BCM Max Transporter 2013
Shadow109
Drives: Vw t5.1 2013
Re: BCM Max Transporter 2013
Post by Shadow109 »
So finally I’ve got the new slip ring and the stalk
I have make all the additional wiring like Adams digram, no faults on vcds, but still no high beam, and the high beam light on the cluster is always on
Please post the autoscan.
Shadow109
Post by Shadow109 »
 Wednesday,30,December,2020,08:47:16:00009
VCDS Version: 20.4.1.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZDH036544   License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 37 56 5F 77 0B
VIN: WV1ZZZ7HZDH036544   Mileage: 202860km-126051miles
08-Auto HVAC -- Status: Not registered 0001
56-Radio -- Status: OK 0000
77-Telephone -- Status: Not registered 0001
Address 01: Engine (J623-CAAA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GF    HW: 03L 907 309 M
   Component: R4 2,0L EDC   H44 3312
   Revision: 26H44---    Serial number: 00000000000000
   Coding: 01114012232400080000
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906019GF 003002
   ROD: EV_ECM20TDI01103L906019FG_003.rod
   VCID: 75E154D3D4C13F2E28-8020
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0110
   Revision: 00H43001
   Coding: 508724AD89A70A9B24A79175696210
   Shop #: WSC 02736 790 49152
   VCID: 3A7B87EFB55F905605-806E
1 Fault Found:
00778 - Steering Angle Sensor (G85)
            005 - No or Incorrect Basic Setting / Adaptation
                    Fault Status: 01100101
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 202861 km
                    Time Indication: 0
                    Date: 2020.12.30
                    Time: 08:32:12
                    Count: 16384
                    Count: 257
                    Count: 8215
                    Count: 766
   Serial number: 10082013470288
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF34BFFE1F77C7679-802A
1 Fault Found:
1140738 - Steering angle sensor
          B1168 54 [009] - Missing Calibration / Basic Setting
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 202861 km
                    Date: 2020.12.30
                    Time: 08:32:11
                    Voltage terminal 15: 12.00 V
                    Voltage terminal 30: 12.15 V
                    Terminal 15 status: On
   Part No SW: 7E5 907 047 BM    HW: 7E5 907 047 BM
   Component: Climatic-T5   H20 0505
   Revision: 00001010
   Coding: 0000000002
   ROD: EV_ClimaT5Basis.rod
   VCID: 7BF542EBF2E5695E5E-802E
   Revision: B9080001    Serial number: 0771 351150194
   Coding: A8A0393A0E212012002808102F2B8CD4F08043FF60040040320000000000
   Shop #: WSC 54707 002 104857
   VCID: 68DF0DA79B73D2C6A3-803C
   Subsystem 1 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3313
   Subsystem 2 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3313
3 Faults Found:
00329 - Control Circuit for Unlocking Rear Lid
            011 - Open Circuit - Intermittent
                    Fault Status: 00101011
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 50
                    Mileage: 202861 km
                    Time Indication: 0
                    Date: 2020.12.30
                    Time: 08:37:04
01504 - Bulb for License-Plate Light (X)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 202861 km
                    Time Indication: 0
                    Date: 2020.12.30
                    Time: 08:32:14
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 50
                    Mileage: 202861 km
                    Time Indication: 0
                    Date: 2020.12.30
                    Time: 08:32:52
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28261631000160
   Coding: 308001
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   VCID: 71E960C3A0A9130EF4-8024
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag003 H07 0013
   Revision: --------    Serial number: 003HL00DDD0.
