Aftermarket Steering Pump code HELP!!!
Re: Aftermarket Steering Pump code HELP!!!
Once the Steering Assist (44) has been coded with the code '11250' (in your case), you may also have to do the basic setting of steering angle sensor (G85) in the ABS unit (03), which is a different procedure.
VCDS procedure: http://wiki.ross-tech.com/wiki/index.ph ... ic_Setting
Something similar will be for your diagnostic tool.
Keep in mind that it is possible that the faults will disappear once you exit communication with the ABS module and perform a new ignition cycle.
I just realized that the part number of the pump you installed is not correct:
Must be:
6R0423156C
The item 12H0037 'according to Autodoc' should be compatible, but the pump you installed (6Q0423156AB) is installed on previous models (Polo 9N3, Ibiza 6L, ...).
Looks like you're absolutely right ciclo:
Somebody else with the same problem: https://forums.ross-tech.com/index.php? ... ost-124227
I'd suggest to get the right 6R0 C pump
Interesting side facts:
it shows on this PQ25 Ibiza scan: viewtopic.php?t=72356 (ESP, 2011)
2010 Fabia 5J PQ25 (no ESP): https://www.digital-kaos.co.uk/forums/s ... abs-coding
