Polo 6R ABS CODING
Re: Polo 6R ABS CODING
Any updates on this?
amrieazhari94
- Drives: polo 1.6 hatchback
hi, i'm new here. can anyone help to calculate polo hatchback 1.6 mpi RHD abs90 long coding
[/Wednesday,12,November,2025,11:05:02:16365
VCDS Version: 24.7.0.0 HEX-V2 CB: 0.4643.4
Data version: 20240715 DS356.3
www.Ross-Tech.com
VIN: PPVZZZ60ZJL100070 License Plate:
Chassis Type: 60-VW25 (XXX)
Scan: 01 02 03 08 09 15 17 19 25 44 56
VIN: PPVZZZ60ZJL100070 Mileage: 77120km-47920miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CLSA) Labels: None
Part No SW: 03C 906 014 BB HW: 03C 906 014
Component: CLSA-MM7GV H02 8765
Revision: --H02--- Serial number: XXXXXXXXXXXXXX
Coding: 00000000000000000000
Shop #: WSC 23440 003 1048576
VCID: 5EE59E65E0246B2A0DF-5160
VINID: 8209AAAAA180A9A7010000070054984C84
Readiness: 0110 0001
Address 02: Auto Trans Labels: 09G-927-750.clb
Part No SW: 09G 927 750 LK HW: 09G 927 750 LK
Component: AQ 250 6F 2238
Revision: 00H98000 Serial number:
Coding: 0000328
Shop #: WSC 01234 785 00200
VCID: 055791092932D8F26C5-5160
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 907 379 AQ HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0003
Serial number: --------------
Coding: 000000000000000000000000000000000000
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 0D47A9297DD2A0B2245-8058
2 Faults Found:
0887 - Control Module
C104A F0 [00011000] - Incorrect VIN
Intermittent - Confirmed - Not Tested Since Memory Clear
Fault Priority: 2
Fault Frequency: 1
Reset counter: 145
Mileage: 76869 km
Date: 2025.08.21.
Time: 00:00:24
0883 - Control module not coded
U1013 00 [00011000] - -
[VehicleConfigUncoded]
Fault Priority: 2
Fault Frequency: 10
Reset counter: 166
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 41DF4519718A34D210D-8014
Part No SW: 6RU 937 087 R HW: 6RU 937 087 R
Component: BCM IM H+4 H42 0452
Revision: BZ042001 Serial number: 6800 248170030
Coding: 38B02BBF08A10000003800002C2B049000C0400F60040000200000000000
Shop #: WSC 83300 833 00003
VCID: 71BFD5D901AAE452A0D-8024
Subsystem 1 - Part No SW: 6R0 959 802 DF HW: 6R0 959 802 DF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 022 1552
Serial number: 13202722170612222342
Subsystem 2 - Part No SW: 6R0 959 801 DD HW: 6R0 959 801 DD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 022 1552
Serial number: 12102723170613132231
Subsystem 3 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Serial number: 1581715074301391AB1B
Coding: 240000
Subsystem 4 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 022 1552
Serial number: 13202728170711091919
Subsystem 5 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 022 1552
Serial number: 13102729170816071534
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Component: VW10AirbagU0F H10 0020
Revision: -------- Serial number: 003GW01AMAS- Dataset Number: v00300666RU 0001
Coding: 003046
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 49CF5D39493AFC92C8D-801C
Part No SW: 6RF 920 861 D HW: 6RF 920 861 D
Component: KOMBI H02 5006
Coding: 110A000000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
VCID: 4CC1642D4648E9BAF3B-8018
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6RU 909 901 HW: 6RU 937 087 R
Component: GW-K-CAN TP20 H42 0452
Revision: BZ042001
Coding: 002300
VCID: 196FCD79B99A4C12B8D-804C
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Component: IMMO H02 5006
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6A8DC2B52CFC178AE17-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Dataset Number: 621074v____ 0124
Coding: 0001010001010000
Shop #: WSC 00078 790 12345
ROD: EV_SteerAssisNSK_014_VW12.rod
VCID: 41DF4519710A34D210D-8014
Part No SW: 6RF 035 187 C HW: 6RF 035 187 C
Component: Radio 557 5515
Revision: -------- Serial number: VWZ7Z2R7102107
Coding: 0E00040000000F
VCID: 49CF5D3949BAFC92C8D-801C
End----(Elapsed Time: 01:46, VBatt start/end: 11.7V/11.2V. VIgn 11.2V)-----]- ciclo
Read carefully, then download the zip file and place it in your user folder. It will make your work easier.