   Coding: 000000000000000000000000000000003033
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 356194D394417F2EE8-8060
   Part No SW: 7E0 920 970 N    HW: 7E0 920 970 N
   Component: KOMBI         H04 0805
   Coding: 160A00
   Revision: B9080001
   Coding: 042200
1 Fault Found:
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 202861 km
                    Time Indication: 0
                    Date: 2020.12.30
                    Time: 08:32:14
   Component: IMMO          H04 0805
   Serial number:
   ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
   VCID: 6ADB77AF8D7FE0D6B5-803E
Address 37: Navigation
Cannot be reached
Address 56: Radio
Cannot be reached
   Component: MU-S-ND-ER    H41 0478
   Serial number: VWZAZ2U1668085
   Coding: 06570001BE00000010110001000D08001F0100D401200100CE
   Shop #: WSC 00046 123 12345
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 2541449324E10FAE58-8070
6 Faults Found:
          U1101 00 [009] - Active
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 202861 km
                    Date: 2020.12.30
                    Time: 08:32:11
                    Voltage terminal 30: 12.0 V
2565 - GPS Antenna
          B1054 13 [009] - Open Circuit
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 202861 km
                    Date: 2020.12.30
                    Time: 08:32:12
7194 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 202861 km
                    Date: 2020.12.30
                    Time: 08:32:14
                    BAP-BAP_Function_ID: 02
0001 - Antenna 1 for Radio
          B1119 13 [009] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 202861 km
                    Date: 2020.12.30
                    Time: 08:32:12
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 0 dB�V
0003 - Antenna 2 for radio
          B111A 13 [009] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 202861 km
                    Date: 2020.12.30
                    Time: 08:32:12
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 2 for radio-Reception level antenna 2: 0 dB�V
1637 - Interface for External Media
          U11B8 00 [009] - No Communications
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 202861 km
                    Date: 2020.12.30
                    Time: 08:32:12
                    Interface for external media: status-Status: Open circuit
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 02:43)--------------------------
Shadow109 wrote: Tue Dec 29, 2020 5:42 pm So finally I’ve got the new slip ring and the stalk
no faults on vcds? :lol:
New navigation system! 8)
1- Make basic setting of the G85 sensor in Address 03 ABS. (priority)
2- New BCM coding:
A8A0393A0E212012002808902E2B8CD4F08043FF60040040320000020800
BCM adaptation --> Channel 54 ... from 0 to 1.
Notes:
- you have disabled the lamp diagnostics, ... for now we will leave it as is.
- if you have to re-enter the BCM coding, this new BCM coding will be your starting point. As future new BCM codings improve, they will be your new starting points in case you have to re-enter BCM coding.
3- Please show us a picture of the unlock mechanism for the rear lid of your T5.
Note: Maybe you encoded some Bit in BCM 087 that does not correspond to your tailgate opening.
4- Install RLS + HBA mirror.
This post deserves a music video :lol: :
Shadow109
Post by Shadow109 »
ciclo wrote: Wed Dec 30, 2020 9:10 am New navigation system! 8)
I'v got some toys from Madwarlock :D
ciclo wrote: Wed Dec 30, 2020 9:10 am 1- Make basic setting of the G85 sensor in Address 03 ABS. (priority)
it shows me an error, (tried with ignition on)
ciclo wrote: Wed Dec 30, 2020 9:10 am 2- New BCM coding:
Done, Interior Illumination Is working now, High beam light still not working, but high beam icon on the cluster gos on and of with the stalk
maybe something wrong with the wiring ?!
ciclo wrote: Wed Dec 30, 2020 9:10 am 3- Please show us a picture of the unlock mechanism for the rear lid of your T5.
I have retrofitted an electric rear tailgate, I will make some photos later
ciclo wrote: Wed Dec 30, 2020 9:10 am 4- Install RLS + HBA mirror.
