Apologies for very late reply.ciclo wrote: Thu Apr 03, 2025 2:48 am It makes me think that either the brake pad lifespan has decreased considerably compared to those used years ago, or that the driver assistance systems -combined with the automatic transmission- are over using the brakes.
I don't want to think badly, and that since it's a "NEW" vehicle with a few Kms on it at the time of purchase, someone decided to reduce them?...
What do you mean by an indelible warning? Isn't it possible to clear the DTC 'as usual' once the brake pads have been replaced?
VW's insanity —and future decline— would be absolute if it required paying for an online connection to clear this DTC.
I guess since my good friends already have a Toyota (with all the wiring from the factory) and the philosophy is to go for good quality, I'll have to buy a Toyota (neither American nor European cars, only Asian or UK cars
Wednesday,11,February,2026,19:48:17:09269
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.4
Data version: 20250822 DS365.0
www.Ross-Tech.com
VIN: WVGZZZA1ZLV077835 License Plate:
Chassis Type: A1-VW27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 3C 42 44 4B 52 5F 65 6D
75 A5 BB BC CA D6 D7
VIN: WVGZZZA1ZLV077835 Mileage: 100140km-62224miles
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
75-Telematics -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DPCA) Labels:. 04E-907-309-V1.clb
Part No SW: 05E 906 018 AT HW: 05E 907 309 H
Component: R4 1.5l TFS H20 9640
Revision: 8AH20000 CVN: 5E8A0C2D
Coding: 0125003223641D0830000000000000000000000000000000
Shop #: WSC 00020 043 00000
ASAM Dataset: EV_ECM15TFS01105E906018AT 003003
ROD: EV_ECM15TFS01105E906018AT_003.rod
VCID: 77A8E2A6DF4F07E2BF9-8022
VINID: 9E65EAAAA441A9C9801C720314E84F2DE4
Readiness: 1110 0001
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 050 J HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1911
Revision: 00005009 Serial number: CU501911185682 CVN: ABB5E1C0
Coding: 0014
Shop #: WSC 17734 418 534600
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021.rod
VCID: 3C223D8AA6E9E4BA92B-8068
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 DK HW: 5Q0 614 517 BN
Component: ESC H35 0113
Revision: 00000000 Serial number: 63139000003538
Coding: 46FA8A7D90272473477F060362C82562510924E26046A4733822F00A52A24B0B00000523525212121035351919323200
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
VCID: 7DA4F08EFD732DB2E55-8028
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0534174099 Dataset Number: V03935301VA 0001
Coding: 1F20200723
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_KessyHellaMQBAB 004052
ROD: EV_KessyHellaMQBAB_VW27.rod
VCID: 45D4586ED523A572FD5-8010
Rear lid opener control module:
Subsystem 1 - Part No SW: 3GD 962 243 D HW: 3GD 962 243 D
Component: GEB.F.Heckoef H17 0908
Serial number: 05086671
Address 08: Auto HVAC (E87) Labels:| 5G0-907-044.clb
Part No SW: 17G 907 044 AN HW: 17G 907 044 AN
Component: AC Automat H11 1501
Revision: 20K07000 Serial number: 00000A00811480
Coding: 061200242001100D1105004C12145836
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_ACTouchPrehVW37X 001010
ROD: EV_ACTouchPrehVW37X_VW37.rod
VCID: 76B6EFA2D8457EEAA4F-8022
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 EC HW: 5Q0 937 084 EC
Component: BCM MQBAB H H44 0511
Serial number: B2701012207200 Dataset Number: V03935394NB 0001
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_BCMMQB 022001
ROD: EV_BCMBOSCH_022_VW27.rod
Rain/Light Recognition Sensor:
Subsystem 1 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 051 0206
Serial number: S6Y19M10D15H05M19S28
Coding: 0018DD
Anti-theft alarm system sensor:
Subsystem 2 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY153350TTJ
Alarm horn:
Subsystem 3 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000000754028
Roof electronics control module:
Subsystem 4 - Part No SW: 3G0 947 105 D HW: 3G0 947 105 D
Component: J528 Dachelek H08 0008
Serial number: 16112500010020D
Coding: F38380
Steering Column Switch:
Subsystem 5 - Part No SW: 5Q1 953 521 KS HW: 5Q1 953 569 K
Component: Lenks.Modul H24 0190
Serial number: 05000405202300100730
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 K HW: 5QA 919 298 A
Component: PLA 3.0 12K H08 0073
Serial number: 000150057322125 Dataset Number: V03935342EN 0001
Coding: 8379567851
ASAM Dataset: EV_EPHVA2CAU3700000 009055
ROD: EV_EPHVA2CAU3700000_010_VW37.rod
VCID: 58EA811A3291289A963-800C
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 AB HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0397
Dataset Number: V03935376DS 0001
Coding: 300C47C35CFF8748949C812483578780000000000000000034
ASAM Dataset: EV_ACCMRRCONTIVW376 003018
ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
VCID: 74B2D5AACE396CFA9AB-8020
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 3Q0 959 655 CM HW: 3Q0 959 655 CM
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z2PPMRKF2 Dataset Number: V03935298UN 0001
Coding: 88CCC0C0000000005C5400CF008840000065
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
ROD: EV_AirbaVW21TS6VW48X_VW27.rod
VCID: 0B40AE56B3C71302EB1-805E
Subsystem 1 - Part No SW: ----------- HW: 454 002 910 19
Component: SideSensor_Df 008 0887
Serial number: 357000000004A1316142
Coding: 2D2D2D
Crash sensor for side airbag: passenger side:
Subsystem 2 - Part No SW: ----------- HW: 454 002 810 19
Component: SideSensor_Pf 008 0887
Serial number: 35800000000C98B8424V
Coding: 2D2D2D
Subsystem 3 - Part No SW: ----------- HW: 454 802 210 19
Component: SideSensor_Dr 301 0148
Serial number: 35100A0CB121A000000D
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 454 802 510 19
Component: SideSensor_Pr 301 0148
Serial number: 35200E4A8381A000000P
Coding: 2D2D2D
Subsystem 5 - Part No SW: ----------- HW: 454 802 310 19
Component: FrontSensor_D 304 0149
Serial number: 35500964D2C1A000000R
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 17A 920 790 B HW: 17A 920 790 B
Component: KOMBI 503 4310
Coding: 65FC00986E88080C0180770F1801000000000906
ASAM Dataset: EV_DashBoardVDDMQBA0 001042
ROD: EV_DashBoardVDDMQBA0_001_VW27.rod
VCID: 2616FFE248654E6AD4F-8072
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AR HW: 3Q0 907 530 E
Component: GW MQB High 524 5502
Serial number: 14022210802625 Dataset Number: SET_FPA_MOD 0001
Coding: 030900046F085600DB1702DC1E0F00010001070000000000000000000000
GVL: 014E3C000800060040CC80008000C80010000000000200000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_VW27.rod
VCID: 7F580A86F77F3FA2F79-802A
Generator:
Component: 5-01-14-01-04
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 1EA 959 442 F HW: 1EA 959 442 F
Component: MFL H03 0219
Serial number: 17038315111572401137
Coding: AF2B00
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Component: J367-BDMHella H10 9070
Serial number: 3250843205
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Serial number: 19000332474005
Coding: 0800000000000000
ASAM Dataset: EV_ELVMarqMQBA0 002002
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 313C1CBE71AB19D231D-8064
Address 3C: Lane Change (J1086) Labels:| 2Qx-907-686-V2.clb
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0150
Serial number: 14520011985865 Dataset Number: V03935308HF 0001
Coding: 92A54640
ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
VCID: 392C249EA9DBD19289D-806C
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H06 0150
Serial number: 14520011913860
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 K HW: 5Q4 959 593 K
Component: TSG FS 007 0485