Hi Guys, Aditya here from India. New to the forum.
I own a VW Vento Highline Plus 1.2TSI (6R) Engine code- CBZB, Transmission - DQ200.
I have recently upgraded the front brakes from stock 256mm to 288mm. I need your help for the ABS Long coding. I have a VCDs cable handy which I bought from Ross-tech.
Also can you help me out with the fault codes? I've recently got the instrument cluster changed to the Maxidot cluster.
Here is the full scan:
Wednesday,17,December,2025,09:18:53:17288
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.4
Data version: 20250822 DS365.0
www.Ross-Tech.com
VIN: MEXJ19608LT057764 License Plate: 8569
Mileage: 70030km-43514mi Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 55 5F 77
VIN: MEXJ19608LT057764 Mileage: 70030km-43514miles
77-Telephone -- Status: Not registered 0001
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number: CVN: 9408DB59
Coding: 00250056232400080000
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
ROD: EV_ECM12TFS02103F906070FD_004.rod
VCID: 6D87DAB3ED15C6E2555-8038
VINID: 755A1A04918021C9001471C6105DF8E5F7
Readiness: 0000 0000
Part No SW: 0AM 300 043 C HW: 0AM 927 769 F
Component: GSG DQ200G2_PQ 050 2601
Revision: 00005008 Serial number: CU501906266887
Coding: 0000020
Shop #: WSC 01357 011 00200
VCID: 2B0314AB1F0108D20B1-807E
Part No SW: 6R0 907 379 CB HW: 6R0 907 379 AS
Coding: 62DD2C63422807C7461B346F4255E0800908
ROD: EV_Brake1ESP90iBOSCH_003_VW23.rod
VCID: 00599307CA873B8A8E3-8054
Serial number: 07071913471021
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5EDFFB0734D7AFCF-802A
Revision: V0000000
VCID: 41DF5603818DF282C1D-8014
Part No SW: 7E0 937 089 D HW: 7E0 937 089 D
Component: BCM PQ25 MMI4 H84 0772
Revision: BB084001 Serial number: 2602 180190288
Coding: 3A984BFF08A10000013806006ECB06900080634F60CE3140230000000820
Shop #: WSC 14325 142 18675
VCID: 34310FD7CE3F572A5AB-8060
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 180619 05 50 0106
Coding: 022800
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 023 2522
Serial number: 13202848190704144513
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 023 2522
Serial number: 13202849190704115520
Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 022 1523
Serial number: 13102728190711181642
Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 022 1523
Serial number: 13102729190711055835
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 Q HW: 6C0 959 655 Q
Component: Airbag VW12 001 0503
Revision: -------- Serial number: 003FZABQ504N Dataset Number: V03935303ZE 0001
Coding: 88C0C0000000000054000000008000000065
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_AirbaVW12TS6VW25X 001001
ROD: EV_AirbaVW12TS6VW25X_VW25.rod
VCID: 41DF5603810DF282C1D-8014
Serial number: 3490010013206422200$
Crash sensor for side airbag: passenger side:
Serial number: 35000100132091A2200$
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 140A00
VCID: 47CB481BAF29CCB20F9-8012
Part No SW: 7E0 909 901 HW: 7E0 937 089 D
Revision: BB084001
Coding: 002300
VCID: 6889ABA7C277E3CA263-803C
1 Fault Found:
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 69779 km
Time Indication: 0
Date: 2025.12.06.