waiting for 2k adhesive :cry: :cry:
new scan :-
Wednesday,30,December,2020,16:54:39:00009
www.Ross-Tech.com
VIN: WV1ZZZ7HZDH036544   Mileage: 202880km-126063miles
   Revision: 00H43001
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 12
                    Mileage: 202889 km
                    Time Indication: 0
                    Date: 2020.12.30
                    Time: 16:35:56
                    Count: 16384
                    Count: 257
                    Count: 8215
                    Count: 766
   Coding: 01
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 12
                    Mileage: 202889 km
                    Date: 2020.12.30
                    Time: 16:35:55
                    Voltage terminal 15: 12.30 V
                    Voltage terminal 30: 12.45 V
   Revision: 00001010
   Coding: 0000000002
   Coding: A8A0393A0E212012002808D02E2B8CD4F08043FF60040040320000020800
   Coding: 308001
   Coding: 160A00
   Revision: B9080001
   Coding: 042200
1 Fault Found:
            000 - -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 202889 km
                    Time Indication: 0
                    Date: 2020.12.30
                    Time: 16:35:55
   Serial number:
Cannot be reached
Address 56: Radio
Cannot be reached
   Coding: 06450001BE00000010110001010D08001F0300D401200100CE
5 Faults Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 12
                    Mileage: 202889 km
                    Date: 2020.12.30
                    Time: 16:35:55
                    Voltage terminal 30: 12.3 V
2565 - GPS Antenna
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 12
                    Mileage: 202889 km
                    Date: 2020.12.30
                    Time: 16:35:56
          U1111 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 12
                    Mileage: 202889 km
                    Date: 2020.12.30
                    Time: 16:35:58
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 12
                    Mileage: 202889 km
                    Date: 2020.12.30
                    Time: 16:35:56
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 12
                    Mileage: 202889 km
                    Date: 2020.12.30
                    Time: 16:35:56
Cannot be reached
End-------------------------(Elapsed Time: 02:28)--------------------------
Nice Madwarlock toys. An excellent buy, you will get more than expected. :wink:
To be able to perform the basic setting of the G85 sensor you first have to enter the security access.
The process should look something like this:
http://wiki.ross-tech.com/wiki/index.ph ... ic_Setting
Regarding the BCM we have improved enormously.
Have you correctly connected the wires for the high beams of each headlight?
- From T73a/1 and T73b/1 to the input (A) of the fuses for the high beams.
In that case, try this new BCM coding:
A8A0393A0E212012002808D02E2B8CD4F08063FF60040040320000020800
Shadow109
Post by Shadow109 »
Many thanks Fernando, Everything is working now except right high beam New scan :-
Friday,01,January,2021,18:52:52:00009
www.Ross-Tech.com
Mileage: 203160km-126237mi   Repair Order:
VIN: WV1ZZZ7HZDH036544   Mileage: 203160km-126237miles
   Revision: 00H43001
   Coding: 01
   Revision: 00001010
   Coding: 0000000002
   Coding: A8A0393A0E212012002808D02E2B8CD4F08063FF60040040320000020800
   Coding: 308001
   Coding: 160A00
   Revision: B9080001
   Coding: 042200
1 Fault Found:
            000 - -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 203164 km
                    Time Indication: 0
                    Date: 2021.01.01
                    Time: 18:48:54
   Serial number:
Cannot be reached
Address 56: Radio
Cannot be reached
   Coding: 06450001BE00000011110001010D08001F0303D401200100CE
4 Faults Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 17
                    Mileage: 203164 km
                    Date: 2021.01.01
                    Time: 18:48:53
                    Voltage terminal 30: 11.8 V
1564 - Microphone 1
          B129B 13 [009] - Open Circuit
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 17
                    Mileage: 203164 km
                    Date: 2021.01.01
                    Time: 18:48:53
          U1111 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 17
                    Mileage: 203164 km
                    Date: 2021.01.01
                    Time: 18:48:56
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 17
                    Mileage: 203164 km
                    Date: 2021.01.01
                    Time: 18:48:53
Cannot be reached
End-------------------------(Elapsed Time: 02:39)--------------------------
I made A little homework today :-
Perfect!!! we get better again, G85 sensor solved!
This last Autoscan means that you will not have any problems when installing the RLS and the HBA. :wink:
Regarding the high beam of the right headlight it is a fault in the wiring, fuse or bulb. Check them out.
Remember that this is the SB28 fuse, in which and according to the installation manual, you will have also added the wire that goes to the high beam warning lamp.
Therefore, ... T73a/1 -> (A) Fuse SB28 (B) -> right high beam wire + warning light wire.
The remaining faults in the autoscan are normal due to the installation of the 5F unit, you must code it according your equipments installed.
Thanks for the pictures of your progress with 5F.
