching, I discovered I wasn’t alone—others reported the same issue on drive2.ru with no known fix. The antenna could not detect the 3AA sensors, and even if it did, my cluster, running firmware 0729, likely wouldn’t display it.
This particular TPMS antenna was advertised as compatible with the MQB platform, but we also tested it on a 2019 Skoda Superb, where it failed as well. So, when buying TPMS antennas from Chinese sellers, be sure to do thorough research.
A few days later, I found and purchased a genuine 3AA907273B antenna. By then, the tire pressure sensors were already installed during routine tire rotation. I managed to flash the new TPMS module from firmware B to D using ODIS, but I still can’t get it to update to firmware F, no matter what I try. This is a Beru unit with specific hardware.
3AA Antenna.png (209.39 KiB) Viewed 5512 times
In December ’24, thanks to advice from our guru Ciclo, I was able to source the correct WRMs. Now, I can enjoy auto-folding OVRMs along with the comfort closing feature for the windows.
[youtube]https://www.youtube.com/shorts/txcytAWfZZk[/youtube]
Between December ’24 and February ’25, I installed a new set of Brembo drilled front rotors. However, during installation, we found that the 288mm calipers were rubbing against the Vega alloys due to offset differences—the stock Portago alloys have an offset of 45, whereas the new 17" Vegas have an offset of 39.
To fix this, we installed 7mm spacers on both the front and rear. After returning the car to me, I noticed a pronounced vibration in the steering wheel at speeds close to 60 km/h, which made me hesitant to drive faster. Eventually, we discovered the alloys were not properly seated on the hub, so we reduced the spacers to 4mm. This resolved the vibration issue.
In March ’25, I found a great set of Polo 6C interior trims, including all the lights and alarm systems. I completed the month with a refreshed interior look. However, there was one issue: Indian Polos don’t come with a driver’s roof grab handle, so there was no mounting bracket. While I wait for the bracket to arrive, the interior is as it is for now. This has been added to my to-do list.
SanketM
Post by SanketM »
Last week, I planned to take my car to an authorized VW service center. Since I’m familiar with the VW service process, I removed the CCE and tried to get the horn working.
First, I attempted to reconnect the two cut ends of the LIN-BUS cable while keeping the ignition key in the ON position, but the horn didn’t respond.
Then, I tried starting the car with the LIN-BUS cables connected to see if the horn would work, but it still didn’t.
The next time I tried to start the car, it briefly started but then stalled, almost as if the immobilizer had activated. My suspicions were confirmed when I connected the ODIS diagnostic tool to the engine module and saw an error message that said something like “Immobiliser active ECU locked.” Additionally, I noticed that every time I tried to start the car, the instrument cluster screen would briefly go dark before lighting back up.
I reached out to a forum member, H2Deeto, to help check the cluster. After testing, I tried starting the car again, but unfortunately, it still stalled.
We then checked the ECU, and I obtained a dump of my MED17.5.21 ECU. H2Deeto kindly compared the immobilizer data from the cluster with the data from the ECU and confirmed they matched perfectly. Despite this, the car continues to stall after starting. My last resort is to disable the immobilizer, but I’m hesitant to do that since I’ve already purchased parts to enable KESSY.
During this time, my car’s battery also drained the next day. Although I charged the battery and cleared all DTCs before running a VCDS scan, errors persist for some modules, indicating voltage below the minimum threshold. I checked all fuses from fusebox slots SB1 to SB10, as well as 14, 19, and 22, and they all appear fine.
I suspect that while trying to reconnect the LIN-BUS cables, I may have incorrectly connected the wrong wires, possibly connecting T41/28 to ground, which might be causing these low-voltage errors. I plan to try using a different battery to see if that resolves the voltage-related faults.
cce-wrong connection.png (418.05 KiB) Viewed 5494 times
Also, I’ve installed an MIB2 Discover Media system with the Green Menu Toolkit to disable the CP check. I’m mentioning this in case it might be triggering the immobilizer issue.
65-Tire Pressure -- Status: Malfunction 0010
   ROD: EV_ECM10TFS01104C906026CG_VW25.rod
   VCID: 6B83C7B123060E829A1-803E
2 Faults Found
17165 - Databus
          U1123 00 [00100111] - Received Error Message
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 0 km
                    Date: 2025.06.10.
                    Time: 00:49:39
                    Engine RPM: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 30 °C
                    Intake air temperature: 30 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 11.320 V
                    Acceleration: 0.000 m/s²
                    Cruise Control System (CCS): status-Bits 0-7: 7
                    Cruise_control_shutoff_conditions_irreversible-Bits 0-7: 0
                    Cruise control system: temporary deactivation-Bits 0-7: 255
                    Accelerator pedal travel: 0.00 %
                    Cruise control switch actuation-Bits 0-7: 0
                    Cruise control switch actuation-Bits 0-7: 32
5523 - Engine Start Blocked by Immobilizer
          P1570 00 [10100111] - -
          [Engine Control Module (ECM) locked]
          MIL ON - Not Confirmed - Tested Since Memory Clear
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 0 km
                    Date: 2025.06.10.
