Set Speed Warning to off as default
DamoMc
Drives: 2024 R Line 1.0 95hp tsi
Post by DamoMc »
Does anyone have a fix for setting the speed warning to off as a default position..2024 R Line?
I know it's possible to set the Lane Assist to On,Off or Memory through OBD11 but haven't found the same option for the speed warning.
It's possible to turn it off via the infotainment screen but it comes back on every ignition cycle
Maarten
Re: Set Speed Warning to off as default
Post by Maarten »
What do you mean with speedwarning?
DamoMc
Post by DamoMc »
This setting..in the driver assistant menu.
I'd like to know if there's a one click app or adaptation to set to off as a default.
There's a one click app to set Lane Assist to off as default
DamoMc
Post by DamoMc »
Or also to set the warning to visual only..its the audible warning that's driving me mad 🫣
Maarten
Post by Maarten »
Just de-check active
Will check my infotainment tomorrow.
Cant remember if I have this box checked or not
Maarten
Post by Maarten »
Did you click the speedsign to get here?
DamoMc
Post by DamoMc »
De checking active does work but unfortunately it becomes active the next time the car is started 💁‍♂️
Maarten
Post by Maarten »
Set the warning to off
Options should be
Off
Optical
Optical and Audible
Speed warning.jpg (150.02 KiB) Viewed 13853 times
You checked this speed sign right?
IQ Drive.jpg (311.75 KiB) Viewed 13853 times
DamoMc
Post by DamoMc »
No off option available on mine,only these 2:
Visual
Visual/audible
So I guess yours was coded with the off option
DamoMc
Post by DamoMc »
Sign de checked also
Maarten
Post by Maarten »
You should not have to de-select the speed sign, it also displays the speed limits for the road you're on.
Maybe I did not formulate my question right, to get to the speed warning menu you pressed the speed sign?
Do you use the ACC? Or the speed limiter?
The options behind the steering wheel.
The one above the side assist, in your case the one above the front assist should not be checked because you do not have side assist and rear traffic assist (uitparkeerassistent)
Speed limiter (snelheidsbegrenzing) should be de-selected
ACC, Snelheidsregeling en Snelheidsbegrenzer.jpg (172.77 KiB) Viewed 13800 times
DamoMc
Post by DamoMc »
These are the options on the screen behind the steering wheel.Unchecking Speed Warning turns it off but only until the next time the car is started when it must be unchecked again.
I don't have the option to turn it off like yours:
Off
Visual
Audible
I only have:
Visual
Visual/Audible
Maarten
Post by Maarten »
Must be the new tacho standards
My car is from 2022, maybe that's why.
My lane assist icon comes up from 60km/u or with Travel Assist on.
Yours is visable when stationairy.
Try finding this setting in VCDS or OBD11.
Then remember last setting.
Could fix your issue
DamoMc
Post by DamoMc »
That's the next step😊thanks for your patience and advice,much appreciated 👍🇱🇺
Maarten
Post by Maarten »
No problem, glad to help.
When you solve this, please post here.
Could be helpfull in the future for others :D
