Re: ciclo's Polo. R-line 1.2 TSI 90hp 119gr.🤝
Y-splice for Alternator LIN wire. Battery Monitor and AGM Battery installed.
Related (video): viewtopic.php?p=610206#p610206
New Battery Monitor.
New AGM Battery.
Fuse for BM not installed. Everything remains the same as before, pending Alternator installation.
After the Alternator installation the repinning of the green T4 connector (LIN, insulation of old wires -PWM, DF-).
AGM battery in optimal condition after more than a week stored.
I'm going to install the alternator in the garage in case any problems arise with the 'new' one, so there will be few photos of the process due to the lack of light.
However, the installation process is very similar to the one I did for the 140A alternator in our Golf 7.5. :arrow: viewtopic.php?p=604140#p604140
I hope to finish the process of my new project by the weekend.
Preliminary notes for alternator replacement (erWin).
Plus some notes mentioned in previous posts.
It all started here: viewtopic.php?p=610167#p610167
Before replacing the Alternator in my Eco-friendly project 💚🌳🌴🌵🌿🍀🍃🤭, I replaced the battery monitor connector with one that has a safety locking mechanism, which is the most common type used for these systems in the VW Group.
Note: There are more possible references.
This 4F0 reference is used in Porsche.😋
Inspires greater confidence. ✅
I'm trying to find a good time to replace the Alternator in the garage sometime this weekend.🌄
Today I've been checking the Energy Recovery function in our Golf 7.5.
Once the appropriate conditions are met (Battery State of Charge -SoC-, Battery State of Health -SoH-, according to the parameters/algorithms... and many other requirements - electrical consumers, temperatures -), in my case, during acceleration the voltage remains at or drops to 12.8V, while during deceleration or coasting, the voltage instantly rises to ~14.8V. This means that the Energy Recovery function, alternator freewheel pulley, and software of the units involved are working perfectly.
Note: This happens the same way whether the Start/Stop function is activated or deactivated, and also in any driving MODE.💎
For example: If you leave the vehicle parked for several days, the battery's SoC will drop, so the Energy Recovery function will only work once the SoC reaches the appropriate value (~80%), that is, after driving for half an hour to an hour (voltage above 14V).
Other codings I'll be applying to my 6R (ECU, BCM/GW):
As I already mentioned, I don't want the Start/Stop 'function', it would require the installation of other parts... Besides being destructive, it's not a useful function for my fortunate and usual circumstances (no traffic jams or similar🚦).
The most fun part of my Eco-friendly project is approaching... :lol:
Happy weekend to everyone, without exception!
https://www.youtube.com/watch?v=yFpCVmI-Xbs
Factory Alternator 140A
Vs:
Indetic aspect.
UPD:
I bought the 140A LIN Alternator BOSCH on eBay for the same price as a LIN voltage regulator.
It seems that the only thing that changes 'in my case' (ETKA: 140A 1.2TSI CBZB/CBZC) is the voltage regulator. 🧠🤔...💰🤭🤷‍♂️
UPD:
I finally bought a new LIN voltage regulator... with the idea of ​​installing it on the 'factory 140A alternator' (PWM, DF), and thus have a spare LIN alternator.😊
Ambush: :lol:
As shown in the image, removing the contact locking mechanism allows you to connect the connector and continue with the project.
UPD:
Refurbished 140A LIN Alternator Installed. Green T4 connector repinned.
-Alternator installation according to erWin.
Highlights.
There is no need to remove the coolant fan at all (another urban legend or something from inexperienced people/workshops).🤷‍♂️
Read previous post.
:arrow: viewtopic.php?p=610278#p610278
-Repinned Green T4 connector. LIN.
The insulation of the old PWM and DF signals/wires/terminals is temporary during testing; it will be improved later (insulation T2 connector).
UPD:
:arrow: viewtopic.php?p=610410#p610410
Fortunately, everything worked smoothly on the first engine start.
