HI every body i am new to uk polo and can only say it is a brilliant site.
Can some one please give me some advice on how to remove a 150mm
scratch which some b**t**d left on near side window.I have tried T-Cut
it worked so and so but not brilliant the scratch is not really that deep, but i can see it every time i get in the car.
cheers
dave-h
scratched glass
Spot on JJ, you can have your glass repaired if the damage is only superficial. I've had a look at the Autoglass website, and they state that if they can repair the damage using resin liquid treatment, you don't have to pay a penny under fully comprehensive insurance!
I also read a bit on how it's done:
Pretty cool huh? Autoglass claim to be able to do this repair on cracks and chips at or less than the size of a pound coin - would be interesting to see what they make of a scratch! Worst case scenario, you might have to replace the whole glass panel, which will only be £50 under FC insuranceWe first make sure that the damaged area is clean and tidy. We then suck all the air out of the chip with a vacuum and inject it with a clear resin liquid, before reversing the vacuum to force the resin to fill the chip.
We cover the chip with a special film and use an ultra-violet light to harden the resin. Finally, we polish the glass clean – and it’s immediately safe for you to drive away.
This whole process only takes around 20 minutes.
