BCM Max Transporter 2013
Shadow109
Drives: Vw t5.1 2013
Re: BCM Max Transporter 2013
Post by Shadow109 »
I light of hope finally 8)
https://youtu.be/ZbudBbFmMTU?feature=shared
Kessy entry spouse to be fully working
I am currently working on a solution for the handles
Beautiful, well done, that's a real success. So now you have keyless entry and keyless exit? Brilliant.
Shadow109
Post by Shadow109 »
Yes, I will try now to make keyless start work
Shadow109
Post by Shadow109 »
Update regrading kessy..
I have got my ELV working
Kessy Entry is also working
the final step was to repin old ignition switch
Screenshot 2023-11-03 182637.png (140.26 KiB) Viewed 7229 times
D1 => T7/5 (starter relay)
D2 => T7/3 (starter relay)
D3 => t9g/5 (Terminal 15 relay)
D4 => T16v/7 (ELV)
D5 => t9g/3 (Terminal 15 relay)
D6 => t9m/1 (Terminal 75 relay)
after repining I got 2 faults, 1 in BCM and the other in ELV
Friday,03,November,2023,14:21:13:22797
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.11.0.0 (x64)  HEX-NET2 CB: 0.4643.5
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZDH036544   License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 05 08 09 10 13 14 15 17 19 20 25 2B 37 3C 47 55 5F
          61 65 77 0B
VIN: WV1ZZZ7HZDH036544   Mileage: 304050km-188927miles
05-Acc/Start Auth. -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GH    HW: 03L 907 309 M
   Component: R4 2.0l TDI   H44 9977
   Revision: 26H44---    Serial number: 00000000000000 CVN: B171D454
   Coding: 01114012234400080000
   Shop #: WSC 43690 085 00000
   ASAM Dataset: EV_ECM20TDI01103L906019GH 004007
   ROD: EV_ECM20TDI01103L906019FM_003.rod
   VCID: 77A086CB4F48D4621E9-8022
   VINID: 9E606AAAA1D8A946000C6144105E5FB8A3
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 Q    HW: 7E0 907 379 N
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 62787000000113
   Coding: 307E4098256586840C7A027AA486616FF9F555
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: 40D22D175A0653DA6F3-8014
   Serial number: 10082013470288
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EAE93EF6072E52A5DF-802A
Address 05: Acc/Start Auth. (J518)       Labels:| 5K0-959-434.clb
   Part No SW: 5K0 959 434 H    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 093 1305
   Revision: 00093000    Serial number: 0467921560
   Coding: 032C0C
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_KESSYPQ35G A02720
   ROD: EV_KESSY_PQ35GP.rod
   VCID: 3A265FFF3CDA090A217-806E
   Part No SW: 7E5 907 047 BM    HW: 7E5 907 047 BM
   Component: Climatic-T5   H20 0505
   Revision: 00001010
   Coding: 0000000002
   Shop #: WSC 02736 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 7BA89AFB7360F0027A1-802E
   Revision: B9084001    Serial number: 2502 306190145
   Coding: 2AB03D3E4EFF201281280EC17EEB9FDDF88E6600608D79C072E4503F0860
   VCID: 2D0C64A3FD14AEB2B45-8078
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 230916 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3313
   Subsystem 3 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3313
   Subsystem 4 - Part No: 1K0 951 605 C
   Subsystem 5 - Part No SW: 7E0 959 442 A    HW: 7E0 959 442 A
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39180000000570018056
   Coding: B4FFFF
1 Fault Found:
03444 - Ignition Starter Switch
            008 - Implausible Signal
                    Fault Status: 01101000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 201
                    Mileage: 304050 km
                    Time Indication: 0
                    Date: 2023.11.03
                    Time: 03:01:46
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331817601496
   Coding: 0041155001
   Shop #: WSC 21890 003 104857
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
   VCID: 372046CB0FC81462DE9-8062
1 Fault Found:
12718592 - Databus
          U1121 00 [00001001] - Missing Message
          [Steuerger t f r Lenks ulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 201
                    Mileage: 304050 km
                    Date: 2023.11.03
                    Time: 03:01:45
Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Component: ACC Bosch PQx H03 0211
   Serial number: 1909180453A6EF Dataset Number: ACC_MRRevo1 0001
   Coding: 00004000FE0779
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_ACCBEGVW361 001006
   ROD: EV_ACCBEGVW361.rod
   VCID: 363E4BCF08C2ED6AC5F-8062
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 12030906320002
   Coding: 030180
   Shop #: WSC 00046 000 00000
   VCID: 2700968BDFE884E24E9-8072
   Part No SW: 7E0 959 655 D    HW: 7E0 959 655 D
   Component: VW10Airbag00G 008 0016
   Revision: --------    Serial number: 003PH0013MB$ Dataset Number: 7E0003V____ 0735
   Coding: 000000000000000000000000000000003047
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   ROD: EV_AirbaVW10BPAVN750.rod
   Part No SW: 7E0 920 980 S    HW: 7E0 920 980 S
   Component: KOMBI         H04 1109
   Coding: 140E230B00
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   VCID: 3B285AFB33E030023A1-806E
   Revision: B9084001
   Coding: 04220F
   VCID: 6882D5B712764B9A873-803C
1 Fault Found:
03406 - Control Module for Battery Monitoring