Shadow109
Post by Shadow109 »
hello again Ciclo, I have installed HBA & RLS today
wiring :-
Mirror T8 :-
3- T73b-54
8- T73b-57
6- middle lights (I didn't install it) (please explain to me where to install it)
1- SC32
2- GND
RLS T3 :-\
1- +30
2-GND
3- T73b-24
coding that I made :-
black 9 :-
byte 4 bit 6
byte 8 bit 0
byte 10 bit 1& 2
byte 13 bit 7
byte 14 bit 1
byte 22 bit 5
New Autoscan :-
Saturday,09,January,2021,22:22:08:00009
www.Ross-Tech.com
Scan: 01 03 04 08 09 10 15 17 19 20 25 37 56 5F 77 0B
VIN: WV1ZZZ7HZDH036544   Mileage: 204110km-126828miles
   Revision: 00H43001
   Coding: 01
   Revision: 00001010
   Coding: 0000000002
   Coding: A8A0393A4E21201201280ED02EAB8ED4F08063FF60042040320000020800
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 230916 03  37  0059
   Coding: 028877
   Subsystem 2 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Subsystem 3 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
2 Faults Found:
03435 - Terminal 30 for Interior Light and Parking Light
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 204118 km
                    Time Indication: 0
                    Date: 2021.01.09
                    Time: 22:16:50
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 204118 km
                    Time Indication: 0
                    Date: 2021.01.09
                    Time: 22:16:50
   Coding: 308001
   Coding: 160A00
   Revision: B9080001
   Coding: 042200
1 Fault Found:
            000 - -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 204118 km
                    Time Indication: 0
                    Date: 2021.01.09
                    Time: 22:16:50
   Part No SW: 7E0 857 511 F    HW: 7E0 857 511 C
   Revision: AA001001
   Coding: 040400E200000100000000
   Shop #: WSC 12345 123 12345
   VCID: 2D51BCB37C1137EE90-8078
   Serial number:
Cannot be reached
Address 56: Radio
Cannot be reached
   Coding: 0645000FBE00000011110001010D08001F0303D401200100CE
   Data medium:
   Subsystem 1 - Part No SW: 5NA 919 866 AL    HW: -----------
   Component: MRM1 2020/21  --- 1420
5 Faults Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 204118 km
                    Date: 2021.01.09
                    Time: 22:16:49
                    Voltage terminal 30: 12.5 V
6720 - Rear View Camera
          B1102 31 [009] - No Signal
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 204118 km
                    Date: 2021.01.09
                    Time: 22:20:02
                    Voltage terminal 30: 14.0 V
          U1111 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 204118 km
                    Date: 2021.01.09
                    Time: 22:16:51
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 204118 km
                    Date: 2021.01.09
                    Time: 22:16:49
                    Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 204118 km
                    Date: 2021.01.09
                    Time: 22:16:50
Cannot be reached
End-------------------------(Elapsed Time: 04:03)--------------------------
Interior Light is not working
CH/LH not working
HBA not working
I wonder if all the issues is caused by the uninstalled wire :?
Regarding the mirror:
- The feed wire for the mirror is badly connected, the mirror needs a +15 signal (SC19) and you are using a +30 signal (SC32) ... (RLS and HBA wires OK).
- Have you connected the reverse 'signal' to the mirror? (it's just a question)
- Take a picture of the dome lights, buttons to turn on the dome lights and connector/s (T8?), ... there are different models of dome lights for T5 and it may not be possible to connect wire 6.
Regarding the BCM coding (block 09) that you have done:
1- In BCM adaptations you have to enable channel 53 - from 0 to 1 - for the HBA to work.
2- New RLS coding: 0228EE or 0228DD
3- Also enable Byte13 Bit6 to TEST that the CH/LH functions also work on the main headlights instead of the fog lights. You can then choose between the main headlights or the fog lights.
edit
Also check the condition of the SC17 fuse (7.5 A), it may have blown due to working in the area of the light dome.
Shadow109
Post by Shadow109 »
ciclo wrote: Sun Jan 10, 2021 9:37 am - The feed wire for the mirror is badly connected, the mirror needs a +15 signal (SC19) and you are using a +30 signal (SC32) ... (RLS and HBA wires OK).
