Radio to lower din slot?
Harald73
Post by Harald73 »
is there a reason why I could not change my car radio to the lower din slot in the dashboard? Is the slot deep enough etc? I have the Sony CDX-M8800.
I ordered the the double cup holder and I think it would fit/look better in the upper slot.
mole
Admin
Post by mole »
I don't think there is a reason you cannot do this :)
Mole
n3oNx
Post by n3oNx »
Mine is in the lower slot. In fact the lower slot has more space tan the upper one. My radio in the top slot was kind of tight and stick out a little bit and in the down one is a perfect fit! =)
Harald73
Post by Harald73 »
It´s actually good to know so when I get around to installing the cup holder, I will truly consider the possibility of moving the radio to the lower slot.
I didn´t install the radio myself, I had it done at the dealer so that´s why I´m asking this.
How about the cup holder? Is it only for the looks or is it really worth something? A friend of mine has a similar one in his Audi and I think the plastic is somehow of a poor quality. Not sure but anyway...
Vdubber
Sponsor
Post by Vdubber »
I considered installing the radio in the lower DIN but decided against it.
My reason of thinking was, if your head unit was in the lower DIN and you went over a bump with drinks in the cup holders they could spill all over your radio.
(I have already soaked the heating dials and centre console a few times :roll: .)
Si
n3oNx
Post by n3oNx »
I allready tought in that but as I rarelly use the cupholder and when I used it i'm most of the times parked. But you can spill the drinks even with the radio in the upper slot. It's just a mather of luck or in this cas bad luck :P
Harald73
Post by Harald73 »
So is the cup holder really that bad? I guess one shouldn´t keep drinks in the car without a closed mug, bottle or something like that.
Maybe the cup holder is only for looks then? I don´t mind. Never seen one here in Finland so at least my centre console will look different.
n3oNx
Post by n3oNx »
I use my cup holder sometimes. I basically drive at night so drinks aren't that much need it in my car but when I go to McDonalds or something like that I use it! :P
richardshone
Post by richardshone »
I swapped mine over and the radio fits much better. As i still have the cubby slot, with the radio in the upper slot it was bending the cubby ever so slightly but it really bugged so me i swapped them and it works much better.
Harald73
Post by Harald73 »
So I swapped my radio to the lower slot and the only problem came with the double cup holder?? It doesn´t fit into the upper slot because the upper side of the slot is totally flat. How is that possible, it was supposed to be "universal" or something like that? Guess I should´ve checked that beforehand.
It could have been possible to install it to the lower slot but I wanted my radio there so I didn´t install it at all, damn! Waste of money anyway. And I had to but the original cuppy upsidedown to get it fit??
carmadaaron
Post by carmadaaron »
this looks like it was fitted by the manufacturer this way :)
shotta
Post by shotta »
Ive got a tele in the upper slot and a alpine mp3/dab in the lower slot theres plenty room in the heater control bit for any excess wiring :wink:
kash
Post by kash »
Does anybody know where you can get an original cubby slot? i.e. the twin cup holder fitting without the cupholders. all i want is the shelf thing.
carmadaaron
VAG parts on the bottom of this forum (main menu of forum), they source these parts
welcome to the forum btw 8)
kash
Post by kash »
Yeah, i had a look on there, but they only do the double cup holder version.
anybody selling their old one?
