OBDeleven
GTI Polo Fin
Drives: Polo GTI 2019
Re: OBDeleven
Post by GTI Polo Fin »
monkeyhanger wrote: Fri Feb 14, 2020 9:53 am
john M wrote: Fri Feb 14, 2020 8:55 am You should increase the threshold voltage, not decrease it, to disable the stop start, suggest 16V or so.
Exactly, you need the battery voltage requirement at a level that the car can't achieve.
You think I haven’t tried? It is not possible to increase it to 16V or any other. I tried everything from 12V to 20V
Re: OBDeleven
The car's battery can hold a voltage of around 13.5v when fully charged. Any less than that stop start can kick in if the battery charge allows it and other factors do too (ambient temp, oil/water temp, how many ancillaries are on etc.).
Mine hardly ever has enough charge to activate in the Winter with my dashcam set on. Her a dashcam, or get in to the routine of turning stop-start off on every journey.
Plenty of people manage to do what you're trying to do with VCDS - Maybe it's an OBD11 functionality thing?
GTI Polo Fin
Re: OBDeleven
I just checked the voltage and it is 14.9V 😄😄
Dazeredo
Drives: Polo aw1 1.0t 95hp
Re: OBDeleven
Post by Dazeredo »
It's normal, it's the alternator voltage to charge the battery
john M
Drives: AW12BVA
Re: OBDeleven
Post by john M »
GTI Polo Fin wrote: Fri Feb 14, 2020 10:07 am
Re stop/start, you may find parameters for minimum and maximum ambient temperatures, default values (for both) are -50C (for 2020 Polo), range is -50C to +50C, if you change both to say +40C then this may disable it? but not sure because having two values is a bit conflicting I think.
GTI Polo Fin
Re: OBDeleven
john M wrote: Mon Mar 02, 2020 8:04 pm
But with the OBDEleven you can’t change ambient temperatures. Maybe it is possible with a VCDS device
proalves
Drives: Polo GTI AW1 2019
Re: OBDeleven
Post by proalves »
Some more changes made in the meantime...
Enable/Disable DRLs using Car Menu
-Select Control unit: 09 Central Electrics
-Security Access 31347
-Adaption
-Select Submenu - Daytime Running Lights
-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge möglich -> Activated (Default -> Not activated)
Heart-Beat light effect on Start Engine Button for Keyless
-Select Control unit: B7 Access Startsystem Interface
-Security Access 20103
-Adaptation
-Select Submenu - DeveloperCoding:Search lights
-ZAT_illumination_concept_mybeat_clamp58xt ->Activated (Default -> Not activated)
-ZAT_illumination_modus_mybeat_clamp58xt -> Activated (Default -> Not activated)
fran_92
Drives: Polo GTI 200hp
Re: OBDeleven
Post by fran_92 »
Has anyone reached activate the OEM alarm from factory??
It is suppose to be activated with OBDEleven following these steps, but I tried and it doesn't works..
1. Go to Module 09 - Electronic control unit
2. Enter Encoding (press up to the right, Bytes mode)
3. Go to Byte 12
4. Activate Bit 0
5. Confirm (V), code 31347
6. Go back, to Adaptation, same module
7. Enter anti-theft device
8. in DWA Alarmverzoegerung, change value to "Driver door contact thatcham"
9. in DWA Camper Modus, change value to "On"
10. in Ueberwachung Innenentriegelungshebel, change value to "On"
11. (optional) in Sirenen Alarmzahl, put the number of times it will beep when the alarm goes off, you can put 1 or 10, by default it is already 10.
12. in Akustischer Alarm Signalhorn, change value to "On"
13. in Diebstahlwarnanlage, change value to "On"
14. Confirm, code 31347
grazuncle2
Drives: Polo 1.0 TSI SE 2019
Re: OBDeleven
Post by grazuncle2 »
I didn't know there this thread till googling something else.
I tried to set DRLs off with handbrake via the OBDEleven credits app but said not supported when I got there (despite having DRLs..) your Polo may be different.. however if you try long coding and get into the electronics section 09
you find the list in populated largely in German..
however:
Search - tagfahrlicht Dauerfahrlicht bei Handbremse abschalten
Daytime running lights Switch off continuous running lights with handbrake
then select on or off