Due to the lack of a fuse for the BM (SC6 5A) and the general coding, the 'new' 140A LIN Alternator is in 'protection mode', supplying only 13.3V according to the cabin voltmeter.🤸‍♂️
I'll do the coding and testing for my Eco-friendly project tomorrow...
POLO 6R. Eco-friendly Project. Absolute Success!
"A record-breaking Recuperation: The 7L3 to 7L7 OEM breakthrough". 💎✌
From a vehicle without 'BlueMotion technology' from the factory to a vehicle with 'GreenMotion' technology (by ciclo). 🌳🤭
Both the intelligent AGM battery charging management and energy Recuperation work like a charm! ✅🧙‍♂️
This project/experiment began here:
:arrow: :arrow: :arrow: viewtopic.php?p=610167#p610167 (previous page). Essential READING!
Final steps, Coding and testing:
Previous note:
I couldn't test the 6C0915181'D' Battery Monitor because the AliExpress store sent me one with the wrong software. I will test the accuracy of the 6C0915181'D' software later.
Fortunately, I have two other Battery Monitors, the 6C0915181'B' and a 7E0915181'K' (T6), which work perfectly.
6C0915181'B'
7E0915181'K'
I install the SC6 5A fuse so I can code and start testing.
Applied Coding:
Address 19: CAN Gateway (J533): GW installation list - Enable 61.
Address 61: Battery Regul. (J840):
- Coding: 032A1A64 :arrow: https://postimg.cc/WdzWJbKt
- Long Adaptation (Ch_04): 060 VA0 05052026DT
Address 09: Cent. Elect. (J519): Byte10 Bit0 Enabled.
Address 01: Engine (J623-CBZC): Not required, the powertrain data bus is functioning correctly for load management and energy recovery.
Regarding battery coding. Long Adaptation. Channel 04.
-Battery capacity (3 digits): 60Ah in my case. You can enter a lower capacity if you want a more aggressive energy recovery system, but the total charge management (80%) will be affected. I don't recommend it.🤷‍♂️
-Vendor (3 digits): VA0 in my case.
-Serial number (10 digits): 05052026DT in my case. This is the battery installation date for future reference. You can enter any number/name/digits you want, for example, 666VAGHELL 😄, but keep in mind that changing even a single digit of the previous battery's serial number will cause the system to think you've installed a new battery.
Once the coding is done, the alternator, exits the 13.3V protection mode, and resumes supplying the charge correctly, ~14.5V.
For testing, it is recommended to have a digital voltmeter connected in the cabin for 'instant readings', and even better if it is installed.
In the image, IGN ON, ENG OFF.
Okay, with diagnostic tools connected to OBD2 (VCDS, VCP, ODIS, etc.) you have the possibility of seeing all the data in real time through the measurement values (SoC, Temps, Generator, etc.), but logically it is safer to observe the instantaneous readings of the voltmeter during road tests.
Tests:
Battery charge management and energy recovery functions work perfectly with both battery monitors, just as I explained in the tests I performed on our Golf7.5.
:arrow: :arrow: viewtopic.php?p=610282#p610282
For now, I'll leave the 7E0 battery monitor for further observation.
Objectives achieved:
- Increased lifespan of the components involved: battery, alternator, starter motor, etc. 🤷‍♂️
- More precise (intelligent) battery charging management.✅
- Slight reduction in fuel consumption.✅
- Less effort/more power during acceleration.✅
- Energy recovery during deceleration.✅
VCDS Autoscan.
Monday,11,May,2026,18:32:56:32438
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4701.4
Data version: 20260320 DS375.1
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: 61 BATT_REG J-367 BDM OK!
