RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
Re: RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
... have you installed the new Dimmer on your Sedan?
smg_shardul
- Drives: Polo 6R
Not yet..ciclo wrote:... have you installed the new Dimmer on your Sedan?
I am about to get dimmer switch in another one week.
I will definitely share here first as soon as I get dimmer switch
Licence plate light wiring done last week
In licence plate light connector pin no 2 was +ve searched the common wire of both connectors and connected wire to bcm.
Perfect.
.... I keep waiting to code your BCM with all the possible options in your Sedan.
smg_shardul
- Drives: Polo 6R
ciclo wrote:Maybe, ...show me a fuse box picture and an autoscan from that Polo Sedan.
Here is the pic of fuse box
Scanned report is shared you on mail unable to upload here
It is necessary to add this wire (SB49b to T73b/11) and a 15 Amp fuse in your friend's Sedan, apart from the two wires mentioned above for the cornering lights (foglights).
From the autoscan data,
Address 03: ABS Brakes (J454) Labels: None
Part No SW: 6W5 907 37< GF HW: 6W5 907 37< DQ
Component: AGV9.0 fwjnt H04 0054
Serial number: -((-----((----
Coding: 60D82A63212504C40311F470845920070500
Shop #: WSC 00000 640 08352
ASAM Dataset: ESZBrake4DBS90BJVCH 056017
ROD: N/A
VCID: 9521A7DF7474CDB6D75-80C0
No ASAM data for: "ESZBrake4DBS90BJVCH" (VW25)
What the h... is th., sorry, what is this?
I do not know if this Sedan has the Steering Angle Sensor (G85) like this viewtopic.php?f=56&t=69603&start=15#p520005 (with inspection window).
This sensor is necessary.
Take a picture of the buttons above the radio.
Thursday,25,May,2017,18:17:16:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWJ13601ET0xxxxx License Plate:
Mileage: 62438 Repair Order: 25052017
Chassis Type: 60 (6RU)
Scan: 01 03 08 09 10 15 17 19 25 44 56
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CLNA) Labels: None
Part No SW: 03L 906 023 NT HW: 03L 907 425 B
Component: 1,6l R4 CR td H33 9971
Revision: --H33--- Serial number:
Coding: 00110016030500080000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM16TDI02103L906023NT 003012
ROD: EV_ECM16TDI02103L906023CR_VW25.rod
VCID: 8501F79F04D47D36275-80D0
Readiness: 0000 0000
ROD: N/A
Part No SW: 6R0 907 044 L HW: 6R0 907 044 L
Component: Climatronic H12 0612
Revision: V0000000
VCID: 3C77D27BBF9E7CFE88B-8069
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6RU 937 086 M HW: 6RU 937 086
Component: BCM IM M+4 H40 0432
Revision: BY040001 Serial number: 0200 258150063
Coding: 3A904ABF08A10000003800002C0B04900000414F60040000200000000000
Shop #: WSC 12469 483 00190
VCID: 6BD521278A702B46511-803E
Subsystem 1 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB
Component: ------------- 006 5520
Coding: 010000
Subsystem 2 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB
Coding: 010000
Subsystem 3 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Component: E221__MFL-TAT H04 0019
Coding: 240000
Subsystem 4 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Coding: 020000
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361317300143
Coding: 108002
Shop #: WSC 00793 648 00255
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E73D873A1826EEEA6F-806B
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW00M0RR+
Coding: 003036
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250_VW24.rod
VCID: 4999BBAFE84CD95603D-801C
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6RF 920 860 K HW: 6RF 920 860 K
Component: KOMBI H02 0204
Coding: 150800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04718
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 52AB9CC3051A9A8E727-8007
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6RU 909 901 HW: 6RU 937 086
Component: GW-K-CAN TP20 H40 0432
Revision: BY040001
Coding: 002300
VCID: 19392BEF106C69D673D-804C
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H02 0204
Serial number:
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-44.clb
Part No SW: 6RF 909 144 K HW: 6RF 909 144 J
Component: EPS_ECU H44 0401
Coding: 0000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SteerAssisUDSNSK 005005
ROD: EV_SteerAssisUDSNSK.rod
VCID: 54A79ADB3F0E94BE60B-8001
Address 56: Radio (J503) Labels: None
Part No SW: 6RD 035 187 HW: 6RD 035 187
Component: Radio 517 5122
Revision: RB101000 Serial number: VWZZZ4Q5006273
Coding: 00000400040005
Shop #: WSC 00078 790 00236
VCID: 04076A9B87EEC43EB0B-8051
End ----------------------------------------------------------------------------------------------------------------------------------------------------
ROD: N/A
I suppose it does have the steering angle sensor, otherwise the power steering probably woudn't work? Or does it have its own sensor?
The power steering on the Polo here didn't function when the ABS was having a bad day (so the G85 wouldn' t communicate)
smg_shardul
- Drives: Polo 6R
He is going to install steering angle sensor with stalk...ciclo wrote:It is necessary to add this wire (SB49b to T73b/11) and a 15 Amp fuse in your friend's Sedan, apart from the two wires mentioned above for the cornering lights (foglights).