Serial number: 0000397175085 Dataset Number: V03935313VT 0001
Coding: 00151A20D001028000001000
ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
VCID: 4DC4604E0D535D32355-8018
Subsystem 1 - Part No SW: 5Q0 959 408 HW: 5Q0 959 164 Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000036110727
Coding: 1D0000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 AB HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 131 1082
Dataset Number: V03935312TK 0001
Coding: 971F0000
ROD: EV_SteerAssisMQB_015.rod
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0367
Serial number: 17111910522941 Dataset Number: V03935304ZR 0001
Coding: 000000070900204600000900000000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 003003
ROD: EV_MultiModulContiVW48X_003_VW27.rod
VCID: 372822A69FCFC7E27F9-8062
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 K HW: 5Q4 959 592 K
Component: TSG BFS 007 0485
Serial number: 0000396858048 Dataset Number: V03935313WJ 0001
Coding: 00151020DC01028000001000
Shop #: WSC 00020 999 12345
ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
VCID: 4CC26D4AF649543A22B-8018
Subsystem 1 - Part No SW: 5Q0 959 407 HW: 5Q0 959 163 Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000036011483
Coding: 050000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 864 C HW: 3Q0 035 864 C
Component: MU-S-N-ER 854 0879
Serial number: Dataset Number: 5G0CV1v____ 0001
Coding: 02730601BE0000004111000100180A201F0500B601200000C6
ROD: EV_MUStd4CDELP_VW27.rod
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav 361 8214
Serial number: VWZ6ZHX1471458
Data carrier:
Subsystem 2 - Part No SW: 5NA 919 866 FH HW: -----------
Component: MRM2 2024/25 --- 2210
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 30000000255241 Dataset Number: rdkseditor 0204
ROD: EV_RDKBERU30_005.rod
VCID: 382A219A92D1C89A763-806C
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 T HW: 5Q0 959 107 C
Component: HDSG-Modul H12 0271
Revision: -------- Serial number: PLG01908160021 Dataset Number: V03935301SX 0001
Coding: 1C28
ASAM Dataset: EV_DeckLidCONTIAU736 001017
ROD: EV_DeckLidCONTIAU736_VW27.rod
VCID: 49CC545EF93B411219D-801C
Address 75: Telematics (J949) Labels:* None
Part No SW: 5NA 035 284 C HW: 5NA 035 284 C
Component: OCULowMQBLGE H19 0825
Revision: -------- Dataset Number: V03935298KU 0001
Coding: 02720601EA16380D3F1CBE000045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004049
ROD: EV_OCULowMQBLGE_004_VW27.rod
VCID: 3D24308EBDF3EDB2A55-8068
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 2Q0 980 653 D HW: 2Q0 980 653
Component: MQB MFK 3.0 H16 1421
Serial number: E79132511211900 Dataset Number: V03935410YR 0001
Coding: 0000011811EEC028889F24800020002201430000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 007042
ROD: EV_MFK3ValeoMQB_007_VW27.rod
VCID: 36362FA298C53EEA64F-8062
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Dataset Number: V03935280ME 0001
Coding: 508040727602
ASAM Dataset: EV_SunRoofCONTIAU736 009011
ROD: EV_SunRoofCONTIAU736_009_VW27.rod
VCID: 75B4E8AEC54375F2AD5-8020
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AH HW: 7P5 941 591 A
Component: LED1L H07 0009
ASAM Dataset: EV_LED_PLUS_L_KEBODAVW416 001003
ROD: EV_LED_PLUS_L_KEBODAVW416_VW27.rod
VCID: 025E8372848D524A987-8056
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H07 0009
ASAM Dataset: EV_LED_PLUS_R_KEBODAVW416 001003
End----(Elapsed Time: 01:47, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
---------------------------No fault code found.----------------------------
ciclo wrote: Thu Feb 19, 2026 6:13 pm The new 312mm brake discs would be a perfect match for wheels of at least 18 inches. It's not just about aesthetics, but also about performance. The braking will be very satisfying, ... exceptionally satisfying.![]()
