darrenpolo
Posts: 56 Joined: Sun Apr 03, 2011 1:01 pm
Post
by darrenpolo » Thu Mar 29, 2012 6:49 pm
Low version H&R Springs fitted, 35mm front, 45mm rear
Lamin-x foglights
Boyracer_2011
Posts: 454 Joined: Sun Sep 11, 2011 2:15 pm
Drives: 1.2 Moda
Post
by Boyracer_2011 » Thu Mar 29, 2012 6:54 pm
Very nice mate
Vissa
Posts: 75 Joined: Tue Dec 06, 2011 5:05 am
Post
by Vissa » Thu Mar 29, 2012 10:26 pm
Do those exist? I only see 25 front / 40 rear and 35 front / 55 rear for the 6R GTI on the H&R website?
Anyway it's looking good!
DubbisH
Posts: 75 Joined: Fri Mar 09, 2012 1:08 pm
Post
by DubbisH » Fri Mar 30, 2012 12:41 pm
Hey bud.....do you have a link or info on that laminx you used? I want to do this myself but some of the stuff is either to dark or too light....your looks about right there. Any info would be great cheers pal.
*DubbisH*
darrenpolo
Post
by darrenpolo » Fri Mar 30, 2012 8:22 pm
Thanks for the comments.
The springs are the lower version of the two available, because the gti i factory lowered it doesn't count as much of a drop.
As for the lamin x, just go on there website and click shop, you'll need 2x 12x4 sheets.
Works out about £17 delivered.
And for god sake don't buy the cheap £3.99 stuff off eBay
DubbisH
Post
by DubbisH » Sat Mar 31, 2012 10:12 am
darrenpolo wrote: Thanks for the comments.
Noted
Thanks mate.
*DubbisH*
tt509
Posts: 810 Joined: Sun Mar 23, 2008 3:27 pm
Post
by tt509 » Sat Mar 31, 2012 10:19 am
darrenpolo
Post
by darrenpolo » Thu Apr 26, 2012 8:54 pm
Installed wheel spacers to the rear today
Vissa
Post
by Vissa » Thu Apr 26, 2012 9:19 pm
What's the spacer thickness? Looks pretty thick!
darrenpolo
Post
by darrenpolo » Thu Apr 26, 2012 10:02 pm
Only 20'mm each side,
I'm getting 10'mm each side for the front.
NeilMcConville
Posts: 509 Joined: Sat Aug 27, 2011 12:00 pm
Post
by NeilMcConville » Thu Apr 26, 2012 10:13 pm
What make did you go for? Looking well
nodoze
Posts: 30 Joined: Thu Aug 25, 2011 11:37 am
Post
by nodoze » Fri Apr 27, 2012 12:44 am
I'm sorry to inform you, but with those 35mm springs on the front with a 10mm spacer you are going to be rubbing big time on cornering.
darrenpolo
Post
by darrenpolo » Fri Apr 27, 2012 11:15 pm
I've put the ten mm on now and no rubbing?!