                    Time: 00:49:40
                    Outside temperature: 31 °C
                    Absolute intake pressure: 99 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel: tank fill level: 0.0 l
                    Oxygen sensor B1: sensor 1: specified value: 1.0000
                    Intake camshaft B1 active operating state-Bits 0-7: 0
                    Overrun cut-off-Bits 0-7: 0
   CVN: AC17BF15
   VCID: 78A9E8FD6250B51A673-802C
   Coding: 62DD4863422403C4461D126D4259C0800808
   ROD: EV_Brake1ESP90iBOSCH_003_VW23.rod
   VCID: 0059801D3A80FDDA5F3-8054
   Coding: 01
   VCID: 7EA5FEE540748B2A2DF-802A
1 Fault Found
136194 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 176
                    Mileage: 54435 km
                    Date: 2026.10.03.
                    Time: 00:27:05
                    Voltage terminal 15: 8.10 V
                    Voltage terminal 30: 8.25 V
                    Terminal 15 status: On
                    Entprellzeit: 90000 ms
Address 08: Auto HVAC (J255)       Labels: None
   Revision: V0000000
   VCID: 41DF4519718A34D210D-8014
   Coding: 3AB02BF848A10000013806F67EEB9E90FFC0670F608D3161230400020000
   VCID: 2D0709A9DD12C0B2C45-8078
   Coding: 0380DD
   Subsystem 2 - Part No SW: 6R0 959 802 CH    HW: 6R0 959 802 CH
   Component: J386__TSG_FT  003 9610
   Serial number: KU0KU025091442687578
   Coding: 1400B3
   Subsystem 3 - Part No SW: 6R0 959 801 CF    HW: 6R0 959 801 CF
   Component: J387__TSG_BT  003 9610
   Serial number: KU0KU013011550136865
   Coding: 0400B3
   Subsystem 4 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
   Subsystem 5 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
2 Faults Found
01326 - Control Module for Multi-Function Steering Wheel (J453)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 136
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2025.06.10.
                    Time: 00:16:07
04194 - Vehicle Status with Under-Voltage
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 136
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2025.06.10.
                    Time: 00:16:03
Address 15: Airbags (J234)       Labels:* None
   VCID: 41DF4519710A34D210D-8014
1 Fault Found
16759553 - Function Restricted due to Insufficient Voltage
          U1400 00 [00001000] - -
          [Functional limitation by undervoltage]
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 176
                    Mileage: 54435 km
                    Date: 2026.10.03.
                    Time: 00:13:27
   Coding: 140E00
   Shop #: WSC 00788 648 00255
   VCID: 382928FD22D0751AA73-806C
1 Fault Found
12658432 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [Steuergerät für Reifendrucküberwachung: keine Kommunikation]
                    Fault Priority: 6
                    Fault Frequency: 6
                    Reset counter: 176
                    Mileage: 0 km
                    Date: 2025.06.10.
                    Time: 00:20:21
   Revision: B9084001
   Coding: 002317
   VCID: 6889B8BD3270259AF73-803C
Address 25: Immobilizer (J334)       Labels:* Redir Fail!
   Serial number:
   VCID: 6A8DC2B52CFC178AE17-803E
   Revision: 00H02000
   Coding: 000039
   VCID: 34311CCD3E38917A8BB-8060
4 Faults Found
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
                    Fault Status: 00100010
                    Fault Priority: 5
                    Fault Frequency: 5
                    Reset counter: 41
                    Mileage: 54435 km
                    Time Indication: 0
                    Date: 2026.10.03.
                    Time: 00:23:59
02333 - Backrest Adjustment Motor (V286)
            011 - Open Circuit - Intermittent
                    Fault Status: 00101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2025.06.10.
                    Time: 00:00:36
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 136
                    Mileage: 54435 km
                    Time Indication: 0
                    Date: 2026.10.03.
                    Time: 11:42:59
00446 - Function Limitation due to Under-Voltage
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 176
                    Time Indication: 0
Address 44: Steering Assist (J500)       Labels:* Redir Fail!
1 Fault Found
0067 - Terminal 30
          U140A 00 [00001001] - Open Circuit
          [Failure monitoring terminal 31]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Voltage terminal 15: 11.056 V
                    Voltage terminal 30: 11.696 V
                    Vehicle speed: 50 km/h
                    Status: Initialization
Address 55: Headlight Range (J431)       Labels: None
   Revision: --------    Serial number: -------------- Dataset Number: 6R0907357C  0004
   VCID: 3A2D32F51CDC670A517-806E
   Coding: 02620001BE0000005111000101080A001F0100C601200100CE
   VCID: 2411EC8D8E5801FA1BB-8070
   Data carrier:
   Subsystem 1 - Part No SW: V03 959 821 NB    HW: -----------
   Component: MRM2 2025  --- 2310
6 Faults Found
          B201A 00 [00001001] - -
          [Check software version management]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 136
                    Mileage: 0 km
                    Date: 2025.06.10.
