BCM Upgrade and not able to match the key
Hiroki
Drives: 6r Polo 1.2 TSI 2011
Re: BCM Upgrade and not able to match the key
Post by Hiroki »
Thank you so much for your kind advice and time.
I just made the order for 190B
I will update once I get it and installed.
Thanks for the reminder for the wiring change. I’m currently studying your google documents and trying to re-create the wiring since I read that the harness that you had kindly created were already sold out.
It’s a learning process and I’m not complaining :)
🙏 thanks
Hiroki
Post by Hiroki »
Just an update about the status.
I got the new BCM and both of my original 315MHz keys were able to pair successfully.
I'm working on the wiring but my work is taking up most of the time and the weather is also preventing me to work on the car (I have no garage and have to park the car outside).
Thanks a lot for all the advices and will keep you posted
Step by step, circumstances always condition the time and place. https://youtu.be/_rQrkaExnt4?t=3
Thanks for the new update/report, it will be useful for someone in the same situation.
Hiroki
Post by Hiroki »
Hi all,
Finally I am successfully finished with the wirings. It is tedious but it is satisfying. I will upload some of the drawings that I did along the way hopefully I could help somebody else.
Now I’m facing a few issues and hope my Gurus here can help me.
1) my car detect the alarm siren but no sound. I changed the siren 2 times (1 from AliExpress -so-called new, 1 from eBay where they said it is fully functional used) both of them not detected by my VCDS.
2) my front fog lights not working. I tried multiple combination of codings that I could find but it is not working. I can get cornering light work (means when I use turn signal, the fog lights on that side light up) but if I pull the light switch, fog light is not on.
3) my highbeam will light if I pull/flash. But it doesn’t on when I push it down.
4) so far right now, I did not install any LED bulbs. They all are halogen bulbs (license plate, parking light, brake light, fog lights etc) but I notice that they are flickering.
Here is my scan
Thursday,31,October,2024,16:09:05:38219
VCDS Version: 24.7.1.0 (x64)  HEX-V2 CB: 0.4656.4
Data version: 20240919 DS356.3
[www.Ross-Tech.com](http://www.ross-tech.com/)
VIN: WVWZZZ6RZBU037606   License Plate:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 56
VIN: WVWZZZ6RZBU037606   Mileage: 194790km-121036miles
## 01-Engine -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 BQ    HW: 03F 906 070 D
Component: SIMOS10.20H02 9849
Revision: --------    Serial number:                CVN: 949FC520
Coding: 002500F6202400080000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_ECM12TFS02103F906070BQ 003010
ROD: EV_ECM12TFS02103F906070BQ_003.rod
VCID: 72BDCB884426752A59F-8026
VINID: 9E69EAAAA1A2A929400C718018574E6D87
Readiness: 0110 0101
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ    HW: 6R0 907 379 AF
Revision: --------
Coding: 23022BE3417000B9C42BD4E282D700801200
Shop #: WSC 31414 790 31414
VCID: 06558758586E798A657-8052
Address 08: Auto HVAC (ÿÿÿÿÿ)       Labels: 6R0-820-045-9AP.clb
Part No SW: 6R0 820 045 J    HW: 6R0 820 045 J
Component: Climatic       25 0660
Revision: 00 11 25
VCID: 3537309475482212BCD-8060
Part No SW: 7E0 937 190 B    HW: 7E0 937 190
Component: BCM PQ25 Max3 H81 0744
Revision: B8081001    Serial number: 0970 117220019
Coding: B8904AB868F30700913806F07CEB96D1FFC067FF608D30F1200000030000
Shop #: WSC 18752 008 00032
VCID: 2B0316ECA30C64E2DA9-807E
Component: RLHS 300518 0  50  0107
Coding: 008F77
Subsystem 2 - Part No SW: 6R0 959 802 S    HW: 6R0 959 802 S  Labels: 6R0-959-802.CLB
Component: J386__TSG_FT  006 0903
Serial number: KU0-KU025.08.1012517
Coding: 18BC34
Subsystem 3 - Part No SW: 6R0 959 801 AA    HW: 6R0 959 801 AA  Labels: 6R0-959-801.CLB
Component: J387__TSG_BT  006 0902
Serial number: KU0-KU024.08.1017757
Coding: 08BC34
Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
Component: E221__MFL-MD9  H04 0103
Serial number: 27190003121620060022
Coding: A40000
Subsystem 8 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
Component: J388__TSG_HL  006 0902
Serial number: KU0-KU001.09.1011977
Coding: 08BC32
Subsystem 9 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
Component: J389__TSG_HR  006 0902
Serial number: KU0-KU016.08.1014939
Coding: 08BC32
1 Fault Found:
03906 - Control Circuit for High Beam Relay
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Mileage: 194791 km
Time Indication: 0
Date: 2019.03.24.
