Re: iichels Polo 6R 1.6TDI DSG --> OEM++ R-Line conversion
a 7E0 937 089C should support TPMS high (address 65) yes. Kessy should be available too, but keep an eye out for the correct key frequencies.
patil
Interestingly, 7E0 937 090D BCM has same HW and SW as 089C ( H82, 0762) !!!iichel wrote: Sat May 18, 2024 4:30 pm a 7E0 937 089C should support TPMS high (address 65) yes. Kessy should be available too, but keep an eye out for the correct key frequencies.
If you'd ask me the difference between 089/090, it's probably in the presence of address 61 in the 090 gateway. And perhaps the LIN pin for atlernator/BDM, otherwise it's identical.
It's only been 10,5 months since I posted here lol
DQ250 gearbox mount for PQ25 FWD/AWD
https://imgur.com/a/Zzgk6kH
Sweeeeet
Sweeeeet
MrCollayder
- Drives: Polo 614 sedan (cczb+dq250 awd+pq35)
Hehe, hope my posts helped you to do it))
Of course! Everyones posts, comments and additions are appreciated
AlexisMtn_
- Drives: Polo 6r GTi 2011-BMW M2-Mitsubishi Evo8
so at the end, why did you go from 4pot to 6pot at the front ? The 4pot in the front is not enough ? not good?iichel wrote: Sat Sep 10, 2022 9:49 pm --> viewtopic.php?p=589677#p589677
Test fit. I need a 12mm spacer to accommodate the rims.
I decided to go for different front calipers for the front axle, Brembo ZL17/ZR17 6-pot calipers (left) I'll retain the 4-pot calipers for the rear axle (right)
Freshly painted in Guards Red:
I really just liked the optics of the 6-piston caliper better. I never drove the 4-piston calipers.