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 201
                    Mileage: 304050 km
                    Time Indication: 0
                    Date: 2023.11.03
                    Time: 03:02:29
   Revision: AA001001
   Coding: 010100E200000100000000
   VCID: 2E0E63AFF092D5AA8DF-807A
   Component: IMMO          H04 1109
   Serial number:
   Coding: 000007
   VCID: 6A86AFBF0CFA798A917-803E
Address 2B: Steer. Col. Lock (J764)       Labels:* 5K0-905-861.clb
   Part No SW: 5K0 905 861 C    HW: 5K0 905 861 C
   Component: ELV-PQ35      H21 0240
   Revision: 00000000    Serial number: 14000305204001
   Coding: 4100000000000000
   Shop #: WSC 00066 790 50316
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 30327DD7EAA6C35A9F3-8064
1 Fault Found:
1048835 - Terminal S
          B11A5 11 [00001001] - Short to Ground
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 201
                    Mileage: 304050 km
                    Date: 2023.11.03
                    Time: 03:01:46
                    ELV State: 54
                    Information Clamps: 71 60
                    CoCo State: B0 01
                    WFS State: 67 1A
                    Vehicle speed: 0.00 km/h
                    Voltage: 68
Address 37: Navigation
Cannot be reached
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0150
   Serial number: 14520003983159  Dataset Number: V03935303MB 0001
   Coding: 529524A0
   ROD: EV_HREntryHellaGen3Kl15.rod
   VCID: 392440F339DC021228D-806C
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H06 0150
   Serial number: 14520003959660
Address 47: Sound System (R184)       Labels: 5K0-035-456.clb
   Part No SW: 3AA 035 466     HW: 3AA 035 466
   Component: KonzernAmp12K H03 6904
   Revision: --------    Serial number: A1108A00007925 Dataset Number: 360050v____ 0004
   ASAM Dataset: EV_AudioVerst12KanalSTT1 001001
   ROD: EV_AudioVerst12KanalSTT1_VW36.rod
   VCID: 6D8CA4A33D146EB2F45-8038
2 Faults Found:
9463315 - Rear Left Treble Speaker
          B1066 13 [00001001] - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 201
                    Mileage: 304050 km
                    Date: 2023.11.03
                    Time: 03:01:46
9463827 - Rear Right Treble Speaker
          B1068 13 [00001001] - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 201
                    Mileage: 304050 km
                    Date: 2023.11.03
                    Time: 03:01:46
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Revision: --------    Serial number: -------------- Dataset Number: V03600097E0 0001
   Coding: 0F46020001000000
   Shop #: WSC 02748 790 50316
   ROD: EV_HeadlRegulVWLWRCC.rod
   Component: MU-S-ND-ER    H41 0480
   Serial number: VWZAZ2U1668085 Dataset Number: V00000000VW 0001
   Coding: 0645000FBE00000011110006010D08001F0103D401200100CE
   Shop #: WSC 00046 123 12345
   ROD: EV_MUStd4CTSAT_VN75.rod
   VCID: 251C9C83A56496F27C5-8070
   Data carrier:
   Subsystem 1 - Part No SW: V03 959 820 DC    HW: -----------
   Component: MRM DL2 23/24  --- 2010
4 Faults Found:
1553 - Function Restriction
          B200D F0 [00001001] - due to Internal Communcations Error
          [Function restriction due to internal communication error: optical drive (fitted)]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 201
                    Mileage: 304050 km
                    Date: 2023.11.03
                    Time: 03:01:58
                    Voltage terminal 30: 12.0 V
1555 - Check Software Version Management
          B201A 00 [00001001] - -
          [Check software version management]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 201
                    Mileage: 304050 km
                    Date: 2023.11.03
                    Time: 03:01:45
                    Status_Software_Version_Management-module_name:
1556 - Internal Control Module Memory Check Sum Error
          B2000 87 [00001001] - Missing Message
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 201
                    Mileage: 304050 km
                    Date: 2023.11.03
                    Time: 03:02:12
                    Voltage terminal 30: 12.1 V
                    System_Software_Error-SW_Status_Consistency: 04 01 01
                    System_Software_Error-SW_Status_Device: o
          U1101 00 [00001001] - Active
          [Anti-theft protection - component protection active (0xEA6300)]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 201
                    Mileage: 304050 km
                    Date: 2023.11.03
                    Time: 03:01:45
   Part No SW: 7E0 907 534     HW: 7E0 937 090 E
   Component: Batt.regelung H84 0772
   Coding: F0001800
   Serial number: 30000000047437
   ROD: EV_RDKBERU30_005.rod
Address 77: Telephone
Cannot be reached
End----------(Elapsed Time: 01:49, VBatt start/end: 12.2V/12.2V)-----------
Screenshot 2023-11-03 143817.png (226.97 KiB) Viewed 7229 times
Screenshot 2023-11-03 144043.png (88.69 KiB) Viewed 7229 times
First click on the button will turn 15kl on, as seen In measuring
when trying to long press with clutch, it will turn off 15kl
I have double checked Terminal S wire from T16v/7 (ELV) to D/4 and is seems OK
Shadow109
Post by Shadow109 »
kessy update...
