you don't have an electrical diagram of the airbag wiring?
I have a steering wheel from a Passat B6 with everything with a cable...but I don't have any active control
any help///please>?
6R - Multifunction Steering Wheel Retrofit
Xialrahc
- Drives: 6R 1.6 TDI 90 FAP 2010
Re: 6R - Multifunction Steering Wheel Retrofit
Hello Hiroki, did you find a solution to make it work please? I'm exaclty in the same situation than yoursHiroki wrote: Tue Feb 28, 2023 4:22 pm HI all,
Thanks for the wonderful information. I'm new here.
I have 2011 VW polo 1.2 TSI 6R.
I had been a regular no button steering wheel.
I bought this MFSW and trying to retrofit to my car
I followed every steps closely and it was a success.
However, I have 2 issues,
1) Only 4 buttons working.
On the Right, the only one working is "CC Off" button and it working as a Horn.
On the left, Page left --> Song Previous, Page Right --> Song Next, "OK" button reduce the volume
2) No Light
Based on the reading, I believe it must be something to do with the connector ring.
I would like to confirm it with the seniors here for that.
I am planing to add Cruse Control soon and hope I could use the paddle shifter also.
Here are the rest of the photos.
Thanks in advance
Thanks so much !
There is an emulator for that. Mqb to pq
Xialrahc
Thank you so much!
I know I’m a few years too late, I didn’t read the instructions properly so after all the hard work I came to find out my polo airbag doesn’t fit (which again my fault), I was wondering the P/Ns of the airbags that do fit as I’ve done everything for my polo I just need the right airbag. There’s a lot that looks similar (like the touran mk1 or golf mk6) but I don’t know if they’ll actually fit.
what steering wheel do you have? the regular 6R0 steering wheel with buttons on the left? that will take a mk6 golf gti/r-line airbag
I got everything working but for some reason my car's got errors on the dash. Ive tried the steering angle sensor reset procedure but still comes up even a DTC reset doesn't fix it (Ignore the ABS and Seatbelt lights, had the handbrake on and seatbelt off). Any suggestions?