Mileage: 101210km-62888mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 3C 44 55 5F 61 65 6C
VIN: WVWZZZ6RZDY0CICLO   Mileage: 101210km-62888miles
Address 01: Engine (J623-CBZC)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000 CVN: 9A6217E3
   Coding: 001100F6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   VCID: 6A8D3FD44CF8023A717-803E
   VINID: 9E69EAAAA1A2A94A400030C808A8E303EA
Readiness: 0010 0001
Address 03: ABS Brakes (J104)       Labels:. User\6R0-907-37x-ESP82.lbl
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D30040D700
   Shop #: WSC 40308 002 104857
   VCID: 025D77745448FA7AD97-8056
   Serial number: 08021613470174
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5038420709E9ABDF-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0812
   Revision: V0000000
   VCID: 3829D59C425460AA373-806C
   Revision: B9084001    Serial number: 2502 179190157
   Coding: 3CB02FBF48E12400B3380F317CEB9FD05AC8670E600D39D0200400030800
   Shop #: WSC 00046 123 12345
   VCID: 2D07F4C8BD16D502545-8078
   Component: RLHS 220816 0  42  0106
   Coding: 0228DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Coding: 1000A3
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
Address 10: Park/Steer Assist (J791)       Labels:. 5Q0-919-298.clb
   Part No SW: 1K8 919 475 D    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0480
   Revision: --------    Serial number: 39491531301709 Dataset Number: 2KC800t____ 0003
   Coding: 0031167001
   ASAM Dataset: EV_EPHVA2CVW364GP00 001010
   ROD: N/A
   VCID: 3B23CA9073E24BB2DA1-806E
No ASAM data for: "EV_EPHVA2CVW364GP00" (VW37 *)
1 Fault Found:
12718592 - ROD - Unknown Error Code
          - 00 [00001000]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 251
                    Mileage: 101083 km
                    Date: 2026.05.05.
                    Time: 00:45:11
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP Dataset Number: v00305696R0 0001
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD9F542C38E23A517-801E
   Serial number: 3575HRB405N1C4LI7929
   Crash sensor for side airbag: passenger side:
   Serial number: 3585HRB405B1D5MS8GS2
   Crash sensor for side airbag: driver side rear:
   Serial number: 3515RRB405B17ABS901.
   Crash sensor for side airbag: passenger side rear:
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H04 0805
   Coding: 140E01
   Shop #: WSC 00233 572 00255
   VCID: 47CBA6603F2A1F524E9-8012
   Revision: B9084001
   Coding: 002207
   VCID: 688945DC5274302A673-803C
   Revision: AA001001
   Coding: 0404000000000000000000
   Shop #: WSC 03607 002 104857
   ROD: EV_HighBeamAssisAU316_VW32.rod
   VCID: 2E05F3C4B090AE1A6DF-807A
   Component: IMMO          H04 0805
   Shop #: WSC 12345 123 12345
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 020100
   VCID: 2A0DFFD48CF8C23AB17-807E
Address 3C: Lane Change (J1086)       Labels:. 2Qx-907-686-V2.clb
   Part No SW: 2Q0 907 686 B    HW: 2QD 907 686 A
   Component: HRE3_Kl15_Mst H06 0150
   Serial number: 00006273342269  Dataset Number: V03935359EX 0001
   Coding: 529524A0
   ROD: N/A
   VCID: 392FD09879DE79A2C8D-806C
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2QD 907 685 A
   Component: HRE3_Kl15_Slv  H06 0150
   Serial number: 00006273536997
No ASAM data for: "EV_HREntryHellaGen3Kl15" (VW25)
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F3BEEC0BE5AA712669-807A
   Revision: --------    Serial number: -------------- Dataset Number: 6R0036v____ 0005
   Coding: 0112000001000000
   VCID: 77AB16A00F4AAFD2FE9-8022
   Component: MU-S-ND-ER    H41 0480
   Serial number: VWZAZ2W1480534 Dataset Number: V03935270BD 0001
   Coding: 02620001FF00000051110101C0890A801F0106C400A00100CF
   Shop #: WSC 34480 348 34480
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 25170CE8E566ED429C5-8070
   Data carrier:
   Subsystem 1 - Part No SW: V03 959 822 MM    HW: -----------
   Component: ECE AS 25/26  --- 2410
Address 61: Battery Regul. (J840)       Labels:. User\1K0-907-534.lbl
   Part No SW: 7E0 907 534     HW: 7E0 937 090 E
   Component: Batt.regelung H84 0772
   Coding: 032A1A64
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Component: J367-BDMConti  H03 1050
   Serial number: 75410903001611152716
   Serial number: 40000000050821
   ROD: EV_RDKBERU30_005.rod
   VCID: 372BD6A04FCA6FD23E9-8062
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 4M0 980 556 A
   Component: RVC Compact   H19 0231
   Dataset Number: V03935314JY 0001
   Coding: 010402014600201F000060
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB.rod
End----------(Elapsed Time: 02:12, VBatt start/end: 12.4V/12.4V)-----------
-------------------------------1 Fault Found-------------------------------
Coding: 032A1A64
Coding: 032A1A64
Subsystem 1 - Part No SW: 6C0 915 181 B HW: 6C0 915 181 B
Component: J367-BDM H08 0270
Serial number: 53337D48375881021946
- UPD, May 13, 2026: 7E0915181K, 200 km, works perfectly in all possible traffic conditions. I would say I really like how the battery recovery and charge management are programmed, and it's nice to see the voltage variations on the voltmeter in the center console.
- UPD2, May 14, 2026: 6C0915181B, 100 km, works just as well as the 7E0. Both SWs (7E0...K and 6C0...B) are from late 2016. This makes sense because the management is done by the BCM/GW/BattReg and the battery monitor is just the sensor that sends all the data coming from the negative terminal of the battery.
- UPD3, May 14, 2026: 6C0915181D, next post. :arrow: viewtopic.php?p=610313#p610313
2013 POLO 6R 1.2TSI CBZC 125HP_Stage1 + GreenMotion. 🏎😄
https://www.youtube.com/watch?v=MIyCUBn0KEc
Battery monitor 6C0915181D with HW10 SW9070.
Update to the previous post.
After returning the one I bought from the AliExpress store and receiving a quick refund after providing the required evidence (scan), I bought a 6C0915181D battery monitor from a local auto salvage yard.
I cleaned it, but I also had to polish it to remove the typical corrosion (dark stains) and sulfation from the donor car battery (SK Fabia, I don't know which one 😄).
I did it with a mini polisher, sponge, and a little fine cutting compound. Naturally, the protective electroplating (galvanizing) wore off in some small spots, so it's highly likely I'll repaint it with spray paint (primer, color, lacquer).
However, I'm not too bothered about protecting it, it is easily solvable, and besides, I like the mirror finish... 😅
It works just as well as the previously tested Battery Monitors (7E0K and 6C0B). 💎
Due to their good performance, I do not have sufficient capabilities to make a comparison between them.🤷‍♂️
Additional observations on the Eco-friendly project:
Now, the fuel consumption at idle, under 'normal' conditions, is 0.5 l/h (1.2 TSI). Before this Eco-friendly project, with the old alternator, it never dropped below 0.6 l/h, so it's already reducing consumption at this point.
A short video showing how it recovers energy during deceleration -breaking or coasting- (14.7V) or how the engine works less hard during acceleration (12.9V).
Before the Eco-friendly project, the voltmeter permanently read ~14.4V. thus increasing total consumption.
For example (image rescued from other previous improvements):
Now, once the requirements are met, when you see 12 to 13V on the voltmeter you are consuming less when accelerating (and more power), and when you see 13 to 14V on the voltmeter the energy is 'free'.
2 to 5 little donkeys more.
90HP + Stage1 = 125HP... + 2HP = 127HP. 🔥 🤭
Note:
-The state of charge (SoC) is approximately 80% of the battery capacity (EFB or AGM) because this leaves a margin of 20% to 'inject' the energy from the energy recovery phase into the battery.