after a long research why my elv didnt send 50kl signal to start the car..
the biggest possibility was that ELV is not knowing that my clutch is pressd
so after a quick look at elsa :-
So my van has a basic clutch padle switch
But in CAA with start-stop elsa shows a different case :-
I have immediately ordered this part and installed it ..
2 wires are repined + new GND wire + one new wire to the ecu
and after testing still no progress :cry: :cry:
I was thinking maybe I should also flash ECU to support (start-stop) to get this new line working
after a quick look into etka I have found : 03L906019GQ
PR :-
G0K 6-speed manual transmission
7MJ Emission standard EU5 plus
7L6 Start/stop system with regenerative braking
7MQ Emissions standard EU5 mod
after flashing and coding, still nothing changed
two days later I asked my self so how a manual beelte and jetta with kessy knows when clutch is pressed
after checking elsa I found this :-
after checking the beetle clutch position sensor I found that its nothing like the T5
WhatsApp Image 2023-11-26 at 23.12.25_55796abd.jpg (21.33 KiB) Viewed 7047 times
WhatsApp Image 2023-11-26 at 23.12.25_4731a748.jpg (28.2 KiB) Viewed 7047 times
But If we look closely at the wiring diagram, all the wires seem to be similar, so I decided to give it a try and rotate the new wire to T73b/55
and when made a test I was surprised, kessy start is starting to work
with full clutch and a long press only, it will start the car
a press with out clutch paddle with turn on 15kl, but I wont be able to start the car with a second press with clutch, instead the second press turn of 15kl
MrCollayder
Drives: Polo 614 sedan (cczb+dq250 awd+pq35)
Post by MrCollayder »
Great job, bro! Working kessy will give you a lot of pleasure =)
So the only thing need to be finished is handle.
Shadow109
Post by Shadow109 »
I’m back to business
Finishing kessy start soon
Shadow109
Post by Shadow109 »
Super comfortable. 8)
Hi Shadow109,
I was wondering if you have an autoscan saved right at this point...
Your video :arrow: https://www.youtube.com/watch?v=2JTT2LMBan4 👍
Link: https://www.t6forum.com/threads/side-as ... ost-545230 (all the acquaintances are there, what a bunch... :lol:👌)
... or maybe you can tell me what control units you had installed just at that time.
PDC?
Radars?
Sorry for hijacking your great thread 🙏, but I haven't been able to figure it out with my methods.😄
Thanks a lot in advance. 🤗
Shadow109
Post by Shadow109 »
Yes I know exactly when It started to work, I will check for you for an autoscan, it only works with the 5Q0 radar’s
When I switched to 2Q0 I have got the beep sound for the pdc speakers instead
Oki, that suits me, it would be nice if the combination of my 7E0 PDC control unit together with the sw of my IC could do it too.
The Lane Change issue is clear, but there are several things that need to be resolved in the 6R regarding the RTA. I would like not to have a useless menu (RTA) when installing the radars, that is, I am happy with the I Cluster chime beeping... that at least doing something! :lol:
Shadow109
Post by Shadow109 »
ciclo wrote: Tue Aug 20, 2024 9:17 am Sorry for hijacking your great thread 🙏, but I haven't been able to figure it out with my methods.😄
you are welcome to post here anytime :D
the only thing I changed when the warning on the cluser starts to work was the coding in 3C
02031102 warning from the PDC speaker
03031102 warning from the Cluster
PDC :-
   Coding: 0041155001
   VCID: 372B22F60FCF04633E5-8062
3C :-
Address 3C: Lane Change (J1086)       Labels:| User\5Q0-907-686.clb
   Component: HRE_Master    H12 0081
   Serial number: 0466413079
   Coding: 03031102
   Shop #: WSC 09003 957 00200
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D2730DE2DF32E33E49-8068
   Subsystem 1 - Part No SW: 5Q0 907 685 C    HW: 5Q0 907 685 C
   Component: HRE_Slave  H12 0081
   Serial number: 0465512829
   Coding: 030311
I Really miss this warning on 2Q0 but I prefer to keep them as they are more accurate and they have oem holders for transporter
You are great! Thank you so much for your help, time, etc!!!👌
Shadow109
Post by Shadow109 »
Finally kessy full + start-stop project is done 🥲
https://youtu.be/fBPKYJhPioE?si=LpfadHs4IRuT1rmB
Next step is working on a special steering rack that will support ELV and electric steering (the way to lane assist) ☺️
