Location of Blend air flap!
Konc13
Drives: Polo 9n 2003 16v 75ps
Post by Konc13 »
Hello, anyone knows where I can locate the blend air flap in the Polo 9n 2003? I want to replace it and I don’t know where it’s located!
Maarten
Re: Location of Blend air flap!
Post by Maarten »
You mean warm and cold air mixer?
Center low behind the centerconsole, not easy to reach.
Konc13
Post by Konc13 »
Accessible from passengers side if glovebox is out?
Maarten
Post by Maarten »
No that is the fresh air flap
The cold and warm mix flap is located near the footwell in the center
Konc13
Post by Konc13 »
So for the hot and cold air mix I need the V68 motor? That is located in the evaporation somewhere in the middle?
Maarten
Post by Maarten »
It is located inside nr 37
Nr 6 is the actuator
HVAC polo 2003.jpg (107.81 KiB) Viewed 28250 times
Maarten
Post by Maarten »
Nr 31 is for recirculation (the fresh air flap)
HVAC polo 2003 .jpg (75.32 KiB) Viewed 28243 times
Konc13
Post by Konc13 »
The thing that I want isn’t the motor? (Nr27)? With part number 6Q0 907 511.
Maarten
Post by Maarten »
Konc13 wrote: Wed Mar 12, 2025 9:13 am So for the hot and cold air mix I need the V68 motor? That is located in the evaporation somewhere in the middle?
The V68 is the one that regulates the temperature mix indeed
Maarten
Post by Maarten »
Konc13 wrote: Wed Mar 12, 2025 9:21 am The thing that I want isn’t the motor? (Nr27)? With part number 6Q0 907 511.
Yes it is
Konc13
Post by Konc13 »
Do you think the steps of this thread are the correct ones to replace the motor?
viewtopic.php?t=52145
Maarten
Post by Maarten »
Looks like it yeah