Time: 11:44:03
Component: IMMO H05 0805
Serial number:
VCID: 6A8DD1AFDCFBD1DA307-803E
Dataset Number: V03935277QZ 0001
Coding: 0001000000000000
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Revision: -------- Serial number: --------------
Coding: 0D0C000001000000
ROD: EV_HeadlRegulVWLWRCC_VW25.rod
VCID: 3A2D21EFECDBA15A807-806E
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 5K7 035 200 M HW: 5K7 035 200 M
Component: MU-S--ROA H41 0480
Serial number: VWZAZ2U0578263 Dataset Number: 5K7CV1v____ 0001
Coding: 0284010EAA00000011150001001028001F0100D400200100CE
Shop #: WSC 69905 136 139810
ROD: N/A
VCID: 2E051DBF20937DFA2CF-807A
No ASAM data for: "EV_MUStd4CTSAT" (VW25)
8 Faults Found:
1597 - ROD - Unknown Error Code
- 00 [00001001]
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:12:20
1598 - ROD - Unknown Error Code
- 00 [00001001]
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:12:20
1543 - ROD - Unknown Error Code
- 00 [00001001]
Fault Priority: 4
Fault Frequency: 1
Reset counter: 148
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:02:11
1555 - ROD - Unknown Error Code
- 00 [00001001]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 148
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:02:11
1556 - ROD - Unknown Error Code
- 00 [00001001]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 148
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:12:20
6720 - ROD - Unknown Error Code
- 00 [00001000]
Fault Priority: 3
Fault Frequency: 2
Reset counter: 206
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:24:23
0001 - ROD - Unknown Error Code
- 00 [00001001]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 148
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:02:12
0003 - ROD - Unknown Error Code
- 00 [00001001]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 148
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:02:12
Address 77: Telephone
Cannot be reached
End----------(Elapsed Time: 01:26, VBatt start/end: 12.1V/12.0V)-----------
------------------------------9 Faults Found-------------------------------
www.Ross-Tech.com
Coding: 0000020
Coding: 01
Revision: V0000000
Coding: 022800
Coding: 140A00
Revision: BB084001
Coding: 002300
1 Fault Found:
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 69779 km
Time Indication: 0
Date: 2025.12.06.
Time: 11:44:03
Serial number:
ROD: N/A
8 Faults Found:
- 00 [00001001]
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:12:20
- 00 [00001001]
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:12:20
- 00 [00001001]
Fault Priority: 4
Fault Frequency: 1
Reset counter: 148
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:02:11
- 00 [00001001]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 148
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:02:11
- 00 [00001001]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 148
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:12:20
- 00 [00001000]
Fault Priority: 3
Fault Frequency: 2
Reset counter: 206
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:24:23
- 00 [00001001]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 148
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:02:12
- 00 [00001001]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 148
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:02:12
Cannot be reached
Hi Aditya, welcome.
Please read the post before yours because it's highly likely you'll be able to do it yourself.
Regarding the other faults in the autoscan, you need to correctly code the Byte2 of GW and remove the phone module from the GW installation list.
If you get stuck at any point, ask again. I'm sure that, along with other respected users, we can solve it.
Yeah, I actually think you’re spot on there. From what you described it doesn’t sound like something to ignore, and leaving it could just make things worse later. Better to deal with it properly now than regret it down the line.kolkata fatafat
Totally—better to handle it now than face bigger problems later.Kolkata Fatafatkumarbr wrote: Fri Feb 13, 2026 2:35 pm Yeah, I actually think you’re spot on there. From what you described it doesn’t sound like something to ignore, and leaving it could just make things worse later. Better to deal with it properly now than regret it down the line.
Welcome to both of you, your first post is certainly intriguing.William wrote: Sat Mar 21, 2026 10:50 amTotally—better to handle it now than face bigger problems later.Kolkata Fatafatkumarbr wrote: Fri Feb 13, 2026 2:35 pm Yeah, I actually think you’re spot on there. From what you described it doesn’t sound like something to ignore, and leaving it could just make things worse later. Better to deal with it properly now than regret it down the line.
However, I completely agree...
There are already too many psychopaths making EXTRAORDINARY MISTAKES, running rampant and ruining the lives of others with no respect for humanity.
Has anyone on this 'wonderful' planet with a standard IQ (I'm referring to 'standard' in the European/Asian sense
Even the water where I live, which is moderately suitable for human consumption (not drinkable), is already the property of those who own a little more than half of everything that exists. Damn ass-licking/'representatives' of the people.
