6c 2016 Gti oil sump pan
APgti
Drives: Polo Gti 2016
Post by APgti »
I have a leak from the sump pan so I need to change the pan and gasket. Can anyone tell me the genuine part numbers for both? Or confirm if an alternative brand will fit properly.
Maarten
Re: 6c 2016 Gti oil sump pan
Post by Maarten »
06K 103 600 L (Sump)
06K 103 649 (Gasket)
D176501A1 (Sealer)
N0282222 (Seals)
These are for the DAJA and the DAJB Engine 1.8 ltr
APgti
Post by APgti »
Thanks, when you say sealer and seals… are they needed also? I thought it would just be pan and gasket?
Maarten
Post by Maarten »
Sealer goes between the sump and the gasket.
Seals should replaced, there are 2 on the sump, you could re-use them but that is not recommended
APgti
Post by APgti »
Thanks again Maarten. Are you aware of any youtube videos on this? Im going to do it myself but the only vid i could find was just sump and Sealer. No gasket used. I always thought it was either gasket or sealer and never both.
Maarten
Post by Maarten »
Sump is nr 1
Gasket is nr 19
Sealer is nr 20
Seals are nr 7
APgti
Post by APgti »
Thanks again. What about the oil level sensor i saw a video where that is reused but they changed the seal on that also?
I don't think this is a difficult job but I cant get my head around needing the sealer with the sump that has a gasket in as the videos i see only sealer is used when there is no gasket.
I can get a sump pan on ebay for £40 do you have any idea of they are decent quality or if genuine vw is the only way to go with this?
Thanks for the help. I am competent with tools, have serviced our own cars for 10 years now but in that time have never once done a sump pan change.
Maarten
Post by Maarten »
I do not see a seal on the image.
My last oil sump was on a golf mk2 almost 20 years ago, those had cork gaskets lol.
I can't tell you which is the best way to go.
APgti
Post by APgti »
Haha. Okay thanks mate appreciate the help.
Do you know part number for number 4? The actual bolts
Maarten
Post by Maarten »
N91071701
APgti
Post by APgti »
Can anyone tell me if I should avoid a copy part for the sump? I ask as I can get a sump for £40 but a genuine VW sump is around £200 so a massive difference.
I know some specific parts are adviseable to stay away from anything other than genuine but does anyone know if this is the case for a sump pan on these cars?
I have ordered oil, filter, sump pan bolts and oil sensor gasket now just need to get the actual pan ordered.
I'd think that answer could be "do you feel lucky?".
I hope to treat my wallet and my cars properly and ending up with an issue with a "lookie likie" nice and cheap, sump pan, will cause your engine problems - unless you are lucky.
Only you can make the correct choice for you.
