ABS Long code needed
semaisking
Drives: POLO 6R 1.4
Re: ABS Long code needed
Post by semaisking »
Here it is:
Tuesday,11,January,2022,18:19:52:00009
VCDS Version: 21.9.0.2
Data version: 20210903 DS330.0
VIN: WVWZZZ6RZAY072623   License Plate:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 56
VIN: WVWZZZ6RZAY072623   Mileage: 140830km-87507miles
Address 01: Engine        Labels: 03C-906-024-BXW.lbl
   Part No SW: 03C 906 024 BH    HW: 03C 906 024 BH
   Component:       CGGB  MM4HV G 8327
   Revision: --H09---    Serial number:
   Coding: 0000071
   Shop #: WSC 07102 298 177429
   VCID: 65C10493AF61CFA1D2-5178
   VINID: 9E69EAAAA1A2A91A401C21820C49610369
Readiness: 0110 0001
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 R    HW: 6R0 907 379 R
   Component: ESP8.2i front H04 0002
   Revision: --------
   Coding: 210224E3217400B4842B24E484D400401300
   Shop #: WSC 80093 222 69422
   VCID: 4D91DC3310D117E1FA-8018
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
   Part No SW: 6R0 820 045 E    HW: 6R0 820 045 E
   Component: Climatic       24 0600
   Revision: 00 10 24
   VCID: 306FA5C763235A09F1-8064
1 Fault Found:
16372 - Control Module; Unspecified Internal Error
            014 - Defective
                    Fault Status: 01101110
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 15662 km
                    Time Indication: 0
                    Date: 2011.11.05
                    Time: 09:15:52
   Part No SW: 6R0 937 087 B    HW: 6R0 937 087 B
   Component: PQ25 BCM      H08 0025
   Revision: BF008001    Serial number: 9955A149090992
   Coding: 24B02BBF08A10000003000007C2B0CD000C0410F608400002000
   Shop #: WSC 64564 324 38760
   VCID: 3C7781F7BF6BAE695D-8068
   Subsystem 1 - Part No SW: 6R0 959 801 H    HW: 6R0 959 801 H  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  004 0803
   Serial number: KU0-KU031.08.0911346
   Coding: 08BC30
   Subsystem 2 - Part No SW: 6R0 959 802 K    HW: 6R0 959 802 K  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  004 0803
   Serial number: KU0-KU021.08.0913084
   Coding: 02BC30
   Subsystem 3 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  004 0803
   Serial number: KU0-KU002.09.0912911
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475     HW: 6R0 919 475
   Component: PARKHILFE 4K  H07 0008
   Revision: --------    Serial number: 71320924506933
   Coding: 100001
   Shop #: WSC 124697 483 00190
   ASAM Dataset: EV_VW250ParkiAssis2 S01006
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 7BF542EBF2E5695114-802E
   Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Component: VW10AirbagA09 H09 0018
   Revision: --------    Serial number: 003DW0046UCE
   Coding: 003039
   Shop #: WSC 06401 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 428BFF0FD58FD89917-8016
   Serial number: 349  RB4000000000005
   Serial number: 350  RB400000000000/
2 Faults Found:
9445459 - Key switch for deactivation of passenger-side airbag
          B1020 53 [009] - Deactivated
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 140833 km
                    Date: 2022.01.11
                    Time: 05:31:43
9447251 - Seat Occupied Sensor; Passenger's Side
          B1027 53 [009] - Deactivated
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 140833 km
                    Date: 2022.01.11
                    Time: 05:31:43
   Part No SW: 6R0 920 860 B    HW: 6R0 920 860 B
   Component: KOMBI         H23 0112
   Coding: 140A00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
   VCID: 3365AACB9A3561118C-8066
1 Fault Found:
10485833 - Internal Control Module Memory Check Sum Error
          B2000 49 [137] - Internal Electronic Failure
                    Fault Priority: 2
                    Fault Frequency: 1
   Part No SW: 6N0 909 901     HW: 6R0 937 087 B
   Component: GW-K-CAN TP20 0025
   Coding: 002200
   VCID: 70EF65C7A3A31A09B1-8024
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H23 0112
   Serial number:
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
   Part No: 6R0 423 156 A
   Component: LenkhilfeTRW        V275
   Coding: 10150
   Shop #: WSC 00000
   VCID: 2E53BBBFED174CF9E3-807A
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 01000000    Serial number: VWZ1Z2L9134216
   Coding: 0800020002
   VCID: 65C104936C61CFA1D2-8030
End-------------------------(Elapsed Time: 02:37)--------------------------
Thank you!
Bryt
Drives: Ibiza
Post by Bryt »
ciclo wrote: Wed Jan 12, 2022 12:59 pmThank you!
Hello, please help with the long ABS code. Thank you Zdeněk
Hi, welcome.
Some/More information is needed, or perhaps I'm missing something...🤷‍♂️
Bryt
Drives: Ibiza
Post by Bryt »
Hello, I bought a car and the abs is on and the error codes are 01042, 03306 and the abs has a long code of all zeros. and I pulled this code from the car's memory. Thank you for your help
Bryt
Drives: Ibiza
Post by Bryt »
saved broken code
24882BE888610100003000007E0B1CD800C0400F608C0000200000000000
Bryt
Drives: Ibiza
Post by Bryt »
Vín code : VSSZZZ6JZAR119021
The fault codes mean the module is not coded and the current coding is invalid (AI), as indicated in the autoscan of the user who started this thread (first post).
A full autoscan is necessary, and since it's a Seat Ibiza(?)
- Types of front and rear brakes with disc sizes.
- Manual or automatic transmission.
The BCM coding (09 Address) is not necessary here, it provides information but is not required.
However, if you have VCDS, you might be able to generate your own ABS coding if you read this thread on the Drive2.ru forum, especially where it says, IMPORTANT INFORMATION! = ПОЛЕЗНО ЗНАТЬ! and download the ABS.zip file. Following the instructions, you should then move the labels to the 'user' labels folder in your vcds program.
Bryt
Drives: Ibiza
Post by Bryt »
Thank you very much for that, I'll try it.
Extract the zip file, place the labels inside this folder...
Copy the 0s coding, open Ne-tech (ross-tech app - inside ross-tech program), paste the 0s coding (pasted by default*), click Read lbl file (2), select your ABS system (1) and begin coding your ABS system (2) according to your vehicle's specifications.
1
2
Copy the result of your evil wizard spells and test it.
You can also code it directly, but it's better to create the spell first and then paste it when encoding via the OBD2 port, this way you will prevent the power (battery) of your magic wand from running out.
Easy, fun and for all types of of apprentice magician... 🧙‍♂️
