Radio to lower din slot?
is there a reason why I could not change my car radio to the lower din slot in the dashboard? Is the slot deep enough etc? I have the Sony CDX-M8800.
I ordered the the double cup holder and I think it would fit/look better in the upper slot.
It´s actually good to know so when I get around to installing the cup holder, I will truly consider the possibility of moving the radio to the lower slot.
I didn´t install the radio myself, I had it done at the dealer so that´s why I´m asking this.
How about the cup holder? Is it only for the looks or is it really worth something? A friend of mine has a similar one in his Audi and I think the plastic is somehow of a poor quality. Not sure but anyway...
I considered installing the radio in the lower DIN but decided against it.
My reason of thinking was, if your head unit was in the lower DIN and you went over a bump with drinks in the cup holders they could spill all over your radio.
(I have already soaked the heating dials and centre console a few times
Si
Si
richardshone
So I swapped my radio to the lower slot and the only problem came with the double cup holder?? It doesn´t fit into the upper slot because the upper side of the slot is totally flat. How is that possible, it was supposed to be "universal" or something like that? Guess I should´ve checked that beforehand.
It could have been possible to install it to the lower slot but I wanted my radio there so I didn´t install it at all, damn! Waste of money anyway. And I had to but the original cuppy upsidedown to get it fit??
carmadaaron
carmadaaron