-Voltage values ​​can vary from 14.9V to 12.1V depending on several parameters (SoC, Temps, consumers...).
VCDS Autoscan
Thursday,14,May,2026,08:40:35:32438
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: 6C0915181D  OK!
Mileage: 101570km-63112mi   Repair Order:
VIN: WVWZZZ6RZDY0CICLO   Mileage: 101570km-63112miles
   Revision: --------
   Coding: 01
   Revision: V0000000
   Coding: 0228DD
   Coding: 0200A3
   Coding: 1000A3
   Coding: 18BC32
   Coding: 18BC32
   Coding: 0031167001
   ROD: N/A
1 Fault Found:
          - 00 [00001000]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 251
                    Mileage: 101083 km
                    Date: 2026.05.05.
                    Time: 00:45:11
   Coding: 00314D
   Coding: 140E01
   Revision: B9084001
   Coding: 002207
   Revision: AA001001
   Coding: 020100
   Coding: 529524A0
   ROD: N/A
   Coding: 11250
   Shop #: WSC 00788
   Data carrier:
   Coding: 032A1A64
   Subsystem 1 - Part No SW: 6C0 915 181 D    HW: 6C0 915 181 D
   Component: J367-BDMHella  H10 9070
   Serial number: 5943827204
End----------(Elapsed Time: 02:12, VBatt start/end: 12.1V/12.1V)-----------
Coding: 032A1A64
UPD after several kilometers/milles:
'It's super satisfying'.👌
Recommended AGM batteries if 60Ah:
- VARTA A8 or EXIDE EK600. Both batteries are designed with the latest generation AGM technology, ideal for Start-Stop systems with regenerative braking that demand a very high charge acceptance rate. They charge twice as fast as conventional AGM batteries.
I would have chosen the EXIDE EK600 (TUDOR) 😊, but I have to admit that the VARTA does a fabulous job!
https://www.youtube.com/watch?v=bydW0NyYe38
Unscheduled tasks. Slight improvements.
- Fuel filter replacement.
- Front and rear brake discs and pads replacement.
- Brake fluid replacement.
- Rear shock absorbers replacememt. 1JP (factory) to 1JS.
During the summer months, when conditions are ideal 🤷‍♂️, I'll dedicate my free time to these small tasks.
I'm still waiting for some parts, but these are some I've 'carefully selected' for my 6R and its next 100,000 km.
Fuel filter:
In my case, the OEM supplier for VW is UFI.
Good video tutorial for the replacement:
:arrow: :arrow: :arrow: https://www.youtube.com/watch?v=S2CnIZrKuvc 👍
My notes (erWin readings):
Brakes:
256mm front, 232mm rear (same as stock).
I will test the ATE 'ceramic' pads, to try to keep the rims clean.
F
I'm not upgrading to 288mm FN3 front discs because comparatively the braking power of the 256mm FSIII front discs is already balanced by my 17" wheels and stock R-line/Sport suspension. As you already know... 'for better braking, larger tires are generally better than slightly larger discs'.
R
Ceramic brake pads require new discs without holes or evacuation grooves on the contact surface.
Brake discs and pads are replaced not only due to wear (dimensions), operating conditions (temperatures, micro temperatures, weather, salt, etc) cause the brake system materials to lose effectiveness.
My original brake discs and pads (100,000km - 14 years), based on my driving style, could last another 50,000 km if we consider their dimensions, but I'm replacing them to try and improve performance in the next 100,000km.
VW DOT 4.
(My) One-way valve bleeding method, combined with erWin instructions.🧙‍♂️
It will help maintain or improve brake effectiveness. Now is the ideal time.
1JS rear shock absorbers (6R0513025A). (Related: 1JS rear springs).
Awaiting delivery together the mountings, jounce bumpers, etc.
It will also help maintain or improve the effectiveness of the rear brakes. Now is the ideal time.
