Set Speed Warning to off as default
DamoMc
- Drives: 2024 R Line 1.0 95hp tsi
Does anyone have a fix for setting the speed warning to off as a default position..2024 R Line?
I know it's possible to set the Lane Assist to On,Off or Memory through OBD11 but haven't found the same option for the speed warning.
It's possible to turn it off via the infotainment screen but it comes back on every ignition cycle
- Maarten
Re: Set Speed Warning to off as default
What do you mean with speedwarning?
DamoMc
This setting..in the driver assistant menu.
I'd like to know if there's a one click app or adaptation to set to off as a default.
There's a one click app to set Lane Assist to off as default
- 20240714_132401.jpg (2.26 MiB) Viewed 14093 times
DamoMc
Or also to set the warning to visual only..its the audible warning that's driving me mad
- Maarten
Just de-check active
Will check my infotainment tomorrow.
Cant remember if I have this box checked or not
- Maarten
Did you click the speedsign to get here?
DamoMc
De checking active does work but unfortunately it becomes active the next time the car is started
- Maarten
Set the warning to off
Options should be
Off
Optical
Optical and Audible
You checked this speed sign right?
Options should be
Off
Optical
Optical and Audible
DamoMc
No off option available on mine,only these 2:
Visual
Visual/audible
So I guess yours was coded with the off option
Visual
Visual/audible
- 20240715_124243.jpg (2.17 MiB) Viewed 13824 times
DamoMc
Sign de checked also
- 20240715_123906.jpg (2.24 MiB) Viewed 13824 times
- Maarten
You should not have to de-select the speed sign, it also displays the speed limits for the road you're on.
Maybe I did not formulate my question right, to get to the speed warning menu you pressed the speed sign?
Do you use the ACC? Or the speed limiter?
The options behind the steering wheel.
The one above the side assist, in your case the one above the front assist should not be checked because you do not have side assist and rear traffic assist (uitparkeerassistent)
Speed limiter (snelheidsbegrenzing) should be de-selected
DamoMc
These are the options on the screen behind the steering wheel.Unchecking Speed Warning turns it off but only until the next time the car is started when it must be unchecked again.
I don't have the option to turn it off like yours:
Off
Visual
Audible
I only have:
Visual
Visual/Audible
Off
Visual
Audible
I only have:
Visual
Visual/Audible
- 20240715_155856.jpg (1.91 MiB) Viewed 13775 times
- 20240715_155909.jpg (1.89 MiB) Viewed 13775 times
- 20240715_155954.jpg (2.25 MiB) Viewed 13775 times
- 20240715_160024.jpg (1.81 MiB) Viewed 13775 times
- Maarten
Must be the new tacho standards
My car is from 2022, maybe that's why.
My lane assist icon comes up from 60km/u or with Travel Assist on.
Yours is visable when stationairy.
Try finding this setting in VCDS or OBD11.
Then remember last setting.
Could fix your issue
DamoMc
That's the next step
thanks for your patience and advice,much appreciated
- Maarten
No problem, glad to help.
When you solve this, please post here.
Could be helpfull in the future for others