Done
ciclo wrote: Sun Jan 10, 2021 9:37 am - Take a picture of the dome lights, buttons to turn on the dome lights and connector/s (T8?), ... there are different models of dome lights for T5 and it may not be possible to connect wire 6.
speaking about the doom lights, I wanna replace it with this :-
ciclo wrote: Sun Jan 10, 2021 9:37 am - Have you connected the reverse 'signal' to the mirror? (it's just a question)
No, to which pin ??
ciclo wrote: Sun Jan 10, 2021 9:37 am Regarding the BCM coding (block 09) that you have done:
All done
ciclo wrote: Sun Jan 10, 2021 10:19 am Also check the condition of the SC17 fuse (7.5 A), it may have blown due to working in the area of the light dome.
Yes indeed, I have replaced it
new Autoscan (before changing the fuse)
Sunday,10,January,2021,15:07:37:00009
www.Ross-Tech.com
VIN: WV1ZZZ7HZDH036544   Mileage: 204130km-126840miles
   Revision: 00H43001
   Coding: 01
   Revision: 00001010
   Coding: 0000000002
   Coding: A8A0393A4E21201201280ED02EEB8ED4F08063FF60042040320000020800
   Coding: 0228EE
2 Faults Found:
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 204135 km
                    Time Indication: 0
                    Date: 2021.01.10
                    Time: 15:02:32
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 204135 km
                    Time Indication: 0
                    Date: 2021.01.10
                    Time: 15:02:32
   Coding: 308001
   Coding: 160A00
   Revision: B9080001
   Coding: 042200
1 Fault Found:
            000 - -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 204135 km
                    Time Indication: 0
                    Date: 2021.01.10
                    Time: 15:02:32
   Revision: AA001001
   Serial number:
Cannot be reached
Address 56: Radio
Cannot be reached
   Data medium:
4 Faults Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 204135 km
                    Date: 2021.01.10
                    Time: 15:02:31
          U1111 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 204135 km
                    Date: 2021.01.10
                    Time: 15:02:34
                    Voltage terminal 30: 11.9 V
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 204135 km
                    Date: 2021.01.10
                    Time: 15:02:32
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 204135 km
                    Date: 2021.01.10
                    Time: 15:02:32
Cannot be reached
End-------------------------(Elapsed Time: 03:58)--------------------------
Excellent. HBA !!! Congratulations. 8)
Learn how to use it, it only works with the light switch in AUTO.
I was assuming there was something wrong with the SC17 fuse, the BCM detected faults should go away on your next autoscan. 👍
It was a problem with the power of signal 58.
Your new mirror with HBA does not need the wire for the reverse signal, the non-dimming function when reversing goes through the new CAN lines.
Thank you very much for all the images of the dome lights. 👌
To install the wire 6 on your new HBA anti-dazzle mirror, the best OEM option (great option :)) is to install the Passat B5 (W8) dome lights as follows:
For those who want to know more about the Pin 6 of the dome lights with ambient lights (the two red LEDs) of the Passat B5 and other models where they were installed, I leave this diagram here:
I love the old VW diagrams.