UPD:
In my case, SACHS is the original supplier.
Some of the cleaners and lubricants to ensure everything runs smoothly and provide greater longevity to the parts when performing these small tasks.
Calmly, without rushing, in summer m😄dE! 🌞🏄‍♂️ 🏖 🥤🍹
I was looking for some parts and came across these rear WRMs with more up-to-date software than my current ones.
8611 of the next generation, like the front ones for folding mirrors.
They're in like-new condition, cost me less than the shipping.🤷‍♂️
I'll test them out and see if anything new/magical happens.😋
POLO 6R. Rear WRMs with SW 8611 installed.
VCDS Autoscan
Tuesday,02,June,2026,11:30:00:32438
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: NEW REAR WRMS OK!
Mileage: 102050km-63410mi   Repair Order:
VIN: WVWZZZ6RZDY0CICLO   Mileage: 102050km-63410miles
   Revision: --------
   Coding: 01
   Revision: V0000000
   Coding: 0228DD
   Coding: 0200A3
   Coding: 1000A3
   Subsystem 8 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8611
   Serial number: KU0KU006051551268991
   Coding: 0200A3
   Subsystem 9 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
   Component: J389__TSG_HR  003 8611
   Serial number: KU0KU022041551127896
   Coding: 1000A3
   Coding: 0031167001
   ROD: N/A
1 Fault Found:
          - 00 [00001000]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 27
                    Mileage: 102051 km
                    Date: 2026.06.02.
                    Time: 11:08:24
   Coding: 00314D
   Coding: 140E01
   Revision: B9084001
   Coding: 002207
   Revision: AA001001
   Coding: 020100
   Coding: 529524A0
   ROD: N/A
   Coding: 11250
   Shop #: WSC 00788
   Data carrier:
   Coding: 032A1A64
End----------(Elapsed Time: 02:13, VBatt start/end: 12.4V/12.4V)-----------
Coding: 0200A3
Coding: 1000A3
I've coded them for rear side folding mirrors, set the comfort function, and they work perfectly for all window functions... except the rear side folding mirrors don't work with this coding.😥😁
I'll leave other codings for advanced automatic functions (rain closing, etc.) for another time, as I didn't have time for further testing.🍹🥤🏄‍♂️🌞 👱‍♂️->👱🏼‍♂️👱🏽‍♂️👱🏾‍♂️👱🏿‍♂️
Other small tasks. Battery terminal protectors and self-adhesive EVA foam pads.
Since the installation of the WRMs took little time, I took the opportunity to do something else...
Battery terminal protectors.
Lightly apply pure petroleum jelly/vaseline to the felt rings/washers for maximum effectiveness. Highly effective on lead-acid and EFB battery terminals, and also, though less necessary, on AGM battery terminals, as they act as a shield against external moisture.
Self-adhesive EVA foam pads.
After 14 years, the original VW round black stickers where the hood rubber stops rest had deteriorated due to poor quality :mrgreen: , and I had to go to the trouble of putting on these square pads to support the weight of life.
I install them square just to do something different, although I prefer round ones. :lol:
POLO 6R 1.2 TSI. Fuel filter replacement.
Previously: :arrow: viewtopic.php?p=610353#p610353
Some sources recommend turning the ignition switch two or three times before starting the engine to prime the filter, but I tried starting it directly to test it 😅, and it started perfectly on the first try. (another urban legend?🤭)
We take a short summer drive and check again for leaks. It's not necessary to jack up the car for this check.
One of the main reasons for changing the fuel filter with the pressure regulator valve is to prevent the fuel pump in the tank from having to work harder due to wear of the filter regulating valve spring.
T2 connector for insulating the wires of the old alternator. PWM, DF.
Since installing the fuel filter didn't take long, I took the opportunity to do something else...
Wire insulation connector:
Related: :arrow: viewtopic.php?p=610292#p610292
For quick leak inspection during the next 100,000km.😊
Locked
