Parking Sensors
Buci
Drives: 6R 2011
Re: Parking Sensors
Post by Buci »
ciclo wrote: Thu Oct 23, 2025 4:40 pm The CAN bus lines dedicated to the PDC in the PQ25 are called "powertrain", this is also commonly used for the other PQ platforms.
In the PQ25, the powertrain CAN lines are used by several units, including Gateway(BCM), Engine, ABS, Instrument Cluster, G85, OBD2 port, and others depending on the installed equipment.
In my humble opinion, the easiest/least complex place to "join" or splice the CAN lines for the PDC in the 6R is in the CAN lines of the instrument cluster connector.
H to H, L to L, easy peasy.
These CAN bus wire splices or connections should be at God level, or at least at semi-PRO level. Using couplings (VW connectors) is always more reliable.
Grrat. The wiring has the solution for that, I reviewed it. But since I need your modul for 8k connection I decided to while I wait for your modul to connect 4k ops option. Can you tell me can I lay all the wiring for 8k but connect only the wires for 4k option? If so, as I see it I need only to connect two set of wires. Wiring from the modul to instrument cluster for can wires, and wirimg from the senzors to the modul. And the buzzer of course. Codimg vcds and that is it? On whiich side.of the trunck is modul for the left driiving cars?
Buci
Drives: 6R 2011
Re: Parking Sensors
Post by Buci »
Buci wrote: Fri Oct 24, 2025 6:52 am
Hm. This is my setup of wiring for 4k ops. I do not know for what is the grren long wire that goes to the front? Wiring is from aliexp..there is no manual for connecting. Here are the pictures.
Re: Parking Sensors
You can connect everything; the module is the one that determines how it will work based on coding and SW capabilities.
With that crimped JPT terminal, the "green" wire is very likely the +15 (12V) power supply, but I can't say for sure since it's an aftermarket wiring harness... You can be sure by looking at the position it occupies in the T16 connector.
8K 6R: :arrow: https://drive.google.com/drive/folders/ ... sp=sharing
Regarding my 8K 1K8 module, there's no good news at the moment. Weather conditions are preventing me from progressing with my 12K interstellar project... which is normal for this time of year. The job doesn't take more than 2 or 3 hours, but since I'm a guy with multiple existential activities, all the existential conditions have to come together to be able to do it. I always want to have these mods finished as soon as possible... even at the beginning of having projected it.
I don't usually procrastinate these enthusiastic tasks intentionally. Let's hope the masters of the universe grant me a couple of 'normal' days... 😄
Buci
Drives: 6R 2011
Re: Parking Sensors
Post by Buci »
ciclo wrote: Fri Oct 24, 2025 8:00 am You can connect everything; the module is the one that determines how it will work based on coding and SW capabilities.
[/quoti I saw a lot videos online and pdf but nobody is talking about the jpt connection. I opened the connector and this green/black wire is on pin 1. So this is the 12V.
Thanks for the schematics. I am not so good in reading them but I eeady to learn. Can you tell where this wire should go? Fusebox? But how? I saw this jpt terminals on BCM when i did the wiring for the cruise control.
T16, pin 1
T16, pin 1
Buci
Drives: 6R 2011
Re: Parking Sensors
Post by Buci »
Buci wrote: Fri Oct 24, 2025 5:12 pm
Buci
Drives: 6R 2011
Re: Parking Sensors
Post by Buci »
Buci wrote: Fri Oct 24, 2025 5:14 pm
I bought this wiring from ali, other parts are oem new or used.
I just found this on AliExpress:
€79.18 | Parking Front and Rear 8K PDC OPS Install Harness Cable Wire For VW Golf 5/6 Passat B6 Touran JETTA MK5 Mk6 Tiguan Octavia Polo
https://a.aliexpress.com/_EIXgq9q
Re: Parking Sensors
From fuse SB9 to SB16 in the SB fusebox there are +15 signal supplies. Connect the green/black wire there and put a 5A mini fuse in the slot you chose. 6R PDC 4K = SB16
The BCM doesn't have JPT terminals, has MQS or MCP terminals of three different sizes. Nothing to touch here.
Next question I will be forced to apply a surcharge.😁
I too would like to learn much more than I know, but I have to deal every day with an absurd medieval occultism typical of times past. Life is very ephemeral, and there's no time to research everything from ancient times to reach a decent level of knowledge.
Buci
Drives: 6R 2011
Re: Parking Sensors
Post by Buci »
ciclo wrote: Fri Oct 24, 2025 5:57 pm From fuse SB9 to SB16 in the SB fusebox there are +15 signal supplies. Connect the green/black wire there and put a 5A mini fuse in the slot you chose. 6R PDC 4K = SB16
Thank you for all of your help. I will try to ask as little as I can because rhe price of 8k modul is going up I see ;).
I asked before but you missed it. The best place to put pdc modul rear buzzer (left or right side of trunck?).
The same for the front buzzer -behind the radio or oem place if you know it?
Thank youuuuu
Re: Parking Sensors
The J446 PDC unit is installed in the same location for 6R RHD.
Download these PDFs (ask me for permission to download)
In them, you'll find the truth 😄 —I mean, everything you need to know... about what you're asking about.
It's hard to understand why people buy things they don't have the knowledge to do so. There are many tutorials and images online on how to do this job.
The money you don't pay to purchase these items without technical assistance is supposedly what you save because you already know how to install them.
...and yet, 'happily', you make others suffer the losses...
All the information in this thread is at least worth/costs three times what you're going to pay for this mod.
I already gave you a ridiculous price for 'my' 1K8 unit, which I offered you because of the timing of the situation, not because I was selling it like a predator, and the only thing that could happen here is for me to lower that price.
I assure you, I have no intention of selling many of the magical things I own; most people don't deserve them.
Buci
Drives: 6R 2011
Re: Parking Sensors
Post by Buci »
ciclo wrote: Sat Oct 25, 2025 2:49 am The J446 PDC unit is installed in the same location for 6R RHD.
Today I started with the retrofit.
Can high and low 18,19 connected to bcm (my back is done!!)
Regarding fuse box I wanted to connect the +15 wire (12v) to the fuse place number 16 but i think that on the other side there is no wire? Can I use number 15 place because the wire is there?
Buci
Drives: 6R 2011
Re: Parking Sensors
Post by Buci »
Buci wrote: Sat Nov 01, 2025 6:53 pm
I have a picture. Green is empty space for fuse number 15, next to him there is a wire (red/white).
On place 16 both holes are empty, without wires.
What is the right place?
Buci
Drives: 6R 2011
Re: Parking Sensors
Post by Buci »
Buci wrote: Sat Nov 01, 2025 7:06 pm
Re: Parking Sensors
For ease of understanding, a fuse has an input 'A' and an output 'B'.
In the 6R SB fusebox, from fuse 9 to fuse 16 input A is the same for all fuses and is called the SUPPLY BAR. In this case it is a supply bar with a +15 signal (ignition switch ON).
Output B is where the systems/components are connected.
Therefore, you can choose any output B of this row of fuses to insert the appropriate terminal/wire and then install the fuse to protect and feed the system you are connecting.
Buci
Drives: 6R 2011
Re: Parking Sensors
Post by Buci »
ciclo wrote: Sat Nov 01, 2025 8:56 pm For ease of understanding, a fuse has an input 'A' and an output 'B'.
Thanks, but did I did it riight? Every fuse has two wires.
So I selected the fuse 15, that already had one wire input A and I connected the pdc modul next to it. Is that Ok? Picture can help.
Buci
Drives: 6R 2011
Re: Parking Sensors
Post by Buci »