Shadow109
Post by Shadow109 »
thanks a lot ciclo
I think I did something wrong with doom lights, when I connected it, the right light was on no matter what I did
After testing RLS & HBA :-
Auto lights works perfectly
CH & LH not working yet
HBA not working yet
Rain sensor not working yet
I have found a flat with RLS today
Tuesday,12,January,2021,22:46:59:00009
www.Ross-Tech.com
VIN: WV1ZZZ7HZDH036544   Mileage: 204590km-127126miles
37-Navigation -- Status: Sporadic communication error 1000
56-Radio -- Status: Sporadic communication error 1000
5F-Information Electr. -- Status: Malfunction 1010
Readiness: 0 0 0 0 0
   Revision: 00H43001
   Coding: 01
   Revision: 00001010
   Coding: 0000000002
   Coding: 0228EE
5 Faults Found:
                    Fault Priority: 3
                    Fault Frequency: 16
                    Reset counter: 83
                    Mileage: 204135 km
                    Time Indication: 0
                    Date: 2021.01.10
                    Time: 15:02:32
                    Fault Priority: 2
                    Fault Frequency: 30
                    Reset counter: 84
                    Mileage: 204135 km
                    Time Indication: 0
                    Date: 2021.01.10
                    Time: 15:08:33
01520 - Rain and Light Recognition Sensor (G397)
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 19
                    Reset counter: 85
                    Mileage: 204148 km
                    Time Indication: 0
                    Date: 2021.01.10
                    Time: 17:07:11
01502 - Bulb for Rear Fog; Left (L46)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 45
                    Mileage: 204583 km
                    Time Indication: 0
                    Date: 2021.01.12
                    Time: 21:06:42
                    Fault Priority: 3
                    Fault Frequency: 36
                    Reset counter: 45
                    Mileage: 204135 km
                    Time Indication: 0
                    Date: 2021.01.10
                    Time: 15:02:32
   Coding: 308001
   Coding: 160A00
   Revision: B9080001
   Coding: 042200
4 Faults Found:
            000 - -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 204135 km
                    Time Indication: 0
                    Date: 2021.01.10
                    Time: 15:02:32
01304 - Radio
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 80
                    Mileage: 204135 km
                    Time Indication: 0
                    Date: 2021.01.10
                    Time: 15:20:42
01300 - Control Module for Navigation with CD-Rom (J401)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 80
                    Mileage: 204135 km
                    Time Indication: 0
                    Date: 2021.01.10
                    Time: 15:20:42
03158 - Control Module for Information Electronics 1 (J794)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 80
                    Mileage: 204135 km
                    Time Indication: 0
                    Date: 2021.01.10
                    Time: 15:20:41
   Revision: AA001001
   Serial number:
Cannot be reached
Address 56: Radio
Cannot be reached
   Data medium:
7 Faults Found:
1556 - Internal Control Module Memory Check Sum Error
          B2000 87 [009] - Missing message
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 204135 km
                    Date: 2021.01.10
                    Time: 15:23:23
                    System_Software_Error-SW_Status_Consistency: 04 01 01
                    System_Software_Error-SW_Status_Device: o
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 204135 km
                    Date: 2021.01.10
                    Time: 15:02:31
2562 - Navigation System
          B126C F0 [009] - Navigation Database Faulty
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 204135 km
                    Date: 2021.01.10
                    Time: 15:22:56
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 204135 km
                    Date: 2021.01.10
                    Time: 16:06:06
                    Voltage terminal 30: 13.9 V
          U1111 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 204135 km
                    Date: 2021.01.10
                    Time: 15:02:34
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 204135 km
                    Date: 2021.01.10
                    Time: 15:02:32
          U11B8 00 [008] - No Communications
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 81
                    Mileage: 204135 km
                    Date: 2021.01.10
                    Time: 15:02:32
Cannot be reached
End-------------------------(Elapsed Time: 03:59)--------------------------
Edit: I noticed that the illumination of the mfsw buttons won't turn of after I turn the car off with auto lights on (only in the night)
Enable Byte3 Bit7 in your BCM coding, although I don't think it will have any effect on the detected faults...
- HBA should work, if it had a malfunction it would be indicated in the MFD+.
Codify Address 20 to: 010100E200000100000000 (for halogen headlights) although I don't think it will have any noticeable effect on the operation of the HBA.
- There is also something wrong with the RLS wiring, some wire is probably not securely connected. (AUTO yes, but not CH/LH... hmm)
Check the electrical installation, pins on connectors, etc ... +30, LIN, ground ...
This is interfering with the operation of the CH/LH and the automatic operation of the windshield wiper.
- There is clearly something wrong with the wiring you have installed for the dome lights (W8). This electrical installation is producing a short circuit at some point in the installation.
If you have installed LED bulbs be careful not to short-circuit the electrical system when installing them. Check the SC17 fuse again. (install a 10A fuse)
I have double checked all the BCM coding and it is correct.
This process is getting stuck in its final phase, my conclusion is that there are some wires that is not properly installed. :?
You are forced to also check the electrical installation you made for your new navigation system (due to the interior lights). :|
edit
MFSW feed = +15 ...