From the autoscan data,Code: Select all
Thursday,25,May,2017,18:17:16:62939 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 12.12.0.0 Data version: 20130910 VIN: WVWJ13601ET0xxxxx License Plate: Mileage: 62438 Repair Order: 25052017 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 60 (6RU) Scan: 01 03 08 09 10 15 17 19 25 44 56 VIN: WVWJ13601ET0xxxxx 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 56-Radio -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CLNA) Labels: None Part No SW: 03L 906 023 NT HW: 03L 907 425 B Component: 1,6l R4 CR td H33 9971 Revision: --H33--- Serial number: Coding: 00110016030500080000 Shop #: WSC 01234 785 00200 ASAM Dataset: EV_ECM16TDI02103L906023NT 003012 ROD: EV_ECM16TDI02103L906023CR_VW25.rod VCID: 8501F79F04D47D36275-80D0 No fault code found. Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J454) Labels: None Part No SW: 6W5 907 37< GF HW: 6W5 907 37< DQ Component: AGV9.0 fwjnt H04 0054 Serial number: -((-----((---- Coding: 60D82A63212504C40311F470845920070500 Shop #: WSC 00000 640 08352 ASAM Dataset: ESZBrake4DBS90BJVCH 056017 ROD: N/A VCID: 9521A7DF7474CDB6D75-80C0 No ASAM data for: "ESZBrake4DBS90BJVCH" (VW25) No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb Part No SW: 6R0 907 044 L HW: 6R0 907 044 L Component: Climatronic H12 0612 Revision: V0000000 VCID: 3C77D27BBF9E7CFE88B-8069 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb Part No SW: 6RU 937 086 M HW: 6RU 937 086 Component: BCM IM M+4 H40 0432 Revision: BY040001 Serial number: 0200 258150063 Coding: 3A904ABF08A10000003800002C0B04900000414F60040000200000000000 Shop #: WSC 12469 483 00190 VCID: 6BD521278A702B46511-803E Subsystem 1 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB Component: ------------- 006 5520 Coding: 010000 Subsystem 2 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB Component: ------------- 006 5520 Coding: 010000 Subsystem 3 - Part No SW: 6C0 959 442 HW: 6C0 959 442 Component: E221__MFL-TAT H04 0019 Coding: 240000 Subsystem 4 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L Component: ------------- 006 5520 Coding: 020000 Subsystem 5 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L Component: ------------- 006 5520 Coding: 020000 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb Part No SW: 6R0 919 475 C HW: 7E0 919 475 Component: PARKHILFE 4K H11 0013 Revision: -------- Serial number: 47361317300143 Coding: 108002 Shop #: WSC 00793 648 00255 ASAM Dataset: EV_VW250ParkiAssis2 S01008 ROD: EV_VW250ParkiAssis2.rod VCID: 3E73D873A1826EEEA6F-806B No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 5K0-959-655.clb Part No SW: 6R0 959 655 J HW: 6R0 959 655 J Component: VW10AirbagU06 H10 0020 Revision: -------- Serial number: 003GW00M0RR+ Coding: 003036 Shop #: WSC 01383 785 00200 ASAM Dataset: EV_AirbaVW10BPAVW250 A01001 ROD: EV_AirbaVW10BPAVW250_VW24.rod VCID: 4999BBAFE84CD95603D-801C No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb Part No SW: 6RF 920 860 K HW: 6RF 920 860 K Component: KOMBI H02 0204 Serial number: 00000000000000 Coding: 150800 Shop #: WSC 00793 648 00255 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04718 ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod VCID: 52AB9CC3051A9A8E727-8007 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: None Part No SW: 6RU 909 901 HW: 6RU 937 086 Component: GW-K-CAN TP20 H40 0432 Revision: BY040001 Coding: 002300 Shop #: WSC 12469 483 00190 VCID: 19392BEF106C69D673D-804C No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb Part No SW: 6RF 920 860 K HW: 6RF 920 860 K Component: IMMO H02 0204 Serial number: ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709 ROD: EV_Immo_UDS_VDD_RM09_VN35.rod VCID: 52AB9CC3051A9A8E727-8007 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J792) Labels: 6Rx-909-144-44.clb Part No SW: 6RF 909 144 K HW: 6RF 909 144 J Component: EPS_ECU H44 0401 Coding: 0000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_SteerAssisUDSNSK 005005 ROD: EV_SteerAssisUDSNSK.rod VCID: 54A79ADB3F0E94BE60B-8001 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels: None Part No SW: 6RD 035 187 HW: 6RD 035 187 Component: Radio 517 5122 Revision: RB101000 Serial number: VWZZZ4Q5006273 Coding: 00000400040005 Shop #: WSC 00078 790 00236 VCID: 04076A9B87EEC43EB0B-8051 No fault code found. End ---------------------------------------------------------------------
ROD: N/A
What the h... is th., sorry, what is this?![]()
smg_shardul
- Drives: Polo 6R
Thanks iichel for the replyiichel wrote:I suppose it does have the steering angle sensor, otherwise the power steering probably woudn't work? Or does it have its own sensor?
He is going to install steering angle sensor along with stalks ...
Okay. All solved for your friend.smg_shardul wrote: Tue Nov 07, 2017 5:12 pm
http://forums.ross-tech.com/showthread. ... &styleid=2iichel wrote: Tue Nov 07, 2017 5:09 pm I suppose it does have the steering angle sensor, otherwise the power steering probably woudn't work? Or does it have its own sensor?
iichel, you must study before making comments with assumptions.
smg_shardul
- Drives: Polo 6R
Yes all problems solvedciclo wrote:Okay. All solved for your friend.smg_shardul wrote: Tue Nov 07, 2017 5:12 pm
Will update once installation is finished
smg_shardul
- Drives: Polo 6R
I have one question regarding BCM operated Fog lamps
Can we connect fog lamp to Bcm instead of direct connection from switch ?
Yes, this is definitely possible. It is the same way the OEM static cornering lights in fog lights operate
smg_shardul
- Drives: Polo 6R
Cornering lights are in bixenon headlampsiichel wrote:Yes, this is definitely possible. It is the same way the OEM static cornering lights in fog lights operate
Any option when bixenon installed ?
Then it is not possible
