Anyone know if its possible and what are the bulb choices??
I've heard from some the Xenons on the Gti are ordered as a whole and that the whole front light setup cannot be oppened.
Is that true ??
I'm in the dark here....
Actually Main beam (the bulbs that comes on when you get the blue light on the dash) cannot be Xenons - the time to energise is too slow so they are conventional halogen bulbs.poussou wrote:Main beam are Xenons so not that.Not side ones either.
I mean the High Scale for driving in the open road without traffic.The one you get when u press the lever inwards and it locks.Blue light dash indicator....
YES !!Si_GTi wrote:You can get VW to plug a VAG-COM into the car and have your lights adjusted if they are pointing too low - might cost you 30 minutes labour (£35) though knowing them!
Poussou, I believe you are talking about the main-beam bulbs next to the xenon dipped-beam unit (see below). Like Neil says, its probably a bumper off, headlamps out, kind of job!
HTH