Time: 00:49:05
Address 10: Park/Steer Assist (J446)       Labels:* None
Part No SW: 6RD 919 475 A    HW: 56D 919 475
Component: PARKHILFE 8K  H02 0007
Revision: --------    Serial number: 57921435200072
Coding: 308103
ASAM Dataset: EV_EPHVA18VW250GPCS 001004
VCID: 50F96100EA6A673A8FB-8004
Part No SW: 6R0 959 655 L    HW: 6R0 959 655 L
Component: VW10Airbag00R H09 0020
Revision: --------    Serial number: 003GY001DNMQ Dataset Number: v00305166R0 0001
Coding: 003052
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4BC3766C034C44E2FA9-801E
Serial number: 3572SRB40000C64551E5
Serial number: 3582SRB40000C4185A98
Serial number: 3515RRB405B6VQ8C3GB/
Serial number: 3525RRB40636UBV85G8-
1 Fault Found:
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
B1016 14 [10001001] - Open or Short to Ground
Fault Priority: 2
Fault Frequency: 1
Mileage: 194791 km
Date: 2024.10.31.
Time: 00:49:16
Part No SW: 6R0 920 860 F    HW: 6R0 920 860 F
Component: KOMBI         H04 0304
Coding: 240A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
VCID: 372B3A9C6FC4D002AE1-8062
Part No SW: 7E0 909 901     HW: 7E0 937 190
Component: GW-K-CAN TP20 H81 0744
Revision: B8081001
Coding: 002200
VCID: 6889A9E0727A8FFAF7B-803C
Component: IMMO          H04 0304
Serial number:
VCID: 6A8DD3E86CF6BDEAE1F-803E
Part No: 6R0 423 156 B
Coding: 11230
Shop #: WSC 31414
VCID: 2F3B02FC9E5418C2F61-807A
Component: Radio         534 5614
Revision: --------    Serial number: VWZZZ4H6239179
Coding: 1F000440040001
VCID: 46D5475818AEB98A257-8012
End----------(Elapsed Time: 01:55, VBatt start/end: 13.1V/13.1V)-----------
Hiroki
Post by Hiroki »
Here are some files that I created while I was doing the wiring.
Wiring diagram (from fuse to BCM to light bulbs etc)
I have compiled BCM pinout numbers and their interpretation but it is in excel/pdf but I don’t know how to upload. I know these info can be found on internet but it’s compiled everything into 1 file so hope it will help better.
I also have the VCDS coding interpretations (I tried different language of VCDS versions to compile into complete information) and it is also in excel/pdf.
Please let me know how can I upload them.
Hiroki
Post by Hiroki »
Sorry I don’t know why the pictures don’t get uploaded.
Here’s the pictures
My current situation
VCDS coding
VCDS coding
T10 headlight switch
Relays
Relays
Front fog/DRL
Front fog/DRL
Dimmer
Dimmer
Headlight - H7
Headlight - H7
Rear lights
Rear lights
Taking a quick look at your posts and without looking at the Autoscan it seems that they are coding problems, I'm on a trip now and I won't be able to take some time to see what's going on in your car until next week.
Nice schemes. 8)
Hiroki
Post by Hiroki »
Thank you brother
I’ll wait for you. Have a nice trip
How are you feeding the 'a' inputs of fuses 39 and 59? +30 power is required.
Have you permanently/4ever removed the J331 relay?
'Example' for J331 relay (page 7):https://drive.google.com/file/d/0B2nv91 ... QkQNBJAwgQ
Auto lights.
Are you sure you have installed the wires in the relay adapters correctly?
Any special reason for a 6R LHD to be in Jamaica?
Communications here are very bad due to the catastrophic rainy season that we had, I even think that sometimes the posts sent are not loaded.
I apologize.🙏
Can you show us the Auto light switch you are using (pictures of the pins and the Auto light switch already installed)? Ref number?
Who has done the coding of the 'new' 7E0 BCM Max?
Coding.
GW coding is correct as long as it is a 6R LHD 5 doors.
Latest BCM coding posted:
New BCM coding: (provisional)
B8904ABF68F32400B33806B07CEB96D15FC0612F608C20D1200000020000
In addition to doing the new BCM coding and showing us the result whatever it is, and whenever possible, do the following:
1- :arrow: https://drive.google.com/drive/folders/ ... drive_link
Post the resulting file (link) here so I can see the BCM adaptation channels values.
2- An autoscan with the old BCM installed... (it is impossible to know the specific equipment installed regarding the central locking without knowing the original factory coding).
What the ....?
It's been a while since I did this kind of assistance/support, and just when I do, the communications are absolute rubbish, that is, I have had to make twice the effort for something that already requires a moderate effort...
... my wonderful life is a permanent gift... which keeps alive my hope that at least once something will be 'normal' for me in the unfortunate place where I was accidentally born, ... I don't ask for easy, just 'normal'... 😄
Original
VS
Flipped
Image :mrgreen:
Hiroki
Post by Hiroki »
My apologies for the delay. We are having tropical storm so I can’t go out to my car yet. And internet is off and on too. It is a RHD car. Will check everything that you asked me to and will ge back to you asap. Thank you!!!
Hiroki
Post by Hiroki »
This is the auto headlight switch that I have.
Hiroki
Post by Hiroki »
I’m not sure I can still put back the old BCM and start the car to do the scan but I will try it and will let you know.
This is the old BCM coding that I take screenshots before the swab.
