tdi chipping
Non-VW related chat - Moderated
13twelve
tdi chipping
Post by 13twelve »
how much does this cane economy?
would a mk5 tdi give a gti a run for its money once its rolling?
carmadaaron
Post by carmadaaron »
i presume u have a mk5, 1.4 TDI 75hp
chip from Revo will give ~100hp :), get a better zorst/air intake,
strip the car and ull b looking at a close comp IMO :P
13twelve
Post by 13twelve »
s'what i thought
i can only imagine the economy would suffer though
the gti would have the edge on acceleration from 0 and with top speed though
Tahrey1043
Post by Tahrey1043 »
from 0, surely it depends how vicious you are with slipping the clutch? :D
maybe you could have a switchable mode chip put in that would crank the idle speed up a bit to remove both the diesel and the turbo lag...
(done deliveries in a diesel van, went like the clappers once rolling, but was hellish to get moving because of the almost binary clutch.. you'd either bark the tyres something rotten and look like a right herbert, or get bogged down at 1200rpm going nowhere... oh if only it was more easily slippable)
the economy, hmmm ...... well the diesel-cycle heat engine 8) is at its most efficient under full load / full acceleration, so it might not be as bad as all that...
Gareth_GT_Hatch
Post by Gareth_GT_Hatch »
you just have to get used to the "throttle lag." My TDI was pretty quick off the line and even better once moving. I don't think that chipping a diesel causes a big difference in fuel consumption (it may even improve if the map is "better")
