RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
smg_shardul
Drives: Polo 6R
Post by smg_shardul »
Finally I got dimmer switch
I tried a lot to source only dimmer switch but didn't got it so took with combination of headlight range control which was easily available at vw India service center and will be useless as I installed bixenon headlights
Thanks a lot ciclo for your exceptional support
Thanks a lot govind for helping me to source dimmer switch
Mean while I edited eeprom of amarok cluster which was installed earlier and pending to support to my vento
Successfully edited it to suit it to vento following changes were done after editing eeprom
1) wheel circumference value was changed to 1843 mm from 2350mm
2) Truck logo in mfd display was changed to sedan
3) Brake oil light error was removed
4) Fuel tank characteristics was changed to 55 lit from 80 lit
Thanks a lot Firegrafics , Madwarlock & Benji for providing all information related to eeprom...ImageImage
Sent from my Pixel 2 using Tapatalk
MaDwArLoCk
Drives: Cross Polo 2010 TSI
Re: RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
Post by MaDwArLoCk »
Well done, Shardul!
Looks really good! :)
smg_shardul wrote: Wed Dec 13, 2017 3:29 pm Thanks a lot ciclo for your exceptional support
At your disposal.
If you want me to correct something of your BCM coding you have to post here a new Autoscan. Now or whenever you want.
God job!
smg_shardul
Drives: Polo 6R
Can I install front seats of Passat with Massager and electric adjustable in polo sedan 6R
My car is already installed with BCM Max will my BCM support these seats ?
Thanks in advance ..
sharan1988
Drives: Polo sedan
Post by sharan1988 »
where did u source the cluster from? i have a vento tsi aswell
smg_shardul
Drives: Polo 6R
sharan1988 wrote:where did u source the cluster from? i have a vento tsi aswell
I got it on eBay
It won't fit for tsi
smg_shardul wrote: Fri Dec 22, 2017 7:33 am Can I install front seats of Passat with Massager and electric adjustable in polo sedan 6R
It is difficult to know, there are many electric seats that do not need any type of connection to the BCM, but there are others that need such connection.
It is important to know in which model year those seats are installed.
sharan1988
Drives: Polo sedan
can't i get one for the tsi...vagtune sells for 44k ..is it worth so much?
smg_shardul
Drives: Polo 6R
sharan1988 wrote:can't i get one for the tsi...vagtune sells for 44k ..is it worth so much?
Search on eBay u will get it in the range of 15k to 25k
Before purchasing any cluster talk to your dealer whether they will install or not 90% of the dealer deny for Installation and no one can install cluster except vw service station
sharan1988
Drives: Polo sedan
Ok will do . Thank you :)
sharan1988
Drives: Polo sedan
Been trying to source a steering wheel with paddles.. mine is flat bottom With out paddles ..Could you help me with it ?
smg_shardul
Drives: Polo 6R
Thanks Ciclo for the reply
They are from 2013 model Passat
It is with Massager and electric adjustable
I will confirm here how is the connection for seat before purchasing
smg_shardul
Drives: Polo 6R
sharan1988 wrote:Been trying to source a steering wheel with paddles.. mine is flat bottom With out paddles ..Could you help me with it ?
I have it in stock PM me..
smg_shardul
Drives: Polo 6R
Can anyone tell me where I will get H4 to H7/H7 headlight wiring converter?
you don't, it's the same connector.