                    Time: 00:19:10
                    Voltage terminal 30: 11.5 V
1556 - Internal Control Module Memory Check Sum Error
          B2000 87 [00001001] - Missing Message
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 136
                    Mileage: 0 km
                    Date: 2025.06.10.
                    Time: 00:20:46
                    Voltage terminal 30: 11.6 V
                    System_Software_Error-SW_Status_Consistency: 04 01 01
                    System_Software_Error-SW_Status_Device: o
          U1101 00 [00001001] - Active
          [Anti-theft protection - component protection active (0xEA6300)]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 136
                    Mileage: 0 km
                    Date: 2025.06.10.
                    Time: 00:19:10
2565 - GPS Antenna
          B1054 13 [00001001] - Open Circuit
          [GPS aerial - open circuit]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 136
                    Mileage: 0 km
                    Date: 2025.06.10.
                    Time: 00:19:10
          U1111 00 [00001001] - -
          [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 136
                    Mileage: 0 km
                    Date: 2025.06.10.
                    Time: 00:19:13
          B1119 13 [00001001] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 136
                    Mileage: 0 km
                    Date: 2025.06.10.
                    Time: 00:19:10
Address 65: Tire Pressure (J502)       Labels: None
   Part No SW: 3AA 907 273 D    HW: 3AA 907 273 B
   Component: RDKBERU30     H08 0010
   Serial number: 10000000052905
   ASAM Dataset: EV_RDKBERU30 003012
   ROD: EV_RDKBERU30_003.rod
   VCID: 353721C935C28872BC5-8060
1 Fault Found
8398082 - Tire Pressure Sensor(s)
          C111A 31 [00001001] - No Signal
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 122
                    Mileage: 54096 km
                    Date: 2026.09.26.
                    Time: 12:14:55
End----(Elapsed Time: 01:15, VBatt start/end: 11.1V/11.1V. VIgn 11.5V)-----
If any of the experts from the forum could share some of their insights with me, it would greatly help me resolve this.
Is the key reader coil connected?
SanketM
Post by SanketM »
HI Michel,
Thank you for your response. Yes it's connected but I get your drift it might have got short circuited and not reading the key transponder for BCM, I'll try connecting another reading coil and see if that solves the ignition problems.
Thanks & Regards,
Sanket
My drift was more 'you did a lot of wiring stuff around the steering column and might forgot to plug it back'.
Been there, done that. Many many times.
SanketM
Post by SanketM »
Hi Michel, thanks for pointing that out. In past I have indeed done this mistake numerous time. Unfortunately it wasn't this time. But it was something on the similar lines. The fuse SB11 had blown up. I replaced it with a new fuse which I had received with the automatic headlights harness. ( Thanks for the gifts ciclo 👍😅) and now all is almost well. Except for one terminal 30 open circuit fault which I see in the BCM MAX 🙈
The car starts now. But I need to get to the bottom this terminal 30 open circuit issue before feeling confident enough to take it for a long drive.
Best Regards,
Sanket.
SanketM
Post by SanketM »
With guidance of Aditya, I have finally fixed the terminal 30 open circuit error by replacing the SB59 fuse. Now all is well again 🤞
adityagttsi
Drives: Polo GT 1.2 TSI
Post by adityagttsi »
Hi, everyone
So I and Sanket are installing OEM Kessy on his car.
Have already sourced the following parts
2x Front Door handles
2x Rear Door handles
Start stop button
Kessy module
J935 Converter box
Terminal 15 Relay
Starter relay
Centre console antenna
Rear bumper antenna
Rear passenger antenna
And necessary wiring harness.
The process of installation is the same as Mr. Collayder’s (Drive2)
Just for some info the car is 2021 year, with 1.0tsi Dsha Engine, 6R0 920 870A cluster(which had its issues) and BCM Max 090D
Now related to the cluster issue since it was used cluster we had to adapt it offline,but that was not successfull. Apparently one 1.0tsi DSHA engines for the immo to sync you need to upgrade the firmware to 0729. Once that is done everything was woking fine.
Now regarding Kessy
- Did the wiring for all doors and connected it to kessy module
- Did the wiring for antenna and connected it to kessy module
- Adapted the wiring for Ignition switch and connected it to ELV, Converter box, Terminal 15 Relay, Starter Relay
- only the signals for Converter box where controlled via ignition switch
- Since we had sourced a used ELV and Dashboard from Jetta. We were able to retrieve the data like CS and Pin
- Using the old CS and Pin from donor kit adapted the ELV to cluster using VVDI2
- Cluster config and status were changed from
Original Config - 610106110100
New Config - 61E106110101
Original Status - 140000F5FF
New Status - 140000F5D5
There was an error in Kessy module No Basic Setting which was cleared by Xhorse Iscancar MM 007
Now it was time to adapt the ECU to Cluster since post the changes to cluster the ECU lost its sync.
But apparently we are unable to do that. Tried Vvdi2, iscancar mm 007, autel 608 and even bench(which i am not sure whether it was done properly)
While adapting it the tool is not able to retrieve the power class.
Now some guys have told this is immo 5 and while others have told me immo 4c
Is there any way we can do this? Or its a dead end?
