6R - Multifunction Steering Wheel Retrofit
Post Instructions on DIY modifications here - use all information with caution!
radu
Drives: polo 6r
Re: 6R - Multifunction Steering Wheel Retrofit
Post by radu »
you don't have an electrical diagram of the airbag wiring?
I have a steering wheel from a Passat B6 with everything with a cable...but I don't have any active control
any help///please>?
Xialrahc
Drives: 6R 1.6 TDI 90 FAP 2010
Post by Xialrahc »
Hiroki wrote: Tue Feb 28, 2023 4:22 pm HI all,
Thanks for the wonderful information. I'm new here.
I have 2011 VW polo 1.2 TSI 6R.
I had been a regular no button steering wheel.
I bought this MFSW and trying to retrofit to my car
I followed every steps closely and it was a success.
However, I have 2 issues,
1) Only 4 buttons working.
On the Right, the only one working is "CC Off" button and it working as a Horn.
On the left, Page left --> Song Previous, Page Right --> Song Next, "OK" button reduce the volume
2) No Light
Based on the reading, I believe it must be something to do with the connector ring.
I would like to confirm it with the seniors here for that.
I am planing to add Cruse Control soon and hope I could use the paddle shifter also.
Here are the rest of the photos.
Thanks in advance
Hello Hiroki, did you find a solution to make it work please? I'm exaclty in the same situation than yours :)
Thanks so much !
There is an emulator for that. Mqb to pq
Xialrahc
Post by Xialrahc »
iichel wrote: Thu Mar 27, 2025 12:22 pm There is an emulator for that. Mqb to pq
Thank you so much!
s0234
Drives: Polo 6R
Post by s0234 »
I know I’m a few years too late, I didn’t read the instructions properly so after all the hard work I came to find out my polo airbag doesn’t fit (which again my fault), I was wondering the P/Ns of the airbags that do fit as I’ve done everything for my polo I just need the right airbag. There’s a lot that looks similar (like the touran mk1 or golf mk6) but I don’t know if they’ll actually fit.
what steering wheel do you have? the regular 6R0 steering wheel with buttons on the left? that will take a mk6 golf gti/r-line airbag
s0234
Drives: Polo 6R
Post by s0234 »
I got everything working but for some reason my car's got errors on the dash. Ive tried the steering angle sensor reset procedure but still comes up even a DTC reset doesn't fix it (Ignore the ABS and Seatbelt lights, had the handbrake on and seatbelt off). Any suggestions?
Retali
Post by Retali »
Hello guys, reviving this thread
because i want to add mfa functions...
My steering wheel is the classic T from the scirocco (without MFA)
MY cluster i believe is MFA+ since it comes from a GT
So i will buy the buttons, the wiring loom and module that Ciclo once told me i need .
What i want to know , is that according to this retrofit wiring must be done, for 12v and lin bus or however they are called.
I found this wire https://wibutec-shop.com/Cable-set-for- ... VW-Polo-6R
is there another easier way to do this with this cable without soldering wires etc ?
Or in general any other easier way regarding the wiring ?
